Old 02-07-2018, 01:15 PM   #15
gravitylover
Well they replaced it yesterday and the paperwork says it was due to the U-joint going bad not the bearing like I was originally told. It sure did feel better driving home last night, much tighter than it has been for a while. Also the knock that was happening when I hit sharp edged bumps that I thought was suspension or control arms is gone so that's good. Unfortunately there's still a creak but it's nothing like it was and I can't feel it through the wheel or floor/pedals like before. Snow day today so the car is sitting in the driveway, I'll get it out for a little road trip tomorrow so hopefully it will settle in and the noise goes away.
The tech said the TOB wasn't making any noise but he did get some grease on the shifting fork and squirted some lube in the port on top of the tranny with a hose, he said it should have gotten down to about where the TOB is and hopefully it quiets things down for me. I'm not holding my breath but it's documented now that it has a problem and apparently my extended warranty goes to 100k from the point I got the car not 100k overall so I have another ~19k until it ends. The service adviser said he thinks I could probably get it covered so we'll see...
Old 02-07-2018, 01:59 PM   #16
Squirting some lube down onto the bearing won't do a thing. The lube that fails is sealed inside the bearing.
humfrz (02-07-2018)
Old 02-07-2018, 02:34 PM   #17
jasonojordan
Drives: 2013 satin white brz limited
My brz has had a groan/creek when turning since nearly new. Never any weird feedback just noisy. You only hear the noise at very low speeds. If you turn sharply at a reasonable speed no groan or creek.
jasonojordan is offline   Reply With Quote
Old 02-07-2018, 06:18 PM   #18
gravitylover
That's what I tried to say but the tech decided to do it anyway because "he knows better" than me. He also said that it's most likely just because some moisture got in there and freezes which is why it only squeals when it's cold.
Old 02-07-2018, 06:20 PM   #19
gravitylover
Mine was happening at all speeds, mostly low but I took a tight corner (with a bit of a drift) at about 70 a couple of weeks ago and felt it through the pedals and it got almost sticky in my hands. Scared me silly so I brought it in the next day.
Old 03-30-2018, 09:37 AM   #20
gravitylover
The 'fix' didn't solve the problem and the noise came back just as loudly as before so I brought the car in again yesterday. This time the tech thinks it's because the steering wheel is bent slightly and rubbing causing friction. They are ordering a new wheel and it's going back in for that to be replaced next week. I'm not confident that's the solution but we'll see.
It's also developed a crackling noise in the front end at low speeds when the wheel is turned slightly on rough pavement. They're not sure what's going on so I have to go for a ride with a tech when I bring the car back so he can listen while I drive.
Good thing I have the 7/100 Gold Plan that came with the CPO purchase and the car is still (slightly) under that 100k mark. This stuff would be terribly expensive to deal with otherwise.
The Following 2 Users Say Thank You to gravitylover For This Useful Post:
humfrz (03-30-2018), Ultramaroon (03-30-2018)
Old 03-30-2018, 01:47 PM   #21
The 'fix' didn't solve the problem and the noise came back just as loudly as before ..........
Well, I reckon if they throw enough parts at it ....... it will eventually get fixed .....
gravitylover (03-30-2018)
Old 03-30-2018, 02:31 PM   #22
Decep
Drives: 2013 FR-S Series 10
I had a groan in my steering whenever doing low speed parking maneuvers that lasted for a week or two. when i took it in to a subaru shop nearby it of course disappeared and i havent heard it for a couple months.
Old 04-05-2018, 02:00 PM   #23
kevman_101
Drives: 2013 Scion FRS
I had a creek and vibration as well. They lubed the seal where the steering shaft goes through the firewall and all is good now.
kevman_101 is offline   Reply With Quote
Old 04-10-2018, 11:43 AM   #24
gravitylover
New steering wheel is in and the noise is gone now I guess they threw enough parts at it The tech came out to talk t me after it was done and said that I should be more careful getting into the car and not hold onto the wheel as I sit down because it bends it from the base. I tried to explain that because I'm old, fat and short I have to plop my butt down first then just rotate in without ever touching the wheel but at 6'4" he just couldn't understand. The wheel was slightly torqued when I got the car though and it always rubbed a bit but didn't make the groaning noise until recently. Maybe the original owner was a road rager that beat on the wheel and was a big dude that tweaked it getting in and out
I didn't get the car new (14k CPO) so I didn't know what the wheel felt like when it was new and didn't notice the degradation over the last 81k miles since I got it. The texture is nice and the stitching color is vibrant
The Following User Says Thank You to gravitylover For This Useful Post:
humfrz (04-10-2018)
Old 04-10-2018, 09:42 PM   #25
Are you sure it was the steering wheel ...."groaning" ........
Old 04-11-2018, 09:56 PM   #26
gravitylover
Not as old as you Not fat like, well, just sorta carrying a small spare tire around the middle and short of stature but large of character
humfrz (04-11-2018)
Groan and Creaky Front Suspension??? jadewbj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-11-2019 01:19 PM
Clutch squeak, grind, groan TSB released. Kicker18 Issues | Warranty | Recalls / TSB 153 10-01-2019 12:50 AM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
