#57 |
Still a drivers side and a passenger side.
#58 |
#59 |
#60 |
From the OP's other threads it looks like he was doing the work himself so odds are it has not been anyplace near a body alignment rack yet. Can align the wheels all they want it won't matter if there is some twist to the body. If the A pillar was bent as stated then there is very likely some twist someplace.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Riftur (02-10-2018), Summerwolf (02-10-2018) |
#62 | |
........ take your car here:https://www.facebook.com/Bakersfield...2384752474766/ .......and buy 4 new tires and let them install them AND check the frame and suspension on your car and align it. There ya go ....... problem solved ....... humfrz |
#63 |
Panda Trueno
Drives: No twin now.
#64 |
Drives: 2014 brz limited
Im not qualified to do that most likely ill just wait and change the tires anyway if that doesn't work then ill go from there. Just to clarity just the alignment numbers i provided wouldn't cause the car to behave like this right? Not talking about frame measurements but alignment measurements. If the cars frame was intact would my alignment numbers cause whay im experiencing.
#65 | |
#66 | |
Panda Trueno
New tires alone probably won't be your fix. Jack the car up, visually inspect for anything bent, pop your hood and check the strut towers. Throwing money and parts at the vehicle until you fix it is more hassle then just figuring out the problem and the correct fix. I think a body shop will check the vehicle on a frame rack for less than a new set of decent tires. |
| The Following User Says Thank You to Summerwolf For This Useful Post: | Spuds (02-10-2018) |
#67 |
Thought I'd throw this out since it's in a similar vein. Just in the last couple months, I've started having the Traction Control kick on during sweeping, high speed curves like entrance or exit ramps. It has never done this before.
It's not an actual loss of traction, it's like something in the rear grabs. It doesn't feel like a brake though (which it should be doing all the time if that's the case, and there's no burnt brake smell), and it's under steady power or even coasting - but not lift-off in the corner, more like off the gas before entering. I have new tires (it was doing it before and after tires). I also just had an alignment done which appeared to help a bit. Before it happened in the forties, now it happens in the fifties. Otherwise, the car continues to drive straight, doesn't pull, no unusual tire wear, no vibration. And again, it's not just a plain old traction loss because it's happening on ramps I regularly did at 70+ with no drama. It also doesn't appear to happen at low speed. Is it possible for the Torsen LSD to go bad or get damaged and do something like this? Just spitballin' here. |
#68 | |
#69 | |
Not sure why you are so dead set against having the body checked but maybe you just simply still do not understand what the problem could be. The car was written off in the first place because it would cost too much to repair so somebody someplace probably knew the frame was out. The doors, fenders, hood, etc can be bent and not cause any issues with the structure. If the A pillar is damaged it can throw off the whole body alignment. It is structural part of the car. Look at the picture below. That is the structural uni-body or "frame" of the car. See how the A pillar is tied directly to the front structure that holds the suspension? ![]() If that pillar is bent that pressure extends through the rest and throws them out of alignment. A body shop will use special equipment to see that everything is in alignment. You can measure yourself but you need to be very precise in the measurements. You can not just look and say "ya it all looks good" http://what-when-how.com/automobile/...rs-automobile/
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#70 | |
| Car swaying left right (floating feeling) highway speeds | FX86 | Issues | Warranty | Recalls / TSB | 37 | 05-30-2021 11:48 AM |
| Hood lift at high speeds | Basti | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 97 | 02-15-2016 03:50 PM |
| weird issue at high speeds after OFT tune | dejxx | Software Tuning | 24 | 08-10-2014 09:49 PM |
| feeling a sway on the rear end | qganja | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-25-2013 03:56 PM |
| High pitch sound at freeway speeds | l0aded | Issues | Warranty | Recalls / TSB | 7 | 06-14-2013 05:25 AM |
