Old 04-27-2014, 10:37 PM   #1
Turdinator
Señor Member
Turdinator's Avatar
AVCS tuning
Hello,
I don't plan on fiddling with the CAM maps anytime soon but I was thinking about it how it might all work since I bought my OFT. If you didn't know what you were doing could you make the valves hit the pistons etc?
1974 TA22 Celica
2013 86 GT
Old 04-28-2014, 02:33 AM   #2
86drift
86drift's Avatar
Drives: Toyota 86 GT
Originally Posted by Turdinator View Post
Hello,
Doubt it. I've maxed out the values and haven't made a mess of my engine.
86drift is offline   Reply With Quote
Old 04-28-2014, 03:57 AM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Cam timing changes does not equal changes in valve lift. Look at an OEM ROM and see the changes that occur in stock form.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-28-2014, 09:08 AM   #4
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
ive edited some vvt changes but it just ignores imputs that are adjusted higher then what shiv already has there. when datalogged the intake cam still dips in the middle and phases off at the end and the exhaust wont stay more then 26 after 5k. idk whats with it
IG-Joey_Soul
Old 04-28-2014, 10:58 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
How many cam tables are you adjusting and which ones are they?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-28-2014, 11:04 PM   #6
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ive only adjusted the (normal) intake and exhaust tables which the car seems to follow much closer then the other tables
IG-Joey_Soul
Old 04-29-2014, 02:28 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
May well be due to oil pressure. I'm not sure why you're keeping the exhaust that advanced that high in the range?
Are you adjusting both hi and low det cam maps (intake and exhaust) or the basemaps?
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-01-2014, 02:48 PM   #8
Grip Ronin
The Mechanic
Grip Ronin's Avatar
hi and lows? no jus the normal map. and the oft tune comes at 25 on the exhaust side all the way to redlineon stg 2
IG-Joey_Soul
Old 05-01-2014, 05:42 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
That'd be why then. I'm not sure when the car uses the base map but generally you should be on the low det cam maps, although I've been told it uses the high det map for a short period.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-24-2015, 01:31 PM   #10
KoolBRZ
KoolBRZ's Avatar
OFT uses the Safe tables mostly
In OFT they are called Safe and Normal maps. I've found that the Safe map is used most often. Here is some of my work. I left the Base tables as they are. The normal tables are the way Shiv made them for stage 2 OTS tunes.
If I say yes, will that make you think I understand?
AVCS - Intake and Exhaust Timing Kodename47 Software Tuning 274 02-28-2021 11:39 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 03:01 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 06:33 PM
