Old 01-19-2018, 06:07 PM   #57
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by wsites View Post
Yet plenty of OEMs offer drilled brake discs.. Porsche offers them on the GT3 RS, Ferrari on the 488 GTB, so on and so forth... So maybe this can be an issue with poorly designed/manufactured discs but I'm having a hard time believing it's as prolific an issue as you claim... ¯\_(ツ)_/¯
The materials used for the brake rotors on those cars (carbon ceramic) are not comparable to the iron rotors we will use on our cars so drilling them doesn't have the same effect.
For track driving, the drilled vs non-drilled argument mostly comes down to economics if you ask me. You can run a set of iron rotors that cost you $200 per set or you can run the fancy, expensive carbon ceramics that cost you $2000 per set. People who can afford the likes of a the GT3 RS or the 488 can also afford the expensive rotors.
It's not inherently unsafe to run drilled disks but people who track their cars wear though consumables very fast and "shits expensive yo" so we want to get the most bang for our buck. Not only are drilled and slotted more expensive than blanks but drilled rotors in particular will require replacement sooner than just slotted or blank. Over a year, it might only be $100 difference but over 5 years, that ads up to $500 and you could buy a header with that money... or more track time.. or other consumables...
Lynxis is offline
Old 01-19-2018, 11:55 PM   #58
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Originally Posted by cjd View Post
Yes. I posted a picture somewhere ^, like 6 posts before you asked.
lol obviously I looked closely.
BlaineWasHere is offline
Old 01-26-2018, 12:34 PM   #59
paintdude258
paintdude258's Avatar
I read through this whole thread, but I didnt see my wheels specifically.
Will this kit fit RPF1s 18x9.5 +38?
paintdude258 is offline
Old 01-30-2018, 12:16 PM   #60
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Originally Posted by orz View Post
So, 17x8.0 +45 Enkei RPF1 clear OE brembo's, but 17x9.0 +35 dont? I'm confused
the 17x9 are horrible for caliper clearance. They use a design trick to keep weight down. The barrel is from a 16" wheel thats tapered out. The spokes are from the 17' +35 wheel which has a flat face for the brakes. The combination of the two means the 17x9+35 RPF1 suck for BBK.
mjanmohammad is offline
Old 02-15-2018, 11:24 AM   #61
Greenbean
Drives: 2017 series yellow BRZ
Enkei Raijin 18x9.5 +45 fitment
I am running fortune auto coilovers but does anyone know if the 18x9.5 +45 enkei raijin squared setup will clear the pp bbk's because these are my favorite wheels right now and do not want to waste money. Thanks
Greenbean is offline
Old 02-15-2018, 11:25 AM   #62
mjanmohammad
Originally Posted by Greenbean View Post
I am running fortune auto coilovers but does anyone know if the 18x9.5 +45 squared setup will clear the pp bbk's because these are my favorite wheels right now and do not want to waste money. Thanks
For which wheel?
Old 02-15-2018, 11:28 AM   #63
Greenbean
Originally Posted by mjanmohammad View Post
For which wheel?
Old 02-15-2018, 11:29 AM   #64
mjanmohammad
I know the 18x8 clears without a problem. I can’t imagine the 9.5 wouldn’t but I would call Enkei and confirm with them.
Old 02-15-2018, 11:31 AM   #65
Greenbean
Why would you believe it wouldnt just wondering becuase i know the 8.5 fits but i want the squared setup, but do the rpf1 18x9.5 +38 clear? I appreciate the help
Old 02-15-2018, 11:34 AM   #66
mjanmohammad
I'm not sure about the 18x9.5 RPF1. In the 17x9 the RPF1s don't clear the brembos at all, but do in the 17x8. It depends on the facing of the calipers. Sometimes the wider wheels need more strength so the calipers are thicker to compensate. That means they sometimes don't clear BBK.
The 18x8 squared setup in the Raijins clear the Brembos. Unless you have FI, you really don't need to be wider than that.
Old 02-15-2018, 11:47 AM   #67
mjanmohammad
Planning are going forced induction with the sprintex 210 twin screw.
Call Enkei and confirm the 9.5s fit then, we don't know very much more than you do here.
Old 02-15-2018, 12:07 PM   #68
Greenbean
I messaged enkei and the 18x9.5 +45 does not clear the front brake caliper but a 18x8.5+45 will
Old 02-16-2018, 01:35 PM   #69
Greenbean
wheel fitment question
i think option labs r716 18x9.5 +35 will fit the bbks but can anyone confirm this?
Old 02-16-2018, 05:12 PM   #70
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Anyone know if the SA10R 18x8.5+45 would clear or not?
Never mind, it clears!
botbs is offline
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 09:36 AM
Real STI BREMBO package upgrade - DIY Trap63 DIY (Do-It-Yourself) Guides 40 06-15-2022 09:25 PM
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue DaJo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-25-2018 05:12 PM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 10:04 PM
Someone tested the Performance Package... small but SOME info at least ~el~jefe~ BRZ First-Gen (2012+) — General Topics 13 11-29-2016 04:21 PM
