Old 11-20-2013, 02:05 PM   #1
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
need math help
i'm drawing a blank here.. at the back of my mind i know what the answer is but i can't put it into words
i need to scale a bunch of numbers in terms of a scale of 0-100%
my min number is 5 and my maximum number is 90... what's the formula to break it down? (so 5=0% and 90=100%)
i'm so close i can feel it...
Old 11-20-2013, 02:14 PM   #2
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
um i'm in calc 3 but never taken stats, i would assume it would have to do with the total spread ? so your total spread is 85...and if you had say 10 of 85 it would be 10/85 = 11.76%
so for example you would add 10 to your min (5) to make it 15. 15 would be 11.76% of your spread? i have no clue.
SoCal909 is offline   Reply With Quote
Old 11-20-2013, 02:18 PM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
no, what you're doing is when you're not concerned with min and max and are just working within a set parameter,
in my case, the 5 is the 1% and the 90 is the 100%
did some internet digging.. couldn't find a math formula but i found an excel formula
NewValue = (((OldValue - OldMin) * (NewMax - NewMin)) / (OldMax - OldMin)) + NewMin
lets see if this bitch works
Old 11-20-2013, 02:20 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
IT WORKS!
Old 11-20-2013, 02:35 PM   #5
SoCal909
SoCal909's Avatar
good to hear, come back to me when you need calc help haha never took stats :P
Old 11-20-2013, 03:17 PM   #6
strat61caster
strat61caster's Avatar
Y= m*X+b
You have two data points, (5,0%), (90,100%)
m= 100/85 (rise over run) = 1.1765
b= where the formula hits zero, so take your 'm' value and plug in one of the two points and solve for b
I got the following:
Y=1.1765*X-5.8824
ineedyourdiddly
Fitting 9.5" wheels in back.. is my math correct? eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-23-2012 02:19 PM
So, I did a little math on Subaru's new 2.0... iggyhop9 Scion FR-S / Toyota 86 GT86 General Forum 33 10-21-2010 11:46 PM
