Old 02-26-2018, 02:14 AM   #43
Hyperblue302
Hyperblue302's Avatar
Drives: 2016 BRZ, 94 Integra GSR
Fwiw, I ran the avcs tool about 2 years ago. With well over 100 runs run thru the tool, these are the values I ended up with.
Edit: Only mods were panel filter and EL header
Hyperblue302 is offline   Reply With Quote
The Following 2 Users Say Thank You to Hyperblue302 For This Useful Post:
freerunner (02-26-2018), solidONE (02-26-2018)
Old 02-26-2018, 01:43 PM   #44
Tor
Tor's Avatar
Drives: Toyota GT86
Cool! What was your method? Did you change one cam at a time? And how many flashes did it take.
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
Old 02-26-2018, 06:43 PM   #45
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Same cam timing with about 15 to 20*f ambient temperature differential. Oddly the logs take in higher ambient temps (66*f) also read higher average VE than in lower ambient temps (45*f ish).
apparently you can smooth the lines further by clicking on the "go" button more times. did not know that.
Red trace 66*f Blue trace 45*f ish
Edit: Would this be a good way to approach? Take logs using various cam maps varying about 5* increments then load them all to the app and see what it spits out?
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 03-05-2018, 10:41 PM   #46
solidONE
solidONE's Avatar
After establishing what I thought a decent improvement in the intake cam setting I tried 3 different exhaust cam settings. Logs taken within an hour of eachother under very similar conditions 3 degree differential in ambient temps. Plugged it in the app and see what it spat out.
The result looks a bit odd at the 4200rpm marker. Maybe I shoudl take more logs with all 3 different exhaust cam settings.
Intent > Content
Old 03-06-2018, 01:24 PM   #47
Kodename47
Kodename47's Avatar
Drives: UK GT86
@solidONE extract those 3 pulls from the log (you can use the WOT tab and then feed it back in) and that will probably clean up the results. The tool doesn't seem to take into account whether you tick/untick. I would say looking at the VE the curve you want is quite clear, red to ~3700, then the green for the rest. Remember that the Ex AVCS is going to net you less gain than the intake so don't expect massive swings in VE from the changes.
.: Stealth 86 :.
Kodename 47 DJ:
solidONE (03-06-2018)
Old 03-06-2018, 10:38 PM   #48
solidONE
solidONE's Avatar
Yup! I'll just run the setting that gives the richest mixture or allow the most advanced ignition without knocking. Can barely tell the difference between the different settings. Maybe I should try the different settings using E85 and see if it makes a larger difference. But let me try plugging in select pulls form each log as you suggested.
Intent > Content
Old 03-07-2018, 04:25 AM   #49
Kodename47
Kodename47's Avatar
Drives: UK GT86
How do you mean the one that gives the richest mixture. The AVCS shouldn't change the AFR that much, unless you have crazy overlap of course. That 2nd chart pretty much verifies the 1st one. Can you not delete the unwanted pull columns in the input screen? You can do similar for the OL MAF tab etc. Would save you taking the data out in a different tab.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-07-2018, 11:52 AM   #50
solidONE
solidONE's Avatar
"Cam 1" with less exhaust retard trends very slightly leaner than "Cam2" with abou 5-7* more exhaust retard. Not sure if it's a direct result of difference in cam timing or other factor. There is about 5*f difference between ambient temps between the logs. I'll still need to figure out if this will allow me to increase ignition timing. That's what I mean. Though I'm not sure if it will make a difference in knock/iginition advance threshhold. I aim to find out. Though, it seems with my current ignition map using this winter blend fuel it has already crossed slightly over that threshhold.
Cam 1: https://datazap.me/u/solidone/cam2-7...3252-3263-3272
Cam 2: https://datazap.me/u/solidone/z7-di5...2578-2588-2599
Intent > Content
Old 03-08-2018, 01:36 AM   #51
freerunner
freerunner's Avatar
Drives: GT86
It's a good sign if AFR gets leaner with <I>less</I> overlap. IF LTFT didn't change due to atmospheric conditions. Pressure wave exploited.
freerunner is offline   Reply With Quote
Old 03-08-2018, 03:19 AM   #52
solidONE
solidONE's Avatar
I'm pretty sure the LTFT is 0 since these pulls were logged right after flashing, but I only have 14 channels to log LTFT wasn't one of the 14 I logged. I really should buy a tactrix to log with.
Intent > Content
Old 10-03-2018, 04:05 PM   #53
JIM THEO
Drives: BRZ 2018
I bring back this old thread just to ask you, what base intake/exhaust AVCS tables you are using with the Gruppe-s adapted AVCS normal/safe maps?
JIM THEO is offline   Reply With Quote
Old 10-03-2018, 05:06 PM   #54
tomm.brz
Drives: brz 2017 hksv2
you don t need to change or tune BASE avcs, they aren t used. they are used only in limp mode or with am of 0.1, and if get those base tables used, you have bigger problems to think of
JIM THEO (10-03-2018)
Old 10-22-2018, 01:33 PM   #55
craneom
Grease Monkey
Originally Posted by Tor View Post
I already did the Gruppe-S header.
There is no difference betweem 91 and E85 in with regards to valve timing. It's flow specific.
Below in copy paste friendly format (maybe I did some tweaks since the picture above, can't remember anymore).
I would much appreciate feedback either as a comment here in this thread or per PM.
Intake:
Code:
[Table3D]
0.15000000596046448	0.20000000298023224	0.30000001192092896	0.4000000059604645	0.5	0.6000000238418579	0.699999988079071	0.800000011920929	0.8500000238418579	0.8999999761581421	0.949999988079071	1.0	1.100000023841858	1.2000000476837158	1.2999999523162842	1.399999976158142
800.0	0.0	0.0	0.0	0.0	0.0	0.0	10.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0
1000.0	0.0	-5.0	-5.0	-5.0	-5.0	0.0	10.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0
1200.0	0.0	-10.0	-10.0	-10.0	-10.0	-10.0	10.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0	20.0
1600.0	0.0	-10.0	0.0	0.0	0.0	0.0	10.0	20.0	25.0	25.0	25.0	25.0	25.0	25.0	25.0	25.0
2000.0	0.0	0.0	0.0	0.0	0.0	0.0	10.0	20.0	30.0	30.0	30.0	30.0	30.0	30.0	30.0	30.0
2200.0	5.0	5.0	15.0	5.0	5.0	5.0	10.0	20.0	33.0	33.0	33.0	33.0	33.0	33.0	33.0	33.0
2400.0	10.0	10.0	20.0	10.0	10.0	10.0	10.0	20.0	33.0	35.0	35.0	35.0	35.0	35.0	35.0	35.0
2800.0	10.0	10.0	15.0	10.0	10.0	10.0	10.0	20.0	33.0	37.0	37.0	37.0	37.0	37.0	37.0	37.0
3200.0	10.0	10.0	10.0	10.0	10.0	10.0	10.0	25.0	33.0	39.0	39.0	39.0	39.0	39.0	39.0	39.0
3600.0	10.0	10.0	10.0	20.0	20.0	20.0	20.0	25.0	33.0	39.0	39.0	39.0	39.0	39.0	39.0	39.0
3800.0	10.0	10.0	10.0	20.0	20.0	20.0	20.0	25.0	33.0	39.0	39.0	39.0	39.0	39.0	39.0	39.0
4000.0	10.0	10.0	10.0	20.0	20.0	20.0	20.0	25.0	33.0	39.0	39.0	39.0	39.0	39.0	39.0	39.0
4200.0	10.0	10.0	10.0	20.0	20.0	20.0	20.0	25.0	33.0	39.0	39.0	39.0	39.0	39.0	39.0	39.0
4400.0	10.0	10.0	10.0	20.0	20.0	20.0	20.0	25.0	33.0	39.0	39.0	39.0	39.0	39.0	39.0	39.0
4600.0	10.0	10.0	10.0	15.0	15.0	20.0	20.0	25.0	33.0	39.0	39.0	39.0	39.0	39.0	39.0	39.0
4800.0	10.0	10.0	10.0	10.0	10.0	20.0	20.0	25.0	33.0	39.0	39.0	39.0	39.0	39.0	39.0	39.0
5200.0	10.0	10.0	10.0	10.0	10.0	20.0	20.0	25.0	33.0	38.0	38.0	38.0	38.0	38.0	38.0	38.0
5600.0	10.0	10.0	10.0	10.0	10.0	20.0	20.0	25.0	33.0	37.0	37.0	37.0	37.0	37.0	37.0	37.0
6000.0	10.0	10.0	10.0	10.0	10.0	20.0	20.0	23.0	30.0	34.0	34.0	34.0	34.0	34.0	34.0	34.0
6400.0	10.0	10.0	10.0	10.0	10.0	20.0	20.0	20.0	29.0	29.0	29.0	29.0	29.0	29.0	29.0	29.0
6800.0	10.0	10.0	10.0	10.0	10.0	20.0	20.0	20.0	23.0	23.0	23.0	23.0	23.0	23.0	23.0	23.0
7000.0	10.0	10.0	10.0	10.0	10.0	18.0	18.0	18.0	18.0	18.0	18.0	18.0	18.0	18.0	18.0	18.0
7200.0	10.0	10.0	10.0	10.0	10.0	14.0	14.0	14.0	14.0	14.0	14.0	14.0	14.0	14.0	14.0	14.0
7400.0	10.0	10.0	10.0	10.0	10.0	10.0	10.0	10.0	10.0	6.0	6.0	6.0	6.0	6.0	6.0	6.0
Exhaust:
Code:
[Table3D]
800.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0	0.0
1000.0	0.0	0.0	0.0	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001	10.000610376140001
1200.0	0.0	0.0	10.000610376140001	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337	19.99969487337
1600.0	10.000610376140001	19.99969487337	19.99969487337	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003
2000.0	10.000610376140001	19.99969487337	30.000305249510003	39.99938974674	39.99938974674	39.99938974674	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758
2200.0	10.000610376140001	19.99969487337	30.000305249510003	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674
2400.0	10.000610376140001	19.99969487337	30.000305249510003	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674
2800.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674
3200.0	19.99969487337	30.000305249510003	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	35.00061043758	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674
3600.0	19.99969487337	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674
3800.0	19.99969487337	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674
4000.0	19.99969487337	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674
4200.0	19.99969487337	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674	39.99938974674
4400.0	19.99969487337	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	35.00061043758	37.50000009216	37.50000009216	37.50000009216	37.50000009216	37.50000009216	37.50000009216	37.50000009216	37.50000009216
4600.0	19.99969487337	30.000305249510003	35.00061043758	35.00061043758	35.00061043758	30.000305249510003	30.000305249510003	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758	35.00061043758
4800.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	30.000305249510003	30.000305249510003	32.00073250052	32.49969490409	32.49969490409	32.49969490409	32.49969490409	32.49969490409	32.49969490409	32.49969490409	32.49969490409
5200.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003	30.000305249510003
5600.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	30.000305249510003	30.000305249510003	30.000305249510003	27.49938971602	27.49938971602	27.49938971602	27.49938971602	27.49938971602	27.49938971602	27.49938971602	27.49938971602
6000.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	30.000305249510003	30.000305249510003	30.000305249510003	27.49938971602	27.49938971602	27.49938971602	27.49938971602	27.49938971602	27.49938971602	27.49938971602	27.49938971602
6400.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	30.000305249510003	30.000305249510003	30.000305249510003	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144
6800.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	30.000305249510003	30.000305249510003	30.000305249510003	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144
7000.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	30.000305249510003	30.000305249510003	30.000305249510003	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144
7200.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	28.99932868455	28.99932868455	28.99932868455	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144
7400.0	19.99969487337	30.000305249510003	35.00061043758	39.99938974674	39.99938974674	28.99932868455	28.99932868455	28.99932868455	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144	25.00000006144
Tor, are you still running these tables? What other adjustments have you made? I am using these exact tables coupled with some MAF scaling adjustments and my Gruppe-S header. Below 3k under too much throttle or load it will buck and stumble. It pulls -0.65 FLKC under WOT between 3800 and 4000 rpm and almost seems like it breaks up above 7k. Not sure if it's my MAF scale or what... '13 BRZ.
craneom is offline   Reply With Quote
Old 10-22-2018, 03:23 PM   #56
JIM THEO
Drives: BRZ 2018
Mine with the above AVCS maps did the same before perfect MAF scaling mainly in ELC maps, also between 5600-6400 loose control of left-right intake AVCS, they have some remarkable difference, I don't know why.
-0.65 FLKC under WOT between 3800-4000rpms especially with 4th-5th-6th gears is minimal in my humble opinion, I am not expert though!
AVCS tuning Turdinator Software Tuning 9 11-24-2015 02:31 PM
AVCS tuning for power and economy KoolBRZ Software Tuning 8 04-13-2015 12:07 PM
Feeler: Dyno Tuning Session via Jamesm @ HRI tuning sw20kosh Northern California 27 11-28-2014 08:53 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Dyno Nights @ FR&R tuning GeeTee86 AFRICA 1 06-25-2013 05:25 AM
