Old 10-19-2017, 08:53 AM   #603
celek
Resident Gear Head
celek's Avatar
Originally Posted by nav View Post
Hey Celek, hope the ITB dream is progressing well! How's it going?
Everything finalized, but finding an open CNC machine is tough. Although I had a local business to me offer free use of a 4 axis CNC if I wanted to use it to play around....
Now the problem is teaching myself how to program one, so maybe next decade???
Currently building 3 other engines for people has hindered my free time to do such tasks
celek is offline   Reply With Quote
The Following 5 Users Say Thank You to celek For This Useful Post:
Jaden (01-19-2018), nav (10-19-2017), Reamer (10-20-2017), Teseo (10-20-2017), Ultramaroon (10-19-2017)
Old 10-20-2017, 11:55 AM   #604
KryptoNate
KryptoNate's Avatar
Drives: '14 Asphalt FR-S
You taught yourself Solidworks, so I have no doubt you can teach yourself basic 3-axis machining pretty quickly. You will probably want to use a CAM software for the throttle control box at least. It will save you a lot of time over programming by hand.
I couldn't really tell from the pictures if you did, but you should be able to simplify the throttle control box some for machining. For example don't machine the strengthening ribs by the motor bearing. Make the top of the ribs the new bottom of the cavity ( assuming there is clearance).
Feel free to ask questions about CAD/CAM. My job is designing forge tooling using CAD which then gets machined by the in-house die shop who use CAM.
Keep up the good work!
Sent from my SM-J510MN using Tapatalk
KryptoNate is offline   Reply With Quote
The Following 4 Users Say Thank You to KryptoNate For This Useful Post:
celek (10-23-2017), nav (10-22-2017), Reamer (10-20-2017), sato (10-20-2017)
Old 10-20-2017, 01:59 PM   #605
fika84
fika84's Avatar
I can also suggest my services to help convert your SolidWorks part(s) to GCode. I've used Edgecam in the past. I would just need their machine definitions for the 4 axis and to know what tools they have available to get started..
I would also be willing to help tutor you with setting up the CAM! We could do remote sessions.
Did they tell you what software they typically use at that shop?
fika84 is offline   Reply With Quote
The Following 4 Users Say Thank You to fika84 For This Useful Post:
Old 10-20-2017, 07:07 PM   #606
sato
sato's Avatar
Drives: Dodge Patitas
The last two posts exemplify one of the reasons I love this community!
Sent from my E6653 using Tapatalk
sato is offline   Reply With Quote
Old 10-23-2017, 12:49 PM   #607
celek
Resident Gear Head
celek's Avatar
I will do some looking around. thanks for the heads up. Honestly the hardest part will be figuring out how to convert the code and learn about the machining process. designing fixtures and flipping the block of billet.
I have simplified it by removing un needed machined areas. Rib is needed for the bearing as the return spring sits down there
Ill have to get with them after SEMA everyone is headed there so not many to communicate with for the next 2 weeks.
Old 10-24-2017, 12:37 PM   #608
fika84
fika84's Avatar
Yeah going from CAD to CAM the biggest thing to think about is the tool paths, speeds and feeds. During senior design I machined over 100 parts out of 6061 and 7075 and was using a 3-axis CNC. So 90% of them had to have 2-4 separate operations for them to be completed.
More recently I helped a buddy get a 3-axis machine setup from the ground up. He bought a used machine and we got the machine definitions setup and working with the CAM software. He's now manufacturing weapons parts and I helped with build his first AR-15 lower. By far the most complicated part I'd machined. It had 5 or 6 operations to be completed and we had to build jigs for it.
Happy to chat about it further if you want.
The Following 2 Users Say Thank You to fika84 For This Useful Post:
nav (10-24-2017), Tristor (03-07-2018)
Old 10-24-2017, 04:09 PM   #609
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Yeah really. I always just assumed you save a CAD file as a parasolid format and import it into the machine like you do with a 3D printer. I just subscribed to this thread.
Yardjass is offline   Reply With Quote
Old 10-25-2017, 02:48 PM   #610
fika84
fika84's Avatar
Lots of differences and similarities between cutting metal vs melting plastic.
The Following User Says Thank You to fika84 For This Useful Post:
Old 12-16-2017, 12:12 PM   #611
Zentec
Drives: 2017 Toyota 86
Happy Holidays all!! Celek any updates from sema how’s it coming along?
Zentec is offline   Reply With Quote
Old 12-20-2017, 04:28 PM   #612
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
i'd like to hear an update as well. now that there are a few itb kit options, would you consider using one of those, or are you in too deep in developing your own?
cyde01 is offline   Reply With Quote
Old 12-22-2017, 02:38 PM   #613
iluvdrt
Drives: 2017 Series.yellow
subscribed. Just read the whole thread. Learning a lot about this engine. Nice work!
I'm an old school suby guy. EA's and EJ's.
iluvdrt is offline   Reply With Quote
Old 01-19-2018, 01:52 PM   #614
oso_25
OH HEY NOW!!!!
oso_25's Avatar
Drives: 2013 Scion Fr-s Asphalt
@celek any updates? Just happened to run into this post after thinking about installing a ITB into my FRS
oso_25 is offline   Reply With Quote
Old 01-19-2018, 02:28 PM   #615
celek
Resident Gear Head
celek's Avatar
Currently engine Itb development is on hold.
I've designed this you may have seen it on Facebook. Trying to fund ITB dev with a much needed bearing and fork solution.
The Following User Says Thank You to celek For This Useful Post:
Ultramaroon (01-23-2018)
Old 01-19-2018, 04:50 PM   #616
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
This has probably been said, but have you thought about abandoning development of the ITBs and buying a ITB kit from one of the manufacturers that have done the development?
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
