Old 02-20-2018, 11:22 AM   #15
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Maybe if you switched weekly for the lifetime of the car MAYBE you'd go through 650 gallons of fuel getting the tank low? You think?
guybo is offline   Reply With Quote
Old 02-20-2018, 01:02 PM   #16
Grady
Grady's Avatar
Gasoline is the cheep part of this equation.
Say you spend 45 min using up gas.
Average 50 mile an hour.
37.5 miles x wear and tear .55(Gov average) =$20.63. Gas would be around $4 of this
Time
If you would just work more than driving =$41.25(If you make 110K a year)
If you work at McDonalds =$11.25
If you drive instead of spending time with your family =Priceless.
Math comes up to just under 8 conversions to pay for the $500 kit on the first one.
Even the MacDonalds employee is under 16 Conversions.
Not picking on MacDonalds employees! Anyone that works and supports them self’s I have respect for!
Just rough numbers and estimates. You can adjust your time and values to whatever fits your situation. May make sense to you may not.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Cole (02-20-2018), Tcoat (02-20-2018)
Old 02-20-2018, 01:58 PM   #17
Riftur
Riftur's Avatar
I only make the change maybe once a year if? I kept it on e85 till the hurricane started coming toward us.
Riftur is offline   Reply With Quote
The Following User Says Thank You to Riftur For This Useful Post:
Tcoat (02-20-2018)
Old 02-20-2018, 01:59 PM   #18
Riftur
Riftur's Avatar
If I was switching back and forth all the time I would invest the money but that is not the case.
The Following 2 Users Say Thank You to Riftur For This Useful Post:
Spuds (02-20-2018), Tcoat (02-20-2018)
Old 02-20-2018, 02:02 PM   #19
Yep. For once a year in special circumstances the whole kit is maybe not the best option.
If switching back and forth weekly or between tanks the kit is. Would just take one time to forget to change the tune and your engine could be toast.
Riftur (02-20-2018)
Old 02-20-2018, 02:12 PM   #20
Grady
Grady's Avatar
Oh geese! You started this thread on what a pain it is and what can you do to make it easier. Now it no big deal you only switch once a year.
I am out!!!!!!
The Following User Says Thank You to Grady For This Useful Post:
Cole (02-20-2018)
Old 02-20-2018, 02:16 PM   #21
I am out!!!!!!
Rift is ok. He is still learning. At least he wants to actually learn!
Riftur (02-20-2018)
Old 02-20-2018, 03:14 PM   #22
Riftur
Riftur's Avatar
I am out!!!!!!
If I remember correctly I asked a very specific question about siphoning gas to make it easier. Everyone else went into all kinds of other stuff. That is not my fault. I stated a reason for it and asked for an opinion since there is no info I found when searching around.
Old 02-20-2018, 03:23 PM   #23
So it is really a pain for me to switch and I am trying to make it easier. Since there is only 1 station around me that has e85 and most of my driving is going to work and home. usually i drive as many time as possible back and forth to work. each day uses just under 1/4 a tank and then I have to drive around to just waste gas to get it a low as possible. So i was thinking of buying a siphoning pump and would like peoples opinions. DO you think the below pump would work well and is worth it? It will need a 5 gallon tank.
https://www.amazon.com/gp/product/B0...LI6HNLMP&psc=1
Well Rift the way you wrote it does make it sound like you do it all the time!
Cole (02-20-2018)
Old 02-20-2018, 03:34 PM   #24
Cole
Not a troll
Cole's Avatar
It seemed like it was a weekly occurrence the way it was worded.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Tcoat (02-20-2018)
Old 02-20-2018, 03:36 PM   #25
Well, if I recall correctly, for a while there last year hurricanes were about a weekly occurrence.
Cole (02-20-2018)
Old 02-20-2018, 03:37 PM   #26
guybo
Huge E85 fan!
guybo's Avatar
Thumbs down
Time
1) my entire life is not working. I converted on my off time. I lost no money due to lot working. That's a dumb part of the equation.
2) I converted when I already needed gas. I think I may have driven an extra 5 miles (I took the opportunity to do a couple 0-60 runs to compare)
IT took me very little time and almost no extra money. Your example is pretty much retarded because someone would have to be a moron to do what you did there. Fail
Old 02-20-2018, 03:41 PM   #27
Riftur
Riftur's Avatar
I just wanted to know if anyone siphoned gas doing the switch to e85 and if the product I was looking at would work. I can not believe this thread is still going honestly.
Old 02-20-2018, 03:44 PM   #28
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
OP, if you consider driving around to use 1/4 tank "to just waste gas", perhaps you "bought the wrong car". Surely there is some stretch of road even if FL that would be a fun way to "waste gas".
PetrolioBenzina is offline   Reply With Quote
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch BII302 Engine, Exhaust, Bolt-Ons 6 04-13-2015 07:06 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
Which is easier? FRS front or BRZ headlights? huma Cosmetic Modification (Interior/Exterior/Lighting) 26 06-23-2012 05:00 AM
i'm leaning toward BRZ but will it be easier to get a FR-S? stlgrym3 BRZ First-Gen (2012+) — General Topics 28 03-30-2012 01:07 PM
Wouldn't it be easier... LexusFman Scion FR-S / Toyota 86 GT86 General Forum 50 03-31-2011 11:55 PM
