Old 02-27-2018, 10:55 AM   #1
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Stock suspension shot, looking to replace with Bilstein B8/RCE Tarmac.
I'm at 72k miles and my stock suspension seems to be on its last legs. After some research, I believe I'm set on Bilstein B8s with RCE Tarmacs along with SPC rear LCAs and SPC front camber bolts. My car is my daily with occasional weekend auto x use so I would like a little more turn in than stock but not enough to greatly affect daily drivability/tire wear which is why I don't think camber plates are necessary. Looked into coilovers, but don't want to spend that much for good ones and I don't really need the adjustability.
I plan on bringing it to a performance shop for install/alignment, my main question is whether there is anything else I might want to look into replacing to possibly save on labor while I'm doing this. I've done about 25 auto x events plus back-road driving so the car hasn't exactly led an easy life and I don't want to things to start breaking now with a stiffer suspension. Thanks.
TL;DR - 72k miles, thinking Bilstein B8/RCE Tarmac with rear LCAs and front camber bolts. Anything else I should look into replacing while I'm at it?
rapidcars is offline   Reply With Quote
Old 02-27-2018, 11:33 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I don't see any reason why B8 over B6. There is no gain to be had, but loose droop travel, rest being same.
rapidcars (02-27-2018), strat61caster (02-27-2018)
Old 02-27-2018, 11:49 AM   #3
rapidcars
rapidcars's Avatar
Been going back and forth on that. I read that B8 was better for lowering and B6 was better for stock springs but there's doesn't seem to be a lot of info on it.
Old 02-27-2018, 12:04 PM   #4
jmark
Drives: '97 NSX-T, '18 Type R
Why not go for the GTWORX/BILSTEIN Trophy Cup Coilovers coming soon for the BRZ?
jmark is offline   Reply With Quote
The Following User Says Thank You to jmark For This Useful Post:
Old 02-27-2018, 12:32 PM   #5
Qadthane
Qadthane's Avatar
Drives: 2013 FR-S in Asphalt
I paired RCE Tarmac springs with Raceseng camber plates. The lowering spring combined with the reduced stack height of the camber plate left the spring not captive when at full droop. The B8 damper, with its reduced droop travel, held the spring captive. If you think you may add camber plates later, going with B8's now may be wise. I'm not saying the B8 is better; I'm just putting info out there in case it is helpful.
Qadthane is offline   Reply With Quote
The Following User Says Thank You to Qadthane For This Useful Post:
Old 02-27-2018, 12:36 PM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
If you're on all stock stuff now, also consider the RCE T0. Another excellent choice. T0 is $1700, so not far from similar pricing. Check the RCE bundles too, as they have some nice packages that can save a few bucks and hassle.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Old 02-27-2018, 12:55 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Sounds like a solid plan. What size wheel/tire?
@Racecomp Engineering could give you solid feedback on b6 vs b8 with their tarmacs
Leonardo (02-27-2018)
Old 02-27-2018, 01:33 PM   #8
rapidcars
rapidcars's Avatar
17x8 48mm offset O.Z. Ultraleggera. Currently have 225 Michelin PSS but will probably change to 245 200TWs when they wear out depending on how much I'm autocrossing.
Old 02-27-2018, 01:39 PM   #9
JazzleSAURUS
Moving from the 225 MPSS to a 245 200tw will make your suspension work quite a bit harder. If you might hit the track, I'd go RS4 or Victra VR1, if it's purely autox I'd go RE71R. The RE71R is a ridiculously fast tire in Autox and epic on the street, but it's a one lap wonder on the track. It will grease out and become useless. (I choose to run them on the toy car where tread life isn't a big concern.
Old 02-27-2018, 01:56 PM   #10
It's a great set-up with a lot of happy people running that combo.
This would be the reason to get B8's, otherwise stick with B6. You may want the camber plates if you go to 245s.
We do have a our Bilstein/GTWORX coilovers coming out this spring...little bit firmer springs (but great valving) and a little more expensive than the strut + spring combo.
- Andrew
jmark (03-08-2018), rapidcars (02-27-2018)
Bilstein B8|RCE Tarmac Springs|Racer-X LCA|More H1C Brakes, Suspension, Chassis 3 02-19-2018 12:05 AM
IN-STOCK Coilover/Suspension Parts Blitz | Tanabe | Apexi | HKS | Bilstein | KW | B&G FRSport.com Brakes, Suspension, Chassis 22 10-19-2017 01:41 PM
RCE Tarmac springs w/ Bilstein B8 struts drifter-s Brakes, Suspension, Chassis 2 05-31-2017 10:50 AM
Opinions: Tein Flex A or RCE Tarmac/Bilstein ChrisSC300 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-06-2015 12:39 AM
Switched from RCE Yellows to Bilstein B8/RCE Tarmac Springs was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 01-23-2015 11:19 PM
