Old 02-05-2018, 04:51 PM   #1
Sonder
Drives: '17 BRZ w/ PP || MBTA
Brake groan. '17 BRZ w/ PP
I've noticed a groaning sound emanating from my brakes recently. It's most noticeable when I've just started driving. The noise seems to lessen if I'm at the end of my drive. There doesn't seem to be any change in how they work though.
I have a little over 5k miles on the car. The brakes are the stock Brembo brakes that are included with the performance package.
Any idea what could be causing the noise? Surface rust? Something is caught? Something is misaligned? The weather? I live in Boston in case that matters.
Should I just take it to a shop? Any reason to worry at all?
Video w/ sound: https://streamable.com/svfmx
Sonder is offline   Reply With Quote
Old 02-05-2018, 05:08 PM   #2
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Sounds are notoriously difficult to describe, and even more difficult to diagnose based on those descriptions alone. A 30 second listen can tell more than a whole thread's worth of writing. Where in Boston are you?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 02-05-2018, 05:22 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
It's still under warranty; take it to the dealer.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
D_Thissen (02-05-2018), humfrz (02-06-2018)
Old 02-05-2018, 06:21 PM   #4
D_Thissen
D_Thissen's Avatar
This x100.
Old 02-06-2018, 09:18 AM   #5
Sonder
I live in Cambridge near Davis Square.
It sounded better today :/ Not sure if you can even hear that well in the clip. The sound is most noticeable right before I come to a complete stop.
Yesterday it was much worse on that same first stop.
Leads me to think it's partly weather related.
Old 02-06-2018, 09:26 AM   #6
venturaII
venturaII's Avatar
The best thing you can do is get someone knowledgeable to take a ride with you and listen. You can usually figure it out by the end of the block.
I've noticed that these rotors will rust pretty quickly when parked...my car will typically stay parked for the weekend and by Monday morning, the first brake application is quite grumbly. It cleans up quickly though.
Groan and Creaky Front Suspension??? jadewbj Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-11-2019 02:19 PM
Clutch squeak, grind, groan TSB released. Kicker18 Issues | Warranty | Recalls / TSB 153 10-01-2019 01:50 AM
Steering groan gravitylover Issues | Warranty | Recalls / TSB 25 04-11-2018 10:56 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
