Old 02-19-2018, 10:09 AM   #43
fika84
fika84's Avatar
http://www.ft86club.com/forums/showthread.php?t=45217
" I found that ring and pinion sets meant for a North American MK3 Supra (8" or 205mm ring diameter) will fit, but the pinion seal will most likely not."
fika84 is offline   Reply With Quote
The Following 2 Users Say Thank You to fika84 For This Useful Post:
clay217 (02-19-2018), Teseo (02-19-2018)
Old 02-19-2018, 10:49 AM   #44
clay217
Drives: 2013 scion frs , 1999 subaru legacy
sent spencer @ weir another email even though it seems pointless, try try and try and his prices are far better than mfactory ect
clay217 is offline   Reply With Quote
Old 02-19-2018, 12:20 PM   #45
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Man, you’re pretty vocal about not getting a response from Spence Weir, but I called the number listed on the website (707-315-6638) and he picked up on the second ring. He said he’s absolutely swamped and just to call him until you reach him.
RJasonKlein is offline   Reply With Quote
Old 02-19-2018, 12:45 PM   #46
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by nextcar View Post
Heads up! I have no connection and make no claims/recommendations on this...
Ebay has a listing for a New Weir Performance 4.56 gear set for FRS with bearings, seals, and solid spacer. Ends tomorrow and has a reserve; don't have any idea what it will sell for. If interested go to ebay and search "weir performance"
I was just trying to find a picture of a weir gear set to see if there were any identifying marks on it and ran across this.
I bid on this and I am assuming one of you bastards beat me on it.
Old 02-19-2018, 03:59 PM   #47
clay217
I have a few times and i am in Canada so its cost a bit every time.I am vocal cause everyone just says to use him and I am looking for other info as he is unreachable to me it seems so i rather just move along and source some. But I will give him a call thanks for the heads up....
Old 02-19-2018, 04:00 PM   #48
clay217
seems buddy out bid you by $5 i gave up early as the $ shot up
Old 02-21-2018, 12:46 PM   #49
scottman
scottman's Avatar
Drives: 13 mt fr-s
Also Canada, I called Wier and ordered mine a month ago, without any issues, and I received it 2 weeks ago.
Phones man.
scottman is offline   Reply With Quote
Old 02-21-2018, 01:21 PM   #50
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Phones man.
I have been calling Weir from the states. No response.
Old 11-23-2020, 09:59 AM   #51
Helturus
Drives: 2013 Toyota GT86
Toyota ring and pinion part numbers compatible with the FRS. Not all can be ordered in North America; I had to order mine from Japan. The only real problem with some of the third party gears is a bit of whine due to not all being helical cut.
3.58:1 - 41201-80125
3.73:1 - 41201-80050
3.91:1 - 41201-80052
4.10:1 - 41201-19605
4.30:1 - 41201-29606 (Included pinion seal will not fit)
4.56:1 - 41201-19557 (Included pinion seal will not fit)
4.88:1 - 41201-80183 (Included pinion seal will likely not fit)
5.13:1 - 41201-80300 (Included pinion seal will likely not fit)
Good luck.
...I went 4.56 with a MT, but sometimes I think I should have gone 4.88
Incase anybody digs this up in 2020 and wants to use the above Toyota part code for the 4.88:1.
Be warned it is incorrect. It has a significantly thicker spline for the pinion yoke compared to stock. Therefore the original one will not fit.
Don't make the same mistake I did
Sadly I do not have the correct Toyota part code to rectify the misinformation.
Helturus is offline   Reply With Quote
The Following 4 Users Say Thank You to Helturus For This Useful Post:
Lonewolf (12-01-2020), Spankopotomous (12-19-2020), Stonehorsw (11-24-2020), Tanstin (11-24-2020)
Old 12-01-2020, 06:29 PM   #52
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Original post updated to reflect your issue
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Old 12-01-2020, 08:09 PM   #53
Lonewolf
Lonewolf's Avatar
Drives: Moped
Is it possible there are different part numbers for different world markets?
frs differential
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
Engine Builds-Reviews tg_1981 Forced Induction 17 01-13-2014 05:19 PM
FBM BRZ/FRS Shop Builds/Projects FullBlown Forced Induction 50 10-21-2013 02:10 PM
