Old 02-20-2018, 08:06 PM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by D-rek07 View Post
I don't think a BBK is necessary for this lightweight car.
This thread is great:
http://www.ft86club.com/forums/showthread.php?t=94608
Most of us amateurs won't come out ahead on that cost analysis.
Why does Subaru now provide a factory Brembo setup if it's unnecessary?
Profit.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
gtengr (02-21-2018), Qadthane (02-21-2018), Yardjass (02-21-2018)
Old 02-20-2018, 08:21 PM   #16
D-rek07
How many pads do you have to burn up and how many times do you have to flush fluid, before you've covered the cost of a BBK and then some?
Offering a performance item on a sports car is a no brainer, regardless if its necessary enough. People will buy it because they think its supposed to be on there. It's all about money. It's a really good deal on our end but Subaru is getting the parts so cheap, they can offer them at a low price.
I still don't know what burning up fluid is so I can't even start on that comparison. You will also burn up brake pads and go through fluid on a BBK eventually. Those prices will also have to go into owning a BBK. It's not like once you buy a BBK, you don't have to change pads or fluid anymore.
D-rek07 is offline   Reply With Quote
Old 02-21-2018, 03:44 AM   #17
LancePower
Drives: 2020 BRZ tS
Good reading....
https://grassrootsmotorsports.com/ar...aking-systems/
LancePower is offline   Reply With Quote
The Following User Says Thank You to LancePower For This Useful Post:
gtengr (02-21-2018)
Old 02-21-2018, 11:21 AM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Squishy pedal? Change it. Fluid is not amber? Change it. 2 years old? Change it.
Or use Project Mu. Green turns clear if it absorbs too much moisture (aging), or turns brown if it gets too hot (tracking).
PM to order.
Don't forget to bleed your clutch pedal every 2 years too.
Damn, that's useful. Might have to try that next time (just bled them with fresh RBF600 though)
Old 02-21-2018, 11:57 AM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I go mostly by color.
Tcoat Take a look at it. It should be almost clear. If milky, rusty coloured, or blackish then it needs to be changed. It should smell sort of sweetish (hard to describe an odour) and if there is any hint of a burnt smell it should be changed and flushed.
Old 02-21-2018, 12:09 PM   #20
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
If it tastes sour then it's expired.
Current DD: M235i
8RZ is offline   Reply With Quote
Brake fluid change guybo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 02-08-2018 12:05 PM
How difficult is it to replace brake hard lines? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-27-2017 11:39 PM
When should you replace your iron brake discs? JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-14-2016 12:26 PM
brake rotor need replace? ZHoward Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 03-23-2016 03:11 PM
Brake Fluid Question... Lebby83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-02-2015 09:01 AM
