Old 05-18-2015, 11:01 AM   #15
I think it is just something rattling but it's not the shifter knob.
Old 05-18-2015, 02:44 PM   #16
86Tony
Drives: 2015 AOZORA EDITION
LOL this thread was in 2012
86Tony is offline   Reply With Quote
Old 05-18-2015, 02:55 PM   #17
LOL I have the problem today.
housecat (08-14-2015), JimmyMac (05-18-2015), Wally86 (01-05-2021)
Old 01-25-2018, 05:12 AM   #18
howareyoukk
Drives: Gts86
Originally Posted by JimmyMac View Post
Sound like this?
I think I have a very similar rattle..its louder in person than on camera yeah? also its mostly between 2000 to 3000 rpm under acceleration at least thats my case. Have u found a solution for it? thanks!
howareyoukk is offline   Reply With Quote
Old 01-25-2018, 06:19 PM   #19
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Well it was awhile ago so I never did figure it out. However, in 2015 at the end of May I blew my engine (turbo'd). I think a rocker might have popped loose and locked open a valve. It was a 2012 build motor, so who knows. I believe newer engines have slightly longer valves and enlarged? oil passages for the rockers among other things.
JimmyMac is offline   Reply With Quote
The Following User Says Thank You to JimmyMac For This Useful Post:
howareyoukk (01-26-2018)
Old 01-04-2021, 06:11 PM   #20
unicron
unicron's Avatar
Drives: frs 2015
I have rattle noise coming from the engine around the same rpm. It sounds like valve rocker noise, but only between 3000 to 4000rpm. Its quiet at idle or while driving at most speeds. Did you find out what it is?
unicron is offline   Reply With Quote
Old 01-05-2021, 01:45 AM   #21
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Do you have a stock or aftermarket header?
Thefalls is offline   Reply With Quote
Old 01-05-2021, 11:34 AM   #22
I discovered that my sound comes from the clutch pedal - master cylinder. If, while the rattle is occurring, you lightly tap the clutch pedal, does it quit?
RToyo86 (01-05-2021)
Old 01-05-2021, 11:54 AM   #23
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
That's interesting. I have the same noise on my 2017. It has been present pretty much as long as I can remember and I bought it new.
It comes and goes but only seems to make noise on throttle in certain situations. Did it bone stock and now header/tuned.
Old 01-05-2021, 03:44 PM   #24
unicron
unicron's Avatar
Drives: frs 2015
The car is mostly stock with 140000 km, it has done it for at least 100000 km, I first noticed it on the highway while accelerating, but now I can hear it driving in the city while accelerating moderately. I believe it is coming from the side of the engine near the high pressure fuel pump / clutch master cylinder. I have seen some videos of cars with the same noise. It seems to have some connection to the phase change of the VVT? or maybe when the port injection and Direct injection turn on / off?. No one has been able to identify it and fix it. I will try an find the videos with the noise. Everyone knows about the crickets but this sounds worst, but not as bad as "rod knock"
The Following User Says Thank You to unicron For This Useful Post:
Thefalls (01-06-2021)
cardboard-in-fan noise at 2-2.5k RPM kgc Issues | Warranty | Recalls / TSB 8 09-08-2012 12:27 AM
Fan noise? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 3 07-30-2012 05:22 PM
LSD noise wheeladdict CANADA 2 07-09-2012 03:21 PM
HID noise Carlsbad BRZ First-Gen (2012+) — General Topics 6 06-20-2012 12:39 AM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
