Old 01-19-2018, 05:48 PM   #617
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
learn adobe inventor...
Originally Posted by celek View Post
Everything finalized, but finding an open CNC machine is tough. Although I had a local business to me offer free use of a 4 axis CNC if I wanted to use it to play around....
Now the problem is teaching myself how to program one, so maybe next decade???
Currently building 3 other engines for people has hindered my free time to do such tasks
You can auto generate G code with adobe inventor....
Jaden
Jaden is offline   Reply With Quote
Old 01-20-2018, 08:56 AM   #618
celek
Resident Gear Head
celek's Avatar
This has probably been said, but have you thought about abandoning development of the ITBs and buying a ITB kit from one of the manufacturers that have done the development?
No I do not like the designs available. They are incorporating the factory MAF to make it more plug in play which also restricts the flow.
They also use a circular off the shelf throttle body which is smaller than the opening of the port on the head so you build velocity then lose it before it enters the head.
It's almost like drag racing and hitting peak boost then your wastegate dumping it then hitting peak boost over and over surging.
celek is offline   Reply With Quote
Old 01-20-2018, 12:53 PM   #619
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
That’s kinda what I was thinking when I saw the designs, and I figured a more open system would breathe better.
Old 01-20-2018, 12:57 PM   #620
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
Interesting. Dunno if you know the answers to these yet or not but, what are you going to use in place of the factory maf? Will your setup require an aftermarket full standalone ecu?
cyde01 is offline   Reply With Quote
Old 01-20-2018, 02:45 PM   #621
celek
Resident Gear Head
celek's Avatar
speed density tuning with Ecutek
Old 01-20-2018, 03:51 PM   #622
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not Alpha-N? It is possible with EcuTek Would possiblt run better and just have SD for idle etc.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-22-2018, 03:19 PM   #623
fika84
fika84's Avatar
Jaden
All machine controllers require different G-Code formats... it's not as simple as just printing out G-Code from an application. It needs to be formatted to the specific controller.
fika84 is offline   Reply With Quote
Old 01-22-2018, 09:52 PM   #624
Jaden
Road-hole
adobe inventor allows you to choose the output format...
Look into it. Adobe inventor allows you to choose the output format. I use it for the CNC lathe that I designed and built. It's a total cad/cam package and fairly easy to adapt to if you've done any cad before.
Jaden
Old 01-23-2018, 01:40 PM   #625
fika84
fika84's Avatar
Jaden
I've used primarily EdgeCam and used it on many types of CNC machines, as well as setup controllers and machines from scratch. You can't just say spit out the G-Code and have it work on 100% of controllers.. that's it. G-Code isn't a one size fits all for CNC machines. Yes it's the language needed to run a CNC controller, but each CNC controller needs a different format and specific commands to run properly. A simple example are machines that have tool changers and machines that don't. Or machines that have the X or Y axis inverted. Or 3 vs 4+ axis machines. Or G-Code for a CNC Lathe vs Mill vs Wire EDM, etc. etc.
Take it from me, machinist get REAL mad if they run your code and it rapids the tool into the part or part holder... replacing bearings isn't cheap..
Old 01-23-2018, 06:26 PM   #626
Jaden
Road-hole
you're not understanding me.
The CAM part of inventor, gives a drop down menu for the controller you are using in order to output the proper G-code.
I'm sure not all of them could possibly be covered, but a vast majority of them are.
If you ask your machinist what controller they are using, you can check if Inventor has the capability to output in that format.
Jaden
Old 01-23-2018, 07:40 PM   #627
Ok, guys. Please allow me to mediate.
1. Let's agree that Adobe Inventor has a comprehensive manufacturer-specific g-code library.
2. It's up to the machinist to verify any code before running it. Even if you and I were the best of buddies, I would still test the shit out of any code you handed me and would expect you to do the same. That's just being a grownup doing grownup stuff.
3. Unless it's a super simple part, the machinist will probably disagree with some aspect of the code because he likes doing a certain thing his way on his machine.
I would offer the machinist an export as a courtesy only after discussing my drawings with him.
Fully defined engineering drawings are still the standard.
...now back to our regularly scheduled ultimate build thread.
Old 01-24-2018, 01:14 PM   #628
fika84
fika84's Avatar
Jaden
That's cool
I find it awesome that you made your own lathe!
Old 01-24-2018, 02:15 PM   #629
Jaden
Road-hole
thanks...
That's cool
Thanks.
technically it is a mill as well. I created it with 3 axes so I can mount a piece where the tool for the lathe would normally mount and put a mill bit in the lathe chuck and can use it as a mill or I can lock down the lathe in one of 24 positions and use it as an indexable 3 axis mill with something mounted in the lathe.
Jaden
I also have a 12X36 gun-smithing lathe for the real precision work. I make custom pool cues.
Old 02-22-2018, 03:10 PM   #630
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
@celek- If this is not proprietary info, how did you go about sourcing custom pistons, as in how do you know if you've got things like compression ratio, valve locations/lift clearance, etc. right? Sorry if this is a vague question, I'm just learning this stuff.
Thanks!
Will
Williampreza is offline   Reply With Quote
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
