Old 01-18-2018, 10:17 PM   #1
Raven86Project
JDM Spirit of the '90s
Raven86Project's Avatar
Drives: 2015 FR-S Turbo
18x10.5 +50 (rear) Will it fit?
Hi! I want to maximize the width of my rear wheels (mainly for cosmetics) on the stock body and at the same time keeping the current stance (no poke or extra camber).
Currently the wheels are 18x9.5 +38 with 255/35. I took some measurements and there is a 28mm clearance between the rim and the strut. So, if I get them widened by 1" (25mm) there should still be 3mm of clearance (minimum recommended) resulting in 18x10.5 +50.
I want to keep this wheel model, which I love, and the closest spec from Work is 18x10.5+30 (20mm poke).
Is there anything else that I have to keep into account before proceeding?
Thank you all!
IG: raven86project
Build Thread HERE
Raven86Project is offline   Reply With Quote
The Following 2 Users Say Thank You to Raven86Project For This Useful Post:
CkOne (12-14-2019), Leonardo (01-18-2018)
Old 01-18-2018, 10:21 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Wow beautiful car.
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
Raven86Project (01-18-2018)
Old 01-18-2018, 10:22 PM   #3
Raven86Project
Thank you bud!
IG: raven86project
Build Thread HERE
Old 01-18-2018, 10:28 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This thread has 19x10.5 +32 rear wheels with 235 /30 tires at -2.8 camber. 19 is bigger, but the poke camber will look the same as 18s.
a little pull on the rears goes along way. there is s guy with 275/40/17 rears.
post 110
http://www.ft86club.com/forums/showt...t=64040&page=8
19x10.5
http://www.ft86club.com/forums/showthread.php?t=23831
I LIKE TIRES!
Old 01-18-2018, 10:42 PM   #5
Raven86Project
Thank you Leonardo! I mainly want to know if I'm going to have fitment problems with my proposed setup 18x10.5 +50, especially with inner clearance.
IG: raven86project
Build Thread HERE
The Following User Says Thank You to Raven86Project For This Useful Post:
Old 01-18-2018, 11:14 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I assume you have coilovers.
This guy has stock struts, springs, and lca and his 19x10+50 fits. Coilovers would give you enough room for 18x10.5 +50
http://www.ft86club.com/forums/showt...t=61628&page=2
You are welcome!
I LIKE TIRES!
Old 01-18-2018, 11:18 PM   #7
Raven86Project
Thank you for the link! Seems like this is going to work just fine!
IG: raven86project
Build Thread HERE
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 07:12 PM
How many of us are waiting to pull the trigger? Phantobe Scion FR-S / Toyota 86 GT86 General Forum 13 08-26-2013 05:54 PM
About to pull the trigger on Perrin.... FRSFirestorm Engine, Exhaust, Transmission 143 05-04-2013 02:25 AM
To pull the trigger or to wait? that_one_guy Scion FR-S / Toyota 86 GT86 General Forum 17 10-24-2012 05:17 PM
2007 STi... should I pull the trigger? RRnold Other Vehicles & General Automotive Discussions 25 02-23-2010 10:37 PM
