#71 |
Drives: RAVEN
#72 | |
Drives: '14 WRB BRZ | '17 CB STi
PR138
IG: @pr.138 2008 LBP Honda S2000 2013 UM Scion FR-S |
#73 | |
Drives: Q5 + BRZ + M796
I was trying to avoid going off-topic with a tangent debate about Porsche handing--not avoiding the "swap vs not" debate. |
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | DriftinFRS (06-18-2018), Thorpedo (01-25-2018) |
#74 |
Drives: GBS BRZ
Well, this is a swap discussion about putting an inline-4 where a flat-4 was, so maybe it's appropriate to have it here? I'm sure there are many people who come in here and think why waste time putting a 4 cylinder where a 4 cylinder already was, and in this case, I agree with the PO that it is totally justified. I think our discussion addresses many criticisms that people will naturally have with this swap.
Anyway, I agree with most of your points above now with a few exceptions: I don't think the 928 is relevant when discussing "typical Porsche handling" (front engine), and I don't think overall body measurements of the Civic Si are relevant when discussing track (car width != track and car length != wheelbase). For reference, the BRZ has ~2 inches more track width than the Cayman up front. And yes, I know there are good reasons why Subaru put the FA20 out front, but none of those reasons had anything to do with engineering a good sports car. It took marketing to turn this turd of an engineering choice into some BS about how they lowered the CG. If they really cared about the CG so much, all they had to do to get an equivalent change was to spec springs just 0.2" shorter. That's an almost imperceptible drop, and it would have cost them nothing. I'll take both solutions: give me the Honda engine to fix the weight distribution and I'll buy the $300 springs to give me back that 0.2" drop in CG. |
#75 | |
If someone was planning to NOT boost the F20, ever, then this swap is not cost effective or necessary, but to each their own. Whether it was the 928 (engine in front), or a LS swapped 911 (engine in rear), the V8's don't feel the same as their flat engines. And I didn't bring up length, width and wheelbase. I was asking him what he meant by a long wheelbase when he said that is what makes the twins great at handling. I still don't know what you or others mean by putting the engine out front? Out front of what? The engine is inline with the front wheels. Some engines in the front: Evo ![]() STI ![]() AE86 ...just as "forward" as the BRZ
#76 | |
I Love custom Turbo kits
Drives: Limited BRZ
Subaru motors have never been proven to being extra reliable (ringlands on stock EJs anyone? Stock FA20s throwing rods and rocker arms?). I know this is not the case for everyone. I know there are Subaru motors with 200K+ miles of course, but for every Subaru like that there are 10 Honda and 20 Toyotas. If you want to tell me, this motor provided the lowest CoG of all choices, I'd totally agree with you. But I would have preferred a higher CoG to have a real engine in there (real=reliably able to take power and mods and last). Mind you, this is from someone who ran the FA20 at 550 whp and didn't break it but knew had a ticking bomb on his hands. I understand 500whp is not realistic to be able to last on a stock motor, but I've seen plenty of stock motors or slightly modified FA20s grenade. Freaking Fully built FA20s can still throw a wrench at you when the a cam sensor or sprocket acts up, and P0016 or P0018 ends up hard coded in the ECU and you need to replace said ECU... Built FA20s have spit out rocker arms, a little dirt on the cam actuator screens and you start getting weird cam actuation CELs. The motor seems to be very sensitive and when you are talking about making power, simple is best. What I'm saying is, even when built, these engines still have more weak points than many other engines that are known to reliably make power. This car from factory with an F20 or K20/24, holy shit I would have bought this car and never looked anywhere else!
| The Following 5 Users Say Thank You to Sportsguy83 For This Useful Post: | BirgeyT1 (01-26-2018), CxG (02-26-2018), Draco_PR23 (01-31-2018), NOHOME (01-29-2018), wooly35 (02-18-2018) |
#77 | |
BoostedBRZ
Drives: Turbo BRZ
If/When my second engine goes, I seriously cannot wait until there's a full solution for an F series or K series honda motor. My friend had a 400whp supercharged 08 civic Si and ran it like that for years, many track days, many daily miles. Car still runs too, but he is doing a kmiata swap.
| The Following User Says Thank You to pgranberg11 For This Useful Post: | Sportsguy83 (01-26-2018) |
#78 | |
The Subaru motors, including the FA20, have their issues, but I don’t see many apple to apple comparisons that would suggest that the motor is silly at $25k. For $25k we get a 200hp NA motor that revs to 7500, 100hp/l, 34mpgs, a mid/front mounted engine and RWD with LSD. You get what you pay for. The Civic SI could be a better value, but that success doesn’t make the FA20 silly in design or disrespectable among its competitors. What is the point of acting like the FA20 should be something greater for that price, and is silly? Do the swap, but people don’t need to be a hater. |
#79 |
Drives: 02 s2k, 08 350z, 08 Fit sport
Supercharged s2000 Owner here. I can't speak for all s2k owners, but I don't think I'd consider the f20c transmission *that* stout. The > 500whp s2k guys know they can pop the gear box. I know if I were turbo'd at my power level (500+whp )the diff and tranny would be on borrowed time. The strength of the s2k gear box is that it'll still shift smoothly at >9000 rpm.
As an aside, the FA20 has a FI option that the s2k community is missing, a positive displacement supercharger. Given the option between 400 whp, turbo, centi blower, or posi blower, I think most would take the posi blower as it has a great power curve and is maintenance free. Though I do understand the f20c potential is greater than the fa20, the fa20 has its own merits. I forgot to mention I'm curious if there is room for centri-blowers. The kits for the s2k use the available space up front which I think is more than the FRS. There is no posi blower kit, so that leaves you with turbos for FI. If you hurt the bottom end of an F20C, it's not a cheap fix. Yes, I understand the engine is strong, but without good safe guards setup (and even with them), things can happen and motors get damaged. The mahle pistions are >700 and the other option are sleeves (dry or wet) and forged slugs. Of course if you're doing a swap of this magnitude, this is a small chunk of the overall budget. I just mention this so folks are aware of some of the f20c drawbacks. Last edited by tirespin782; 01-28-2018 at 10:27 AM. Reason: forgot a couple points |
| The Following User Says Thank You to tirespin782 For This Useful Post: | Irace86.2.0 (01-29-2018) |
#80 | |
Drives: Limited BRZ
If I wouldn't have been already mid-LS-swap I would highly consider doning my car for this swap.
| The Following 5 Users Say Thank You to Sportsguy83 For This Useful Post: | 86Tony (01-29-2018), BirgeyT1 (01-30-2018), Draco_PR23 (01-31-2018), pgranberg11 (01-29-2018), Tristor (02-21-2018) |
#81 | ||
In light of wanting to double the factory horsepower, yea, the engine can’t take it reliably without a build. If thats the measure of a real motor then few motors are real motors. If all flat motors are silly then Subaru and Porsche have silly motors. |
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Tristor (02-21-2018) |
#82 |
Drives: Limited BRZ
All good, back to swapping the F20 into an 86
| The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post: |
#83 |
Drives: 2015 AOZORA EDITION
Any update for the guys patiently waiting?
#84 |
Drives: 2JZ FRS
we have no customers that have committed to letting us do a build yet, so we are in the process of getting another shop car to develop on. Not having a car to develop on is the hold up
| The Following User Says Thank You to spitfire481 For This Useful Post: | Zer0 (02-21-2018) |
| trunk to roof height math for wing | EN2_Squirrel | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 01-07-2020 08:22 PM |
| First Audio Build (Need Math Help!) | MidnightMonkey | Electronics | Audio | NAV | Infotainment | 52 | 04-24-2016 04:50 PM |
| need math help | 7thgear | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 11-20-2013 03:17 PM |
| Fitting 9.5" wheels in back.. is my math correct? | eikond | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 05-23-2012 02:19 PM |
| So, I did a little math on Subaru's new 2.0... | iggyhop9 | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-21-2010 11:46 PM |
