Old 02-06-2018, 05:30 AM   #1
Riftur
Riftur's Avatar
Switch from 93 to e85 easier
So it is really a pain for me to switch and I am trying to make it easier. Since there is only 1 station around me that has e85 and most of my driving is going to work and home. usually i drive as many time as possible back and forth to work. each day uses just under 1/4 a tank and then I have to drive around to just waste gas to get it a low as possible. So i was thinking of buying a siphoning pump and would like peoples opinions. DO you think the below pump would work well and is worth it? It will need a 5 gallon tank.
https://www.amazon.com/gp/product/B0...LI6HNLMP&psc=1
Riftur is offline   Reply With Quote
Old 02-06-2018, 08:03 AM   #2
jasonojordan
Drives: 2013 satin white brz limited
Why not just buy an ethanol module like the one that delicious sells and the corresponding tune and be done with it?
Then you can run what ever gas (with in reason) that your happy ass wants to and not have to worry about trying to run it nearly empty and messing around with tune swaping.
jasonojordan is offline   Reply With Quote
Old 02-06-2018, 08:08 AM   #3
WNDSRFR
Drives: FR-S,GTI
Before you spend your hard earned cash, I would try inserting a tube into the gas tank and see if it is possible.
I had a plan one time to fill up the tank on my Saturn and siphon it out to use during a hurricane for a generator.
But, alas, It was impossible to get the hose to the tank because of obstructions and bends etc. So I went without power until the gas stations got replenished.
Old 02-06-2018, 08:16 AM   #4
Riftur
Riftur's Avatar
Good idea, didnt even think about that.
Old 02-06-2018, 10:51 PM   #5
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
You are in FL, why not just run E85 all the time? Why bother switching unless you are going long distance?
Jeez, a tank week commuting, no thanks.
PetrolioBenzina is offline   Reply With Quote
Old 02-07-2018, 06:56 AM   #6
Riftur
Riftur's Avatar
I had to make the switch back for a few reason. The biggest one was the hurricane we had and not able to find e85 since there is only 2 stations in my area that sell it.
Old 02-07-2018, 06:48 PM   #7
Grady
Grady's Avatar
Time is money, buy a flex fuel kit. Cheaper in the long run.
The Following 3 Users Say Thank You to Grady For This Useful Post:
Chimera (02-20-2018), FRSBRZGT86FAN (02-20-2018), Hades (02-21-2018)
Old 02-19-2018, 09:55 PM   #8
Harey
Drives: 2013 Toyota 86
Flex fuel or fill up jerry cans when you fill up the tank.
Sucks that it is a pain in the butt to drain the fuel from this tank.
Harey is offline   Reply With Quote
Old 02-20-2018, 05:20 AM   #9
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I love how people are always like " why not just drop the $1500 for the full flex fuel kit?" like we all have $1500 just sitting around. So what if you have to spend a few extra minutes to convert one way or the other, it's a hell of a lot cheaper than getting a flex fuel kit.
@Riftur how often do you switch back and forth?
Old 02-20-2018, 06:57 AM   #10
They say it because it is the proper way to do it. Sure you can work around it by switching back and forth but since this thread exists at all there are obviously issues with that method. If $1500 is too much to do things the right way when your whole engine is at risk you probably shouldn't be doing it at all.
Cole (02-20-2018), finch1750 (02-20-2018), Hades (02-21-2018), sodjer (02-20-2018)
Old 02-20-2018, 07:45 AM   #11
Riftur
Riftur's Avatar
Not very often at all. Thats why i have no need for the flex fuel kit. I use the OFT and it works great.
The Following 2 Users Say Thank You to Riftur For This Useful Post:
guybo (02-20-2018), Tcoat (02-20-2018)
Old 02-20-2018, 08:06 AM   #12
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
What's the mechanism that balances out the two lines in the tank? I know it's been discussed, but I don't remember whether it needed power in the pump or not. OP might want to take a look at that.
Old 02-20-2018, 08:07 AM   #13
Grady
Grady's Avatar
Sometimes spending money up front is cheaper in the long run. You stated you drive around and waste gas just to switch over. How much does that cost you? Wear and tear, extra gas, TIME, and increasing you chances of an accident. Put a value on all that stuff and add it up over the life of the vehicle. If it comes up to more than $1500 then yes it will be better to get the kit, if not you are good.
Cole (02-20-2018), Hades (02-21-2018), Tcoat (02-20-2018)
Old 02-20-2018, 11:19 AM   #14
Cole
Not a troll
Cole's Avatar
Uhm, no. It's not $1500. Maybe don't talk about things that you're clueless about?
Hell, options galore from reputable vendors
It took me a long time to realize that time truly is money.
In this case, I'd certainly be ok with spending the money on a Flex Fuel kit, vs farting around every time I need/want to switch.
The Following 3 Users Say Thank You to Cole For This Useful Post:
finch1750 (02-20-2018), FRSBRZGT86FAN (02-20-2018), Tcoat (02-20-2018)
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch BII302 Engine, Exhaust, Bolt-Ons 6 04-13-2015 07:06 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
Which is easier? FRS front or BRZ headlights? huma Cosmetic Modification (Interior/Exterior/Lighting) 26 06-23-2012 05:00 AM
i'm leaning toward BRZ but will it be easier to get a FR-S? stlgrym3 BRZ First-Gen (2012+) — General Topics 28 03-30-2012 01:07 PM
Wouldn't it be easier... LexusFman Scion FR-S / Toyota 86 GT86 General Forum 50 03-31-2011 11:55 PM
