Old 01-25-2018, 12:06 AM   #1
TLD
Drives: GT86
Suspension upgrade recommendations
I'm looking to upgrade my suspension, the thing is, my current suspension (BC racing) on my 86 was installed by previous owner, and I have no idea what the spring rate is. I've done alignment after I bought the car, ride height is now at stock and I intend to keep it that way because where I park has a very steep drive way, and my car is the sport plus or areo package which has a longer and lower front bumper. I can get away with maybe 0.5" drop though.
The problem I have with my current suspension is that it takes high frequency bumps very violently, and the tires often lifts off the ground (not literally, but you can feel the weight lifted off the wheel). It has 30 steps damper adjustability but I believe that only affect low frequency bumps.
I have rode with my friend in a MINI with KW v3 suspension and I instantly notice the difference and think my suspension is crap. But I know different car reacts with suspension differently, so I'm not sure if KW v3 is the answer.
I do not do track days (there ain't no tracks here), only back roads. So, any recommendations? Thanks and sorry for the long post.
TLD is offline   Reply With Quote
Old 01-25-2018, 02:53 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You might like to give a budget.
Old 01-25-2018, 04:20 AM   #3
cyin86x
Drives: Rocket Bunny V3
If you're not into tracking, then I'd personally recommend against the KW V3 because of the cost. Those are for the guys who are hardcore track junkies that want to fine tune their suspension at the track and also they set it up differently depending upon which track they go to that weekend.
I know that because many of my friends who are track guys go through that all the time. Adjustable rebound, compression, and etc. I think thats overkill for the streets.
In my opinion, I think Tein is a pretty good option for the streets since I've had their coils in the past. Pretty affordable too. Now if you aren't really working with a budget and want the best, the KW V3 is one of the best. Maybe if you were to tell me what budget you were working with, I can give you more proper advice.
cyin86x is offline   Reply With Quote
Old 01-25-2018, 05:35 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
"Now if you aren't really working with a budget and want the best, the KW V3 is one of the best."
It's mid. There are Penskes after all too
The Following User Says Thank You to churchx For This Useful Post:
why? (02-23-2019)
Old 01-25-2018, 06:41 AM   #5
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
These Teins have me really interested and not just for the price point, but for who's been developing them-
http://counterspacegarage.com/tein-f...-toyota86.html
Also, KW V3s are top quality but infinite adjustability is pointless on the street. Ohlins Road & Track coilovers would be another brand to research, both go for about $2K USD.
JSube is offline   Reply With Quote
Old 01-25-2018, 10:50 AM   #6
Racecomp Engineering
The new "soft" Ohlins would work well for you. I would pair with upgraded swaybars since they are really soft.
Standard "soft" KW V3 also ride really well if you spend a little time with the adjusters.
Bilstein B6 shocks with stock springs or STI springs (mild 15mm drop) is another idea.
In general I would avoid anything that comes with camber plates.
- Andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
strat61caster (01-25-2018), Teseo (01-25-2018), turbocat (01-25-2018), Vic4uf (02-09-2018), why? (02-23-2019)
Old 01-25-2018, 11:05 AM   #7
Vital
Drives: 2015 BRZ
- Andrew
What about RCE Yellows and B6 would that work? Or is it better to get B8 dampers?
Vital is offline   Reply With Quote
Old 01-25-2018, 11:21 AM   #8
RCE Yellows and B6 is awesome. Shipping a set of springs to Hong Kong is expensive though.
But yes I recommend RCE Yellow and B6. I will likely eventually do that on my own personal car. The B8s don't give any real advantage.
- Andrew
jmark (01-30-2018), Leonardo (01-25-2018), Teseo (01-25-2018), Vital (01-25-2018), why? (02-23-2019)
Old 01-25-2018, 11:48 AM   #9
Azzudien
Drives: 2017 Series Yellow BRZ
Why not just get a stock suspension? Sure you could get relatively cheap from someone on these forums that has upgraded suspension for the track.
Seems that would solve most of your issues, and since you do not track is there really a need for more?
Azzudien is offline   Reply With Quote
The Following 2 Users Say Thank You to Azzudien For This Useful Post:
Captain Snooze (01-29-2018), yberther (01-25-2018)
Old 01-25-2018, 12:27 PM   #10
arkanist
Drives: 2016 BRZ Limited, Stock
- Andrew
Why avoid the ones with camber plates?
arkanist is offline   Reply With Quote
Old 01-25-2018, 12:31 PM   #11
If he's not doing track days and his primary concern is ride quality, camber plates will only make things worse compared to the OEM top mount. Camber plates do have an effect on ride quality that can be fairly noticeable.
He can still get camber with a camber bolt or in the case of KWs, the lower mount is slotted for camber adjustability.
- Andrew
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post:
arkanist (01-25-2018), FirstWinter (01-25-2018), jmark (01-30-2018), Leonardo (01-25-2018), Teseo (01-25-2018), venturaII (01-25-2018)
Old 01-25-2018, 12:38 PM   #12
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Hi @TLD,
We have been to Hong Kong a few times and checked out those back roads before, but haven't actually had the chance to travel with the HK GT86 Club to go to Zhuhai's racetrack. Are you part of the HK GT86 Club? We have our CSG Spec TEIN Flex A coming soon and has been proven on a variety of road conditions including suspension testing across the US over the course of 1.5 weeks and 6000+ miles.
Thanks,
CSG
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
Lust (01-25-2018)
Old 01-25-2018, 12:54 PM   #13
strat61caster
strat61caster's Avatar
Location
Probably much easier to get ahold of aftermarket spring/damper combo where he is. On a budget searching for ride quality I'd check out the Showa's.
http://www.ft86club.com/forums/showthread.php?t=120639
ineedyourdiddly
Old 01-25-2018, 09:38 PM   #14
TLD
Drives: GT86
Thanks everyone for the replies. I'm really sorry that I forgot to mention my budget. But car parts price in Hong Kong is quite different to US/Europe, so my USD2k might not get me the same thing as you can (I think a new set of KW v3 is close to USD3k here). But I'd think in US terms, something ~USD1.5-2k.
I've heard some good words about TEINS, but which model and which spring rate?
- Andrew
Thanks Andrew, my previous owner already have camber plate installed. In your opinion I should revert back to stock top hat? Or just keep them? I'm not upset because of my current setup is harsh, I just don't like how it jumps and that might potentially lead to loss of traction.
Originally Posted by CounterSpace Garage View Post
Hi @TLD,
Thanks,
CSG
Sadly I'm not part of the HK GT86 Club. If you have connections please let them know there's a stranded GT86 owner here in Hong Kong and would like to join their events. And maybe ride with some of their cars so I can feel which suspension I like the most.
Suspension upgrade Jmk91 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-14-2016 12:55 AM
Recommendations for plug and play speaker upgrade? irocz0r Electronics | Audio | NAV | Infotainment 10 09-07-2016 02:32 AM
Brake Pads Upgrade - Shop Recommendations in OC? KelvinBRZ Southern California 8 12-03-2015 03:49 PM
Recommendations for Suspension Mods Seth Hawkins Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 10-28-2015 12:20 PM
Pondering audio upgrade options; have questions, want recommendations SilverlightPony Electronics | Audio | NAV | Infotainment 17 05-11-2014 05:38 AM
