Old 01-26-2018, 01:17 PM   #15
Racecomp Engineering
Originally Posted by TLD View Post
Thanks Andrew, my previous owner already have camber plate installed. In your opinion I should revert back to stock top hat? Or just keep them? I'm not upset because of my current setup is harsh, I just don't like how it jumps and that might potentially lead to loss of traction.
Camber plates are usually felt on sharp edged bumps. It sounds like poor rebound damping is the major factor for you, but the camber plates aren't helping. I would just recommend that you use stock top hats with whatever set up you move to in the future.
- Andrew
Old 01-26-2018, 01:23 PM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
RCE Yellows and B6 is awesome. Shipping a set of springs to Hong Kong is expensive though.
But yes I recommend RCE Yellow and B6. I will likely eventually do that on my own personal car. The B8s don't give any real advantage.
- Andrew
Been thinking about this... Is there any advantage to using the B8s over B6s with springs that are lower than the RCE Yellows? Thank you.
I LIKE TIRES!
Old 01-27-2018, 01:18 PM   #17
TLD
Drives: GT86
- Andrew
Thanks man, this is really helpful.
TLD is offline   Reply With Quote
The Following User Says Thank You to TLD For This Useful Post:
Racecomp Engineering (01-28-2018)
Old 01-28-2018, 05:32 PM   #18
Very little advantage to B8s. No change in valving, same bump travel, less droop travel. They might have a different internal bumpstop though.
- andrew
Leonardo (01-28-2018)
Old 01-29-2018, 01:29 AM   #19
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Thanks everyone for the replies. I'm really sorry that I forgot to mention my budget. But car parts price in Hong Kong is quite different to US/Europe, so my USD2k might not get me the same thing as you can (I think a new set of KW v3 is close to USD3k here). But I'd think in US terms, something ~USD1.5-2k.
I've heard some good words about TEINS, but which model and which spring rate?
Sadly I'm not part of the HK GT86 Club. If you have connections please let them know there's a stranded GT86 owner here in Hong Kong and would like to join their events. And maybe ride with some of their cars so I can feel which suspension I like the most.
Our CSG Spec Flex A are $1400 and will be coming into stock in April. It comes with the pillowball top hats and front camber plates. You can probably check out their GT86 FB page. We can discuss more over PM!
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
RL_BRZ (01-31-2018)
Old 01-29-2018, 02:44 AM   #20
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If you want some feedback based on first hand experience I went from coilovers that had plates to coils that use OEM and am extremely happy. I can still get more then -3 camber thanks to slotted struts and camber bolts so there is plenty of adjustment still. Mine was the same thing with harsh valving so changing to a quality coil with good valving helped a lot but the OEM rubber top hats make a difference as well.
Old 01-29-2018, 03:06 AM   #21
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Azzudien View Post
Why not just get a stock suspension? Sure you could get relatively cheap from someone on these forums that has upgraded suspension for the track.
Seems that would solve most of your issues, and since you do not track is there really a need for more?
This is quite a relevant option.
Old 01-30-2018, 01:32 AM   #22
TLD
Drives: GT86
Thanks mate, that's really helpful.
From all your comment seems going back to stock is a good option for me. I'll see if I can get a used set of stock suspensions. But some of you already know it is not that easy here in Hong Kong.
Old 01-30-2018, 03:51 AM   #23
Captain Snooze
Drives: Red Herring
Story time.
I had after market dampers fitted to my car very soon after purchase 5 years ago. About 6 months ago I had oem suspension put back on the car while the after market dampers were being serviced. I was pleasantly surprised at how good I found the oem units and I am not the only one on these forums who thinks so.
If you can find them I think the oem dampers would meet your criteria.
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
CSG Mike (01-30-2018), Tcoat (01-30-2018), why? (02-23-2019)
Old 01-30-2018, 10:27 AM   #24
Story time.
Yep. As I have said before and will say again a lot of the hate for OEM parts (including suspension) is simply because they are OEM. The mindset that aftermarket is always "better" or an "upgrade" can be misguided. There are a lot of aftermarket parts out there that are crap and blown right out of the water by the OEM stuff.
Busybee (04-17-2020), CSG Mike (01-30-2018), new2subaru (02-23-2019), strat61caster (01-30-2018), Teseo (01-30-2018), why? (02-23-2019)
Old 01-30-2018, 11:17 AM   #25
finch1750
finch1750's Avatar
Story time.
A local guy reverted his car back to stock before selling it and said the same thing. And he had Ohlins
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
CSG Mike (01-30-2018), strat61caster (01-30-2018)
Old 01-30-2018, 11:29 AM   #26
Azzudien
Drives: 2017 Series Yellow BRZ
Suggest you just have someone in the states ship to you. You could buy a used OEM suspension on this forum, pay for shipping and still be 1/3 of the cost of aftermarket.
Azzudien is offline   Reply With Quote
Old 01-30-2018, 10:27 PM   #27
TLD
Drives: GT86
Story time.
Thanks for the suggestions. I'm looking into OEM suspension now. Another question: does the BRZ suspension fit the 2012 86? or does the 2017 model fit the 2012? Thanks.
I'm checking out the sells posts. Hope to find some good deal there!
Old 01-30-2018, 10:31 PM   #28
finch1750
finch1750's Avatar
They all fit. Just different spring rates between them all. And the 2015+ shocks are better valving then the MY12-14 supposedly.
strat61caster (01-31-2018)
Suspension upgrade Jmk91 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-14-2016 12:55 AM
Recommendations for plug and play speaker upgrade? irocz0r Electronics | Audio | NAV | Infotainment 10 09-07-2016 02:32 AM
Brake Pads Upgrade - Shop Recommendations in OC? KelvinBRZ Southern California 8 12-03-2015 03:49 PM
Recommendations for Suspension Mods Seth Hawkins Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-28-2015 12:20 PM
Pondering audio upgrade options; have questions, want recommendations SilverlightPony Electronics | Audio | NAV | Infotainment 17 05-11-2014 05:38 AM
