Old 02-20-2018, 01:56 PM   #1
D-rek07
When to replace brake fluid
After quite a bit of research, I cannot find when the actual time to change brake fluid. Everyone just says, "after 2 track days" or "every six months" or something like that. Is there a test or an analysis you can do to determine that it needs to be changed?
Thanks in advance
D-rek07 is offline   Reply With Quote
Old 02-20-2018, 02:04 PM   #2
Code Monkey
Drives: Subaru BRZ
Whenever the brake pedal gets squishy.
Code Monkey is offline   Reply With Quote
Old 02-20-2018, 02:07 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
"brake fluid test strips"
A bleed and topping off of fluid every 1-2x track days is cheap insurance, the strips to confirm that at least what's in the reservoir hasn't broken down.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
gtengr (02-20-2018), Sapphireho (02-20-2018), Spuds (02-20-2018)
Old 02-20-2018, 02:08 PM   #4
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
You can use a brake fluid moisture test kit. They come in strips or you can buy an electronic tester. It's sometimes hard to gauge how squishy your pedal can become over time... unless it's like right after a track day.
If you're not driving it too hard around every 30k is about right.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Spuds (02-20-2018)
Old 02-20-2018, 02:08 PM   #5
Take a look at it. It should be almost clear. If milky, rusty coloured, or blackish then it needs to be changed. It should smell sort of sweetish (hard to describe an odour) and if there is any hint of a burnt smell it should be changed and flushed.
Everybody drives differently so there is no hard and fast time limits or operating condition that says "change it now". Rules of thumb is the harder you drive the car the more often you need to check it.
Busybee (12-10-2020), Spuds (02-20-2018)
Old 02-20-2018, 02:16 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
If braking heatload has never been to squishy/fading brakes and to boiled fluid, imho it may last long enough, at least i'd change never boiled fluid at most once per year. But then again if track is mentioned .. it's easy to abuse brakes above their capacity . BTW, if you boil them often enough, maybe worth considering instead of frequent flushes change fluid to one with higher boiling temps / enhance cooling (eg. airducts) / reduce braking heat load (eg. shorter sessions / pedal dance instead of with nannies / braking lessons by hpde instructors ) .. or move to BBK.
strat61caster (02-20-2018), Tcoat (02-20-2018)
Old 02-20-2018, 02:31 PM   #7
CSG Mike
CSG Mike's Avatar
Thanks in advance
Squishy pedal? Change it. Fluid is not amber? Change it. 2 years old? Change it.
Or use Project Mu. Green turns clear if it absorbs too much moisture (aging), or turns brown if it gets too hot (tracking).
PM to order.
Don't forget to bleed your clutch pedal every 2 years too.
The Following 5 Users Say Thank You to CSG Mike For This Useful Post:
finch1750 (02-21-2018), humfrz (02-20-2018), Spuds (02-20-2018), Teseo (02-20-2018), wparsons (02-21-2018)
Old 02-20-2018, 03:45 PM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I switched to Motul at 30k, made a huge difference. It was easy to do and not all that expensive.
guybo is offline   Reply With Quote
Old 02-20-2018, 04:57 PM   #9
D-rek07
I track it about once every other month. I have heard about the moisture test strips but is there any other way to test it for being broken down? I'm not really even sure if brake fluid breaks down from heat cycling. I have three track sessions on my current brake fluid and bled them about 6 months ago. I have not noticed any decrease in pedal feel. I'm using Motul RBF600.
Old 02-20-2018, 05:25 PM   #10
CSG Mike
CSG Mike's Avatar
Test strips are the objective test. Pedal feel is the subjective test. There is no other way to test, unless your fluid has a provision to indicate moisture.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
gtengr (02-21-2018), strat61caster (02-20-2018), wparsons (02-21-2018)
Old 02-20-2018, 05:31 PM   #11
D-rek07
So moisture is the only thing harmful to brake fluid? It can't break down due to heat?
Old 02-20-2018, 06:08 PM   #12
CSG Mike
CSG Mike's Avatar
Fluid degredation from heat is an indicator that the *real* solution to your problem is to increase capacity with a well designed BBK.
Band-aid fixes include higher grade brake fluid.
Old 02-20-2018, 06:47 PM   #13
D-rek07
So either that or flushing brake fluid more often. I don't think a BBK is necessary for this lightweight car. I have no problem flushing brake fluid, I'm just trying to figure out how to determine that the fluid has degraded from heat.
Old 02-20-2018, 06:59 PM   #14
CSG Mike
CSG Mike's Avatar
How many pads do you have to burn up and how many times do you have to flush fluid, before you've covered the cost of a BBK and then some?
Why does Subaru now provide a factory Brembo setup if it's unnecessary?
Brake fluid change guybo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 02-08-2018 12:05 PM
How difficult is it to replace brake hard lines? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-27-2017 11:39 PM
When should you replace your iron brake discs? JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-14-2016 12:26 PM
brake rotor need replace? ZHoward Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 03-23-2016 03:11 PM
Brake Fluid Question... Lebby83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-02-2015 09:01 AM
