Old 02-08-2018, 01:12 PM   #1
CoolHandMoss
Drives: 2013 FRS
DIY oil cooler mounting.
I know plenty of people have done DIY oil cooler installs without using a kit. I'm wondering if anyone has any pictures or general advise for mounting the oil cooler without the pre-made brackets. I don't imagine it will be too terribly difficult but it would be nice to see what others have done and what has worked or hasn't worked. Has anyone tried any ducting to increase airflow through the cooler?
CoolHandMoss is offline   Reply With Quote
Old 02-08-2018, 01:22 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I had a custom one done. It sat behind the passenger side fog light. Held in place to the bumper beam, very similar to the FBM location. Did not duct it. If I can find a picture I'll attach it later.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Teseo (02-08-2018)
Old 02-08-2018, 01:38 PM   #3
Ol @Ultramaroon installed an oil cooler ...... I don't know if it was a kit or not.
I'll summon him up for you ......
Old 02-08-2018, 01:56 PM   #4
CoolHandMoss
Drives: 2013 FRS
I'm definitely going in front of the radiator for this one. It will be mounted on the plastic tray thing. I'm mostly curious how is good to month it on that and how much to brace it on the bumper. I've seen a couple examples but none that made me feel really onfident that was the way to do it.
Old 02-08-2018, 02:07 PM   #5
DAEMANO
Time Traveller
Problem with that plastic tray is that it's hardly reinforced but in a place where it could be damaged if you run over something. Attaching a hot lubricant line and radiator directly to that could result in a dry engine if the plastic tray (and the attached radiator) gets torn off. Makes people nervous. I'd look for another location and a metal bracket that attaches your oil cooler radiator to a hardpoint or protected area and not just the plastic tray.
Old 02-08-2018, 02:09 PM   #6
redlined600
redlined600's Avatar
Drives: Fr-s
I can't manipulate images from work but if you go to this post one can see how I mounted mine. I specifically didn't want it mounted to the plastic part. I used rivnuts in the bumper beam.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
Teseo (02-08-2018)
Old 02-08-2018, 02:39 PM   #7
Teseo
Drives: frs
You gave me an idea for a "V" mount
Old 02-08-2018, 07:18 PM   #8
CoolHandMoss
Drives: 2013 FRS
That looks really good. I like the idea of mounting it to the bumper for stability. I'd have to mount it a little lower though because I'm determined to use 45* fittings rather than 90's.
Old 02-08-2018, 08:55 PM   #9
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Here's mine
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
Teseo (02-11-2018)
Old 02-09-2018, 01:17 AM   #10
No kit. Mine is a huge one-off. 72-row series-1 Setrab mounted directly to the cooler stack. It works as designed but took some doing. It's not plug-and-play by a long shot.
Code Monkey (02-09-2018), humfrz (02-09-2018), Teseo (02-11-2018)
Old 02-09-2018, 09:37 AM   #11
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by Lunatic View Post
Here's mine
@Lunatic, with the front bumper cover off, it almost looks like there should be a guy playing a flame-shooting electric guitar strapped to the front of your car...
shiumai is offline   Reply With Quote
Old 02-09-2018, 10:39 AM   #12
Lunatic
Lunatic's Avatar
That would work!
shiumai (02-09-2018)
WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler TheMedakaBox Northern California 4 08-09-2017 10:16 PM
Mounting OFT? JDsThatGuy Software Tuning 3 04-09-2015 10:49 PM
DIY - OFT Mounting Solution 1Cor10:23 DIY (Do-It-Yourself) Guides 7 12-26-2014 03:42 PM
Another Oil Cooler Mounting Option FastJew Tracking / Autocross / HPDE / Drifting 12 05-18-2014 09:13 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
