Old 01-04-2018, 09:54 AM   #1
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
FA20 - A, Thats F20 Quick Math
We've been up to no good! This was a complete mock up we did to make a mount kit. Mounts are in production!
Up next will be K Series mounts, then we will finalize our Honda engine swap ECU plug and play package! Stay tuned!
f20 by Brady Johnson, on Flickr
Pure Automotive is offline   Reply With Quote
Old 01-04-2018, 10:03 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Saw this on FB, pretty cool swap.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-04-2018, 10:33 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Schweeeet
Old 01-04-2018, 10:34 AM   #4
MRS-Colin
Drives: 2001 Impreza 2.5 RS
TELL EM MANS NOT HOT
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 01-04-2018, 10:40 AM   #5
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Sacrilege!!
But if you put in a Honda J-series...the newer ones..we may actually save weight perhaps. And I know them pretty good and they are reliable as hell.
I am all in then baby,
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 01-04-2018, 11:20 AM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Wow, that's the cleanest swap (of an s2k engine) I have seen!!! Nice work!
I loved my ap1! That VTEC song!
I LIKE TIRES!
Old 01-04-2018, 12:02 PM   #7
ILLSMOQ
Drives: 2017 WR BLUE BRZ
You guys are tearing it up!
ILLSMOQ is offline   Reply With Quote
Old 01-04-2018, 12:25 PM   #8
NOHOME
Drives: RAVEN
I do like the S2000 despite the Jeckyl and Hyde personality. Not so sure I would deliberately transplant that personality into the FRS.
Power gains would only be found above the VTEC threshold at 6000 rpm?
I am not saying that it is a bad swap ( looks well executed) but I would need to have the value proposition of this swap explained to me a bit more.
NOHOME is offline   Reply With Quote
Old 01-04-2018, 12:27 PM   #9
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
K swap the world!
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
Old 01-04-2018, 01:39 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Jeckyl/Hyde personality is purely a function of VTEC transition at 6000rpm. Tune to move it to 5000rpm or wherever torque is equal on either set of lobes eliminates the stupid VTEC "kick". In my '01, I never notice it because I'm almost never in VTEC on the street, and always in VTEC at the track
240hp > 200hp
greater reliability (perhaps debatable)
9000rpm screamy engine vs. 7400rpm tractor sounds
Old 01-04-2018, 01:53 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Lol!
via Imgflip Meme Generator
I LIKE TIRES!
Old 01-04-2018, 02:13 PM   #12
Tokay444
Anti stance.
Tokay444's Avatar
Cleanest mock up?
Old 01-04-2018, 03:23 PM   #13
Pure Automotive
The value of this swap is the same value of every swap we have done so far. They're all the same reason: They are a building block toward something better. FA20s (reliable ones) that are built and boosted are fun, until about 400-450 your trans breaks. Then you need to buy a built trans. The money you spent on a built FA20, turbo kit, and built transmission, could have been spent on a swap. Then, instead of being maxed out, which the FA20 would be at that point, now you have a platform that will max out much higher. We did a turbo s2K for a customer that made 650 whp on the stock engine and trans. The only weak point at that power level in an S2000 is the diff. The FT86 differential has been known to hold 700+. This swap will cost half what a 2JZ swap costs when we're done with our kit. It will also make less than half the power, but then you'll have a stepping stone to build onto later that won't let you down like the FA20 always does.
Old 01-04-2018, 03:27 PM   #14
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
I wonder how differently it will handle compared to the fa20.
glorydays is offline   Reply With Quote
trunk to roof height math for wing EN2_Squirrel Cosmetic Modification (Interior/Exterior/Lighting) 9 01-07-2020 08:22 PM
First Audio Build (Need Math Help!) MidnightMonkey Electronics | Audio | NAV | Infotainment 52 04-24-2016 04:50 PM
need math help 7thgear Off-Topic Lounge [WARNING: NO POLITICS] 5 11-20-2013 03:17 PM
Fitting 9.5" wheels in back.. is my math correct? eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 05-23-2012 02:19 PM
So, I did a little math on Subaru's new 2.0... iggyhop9 Scion FR-S / Toyota 86 GT86 General Forum 33 10-21-2010 11:46 PM
