Old 01-22-2018, 03:03 PM   #883
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Originally Posted by DustinS View Post
Rip it out and disassemble. Triple check all the clearances to see what caused the issue to make sure it doesn't happen again. Put it all back together and hope it doesn't happen again.
...and add turbo.
ILLSMOQ is offline   Reply With Quote
The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post:
DustinS (01-22-2018), Sportsguy83 (01-22-2018)
Old 01-22-2018, 03:19 PM   #884
kurty85
Drives: 2014 FRS LS Swap
Scoggins-****ey parts https://sdparts.com/ has tons of parts for good money if you need anything. Built my whole 408 twin turbo from there for a really good price.
kurty85 is offline   Reply With Quote
The Following User Says Thank You to kurty85 For This Useful Post:
Old 01-22-2018, 03:20 PM   #885
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by ILLSMOQ View Post
...and add turbo.
Two of them
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (01-23-2018)
Old 01-23-2018, 10:23 AM   #886
all4spl
shouldn't they use the date of when you reached out to them with a concern that the engine wasn't healthy? I'm willing to bet cam bearings.
all4spl is offline   Reply With Quote
Old 01-23-2018, 11:03 AM   #887
DustinS
DustinS's Avatar
That is what I thought, but oh well. It's fine.
I think it might be cam bearing as well. I starting to get a list together of everything I need. New bearings all around, head gasket, ARP Head Bolts, gasket kit...
Old 01-23-2018, 11:09 AM   #888
all4spl
Which block is it? These engines are what I specialize in and to my knowledge, when you spin a cam bearing, that's it. They don't make a properly oversized bearing. It requires a new block unless you spend the BIG money on roller cam bearings. Which is not very common.
Old 01-23-2018, 11:31 AM   #889
ILLSMOQ
Hopefully he hasn’t spun the bearing.
The Following User Says Thank You to ILLSMOQ For This Useful Post:
DustinS (01-23-2018)
Old 01-23-2018, 11:56 AM   #890
DustinS
DustinS's Avatar
God I hope not. It's a Texas Speed 418 Stroker Block lol. Maybe it just didn't seat all the way? That news didn't help any haha
This guy has a weird issue. Low oil Pressure and Metal Shavings. Tore apart the engine and didn't find anything too bad. Put new bearings and everything and still had lower oil pressure but runs fine.
https://ls1tech.com/forums/generatio...n-reuse-3.html
Old 01-23-2018, 01:16 PM   #891
all4spl
Well i'm not sure if you recall me posting awhile ago, My engine had this same exact issue that youre experiencing. I had a vortech supercharged build motor corvette that spun a cam bearing. the bearing actually started coming out of the bore and rubbing against the cam. I had like 9psi of oil pressure with the factory sensor and didn't change much with RPM. Literally had to cut the bearing out and the block was trash. I hate to say it but I would call texas speed back and tell them that you reached out to them when you first saw the problem and they said just deal with it. Now that you have proof it is bad, they said oh well it's passed warranty. That's shitty.
Old 01-23-2018, 02:55 PM   #892
DustinS
DustinS's Avatar
I don't think it is that drastic. I still have oil pressure up to 45psi. Possible oil pump failure/clog? I'm not sure, and won't till it's opened up.
I will get everything measured up before ordering. Have a few friends with the tools to do the job so that is nice.
Old 01-23-2018, 03:05 PM   #893
all4spl
I'd change some of those. I'm not sure who you get your parts through but I'm sure I can save you a little money. If you're interested in a little feed back and maybe a little price savings, pm me.
The Following User Says Thank You to all4spl For This Useful Post:
Old 01-23-2018, 03:35 PM   #894
DustinS
DustinS's Avatar
This is just a preliminary check on pricing. Won't know if I need undersized/oversized until it's apart.
Save $160 if I don't get the coated bearings. I think it's worth the extra price.
Old 01-23-2018, 10:25 PM   #895
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Received in November 2016. Installed in May 2017.
Fuck man. ...and after paying that huge, TSS marked up price tag to avoid this kind of b/s.
Old 01-24-2018, 09:10 AM   #896
all4spl
Well, I'd get different bearings all together. And I would also do the head studs vs head bolts. I always feel safer torqueing down on thread of the studs vs threads of the block, especially with ARP. The block will give before the bolts do.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
