Old 01-11-2018, 02:08 PM   #1
max20s14
Drives: 14' Raven M/T - 02' is300
How to check for excessive silicone sealant???
My 14' car is approaching the end of the power train warranty with 50k miles.. Reading through here gets me paranoid from hearing about peoples oil galleries getting clogged with excessive silicone sometimes causing problems with cam gears and in some cases starved bearings.. I've done an oil analysis with blackstone labs and silicon level showed average.
Is there a way to check without tearing down the engine?
Are there preliminary signs like: low oil pressure ect, oil analysis with high silicon?
Ideas on preventing serious damage? like install oil pressure gauge ect..?
Is the primary source of the excessive sealant just the front cover or has anyone found it to be in other places?
If anyone that had a sealant related oil problem wants to share their experience here that would be ideal.
But maybe I am just too paranoid
max20s14 is offline   Reply With Quote
Old 01-11-2018, 02:50 PM   #2
Originally Posted by max20s14 View Post
My 14' car is approaching the end of the power train warranty with 50k miles.........
I suggest you just not worry about it ....... you have a better chance of getting hit by an impaired/distracted driver.
Old 01-11-2018, 03:40 PM   #3
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
The only way to know is to take your engine apart and inspect. However once you put your engine back together you should recheck in 100 miles.
Old 01-11-2018, 03:46 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
unless you're suddenly going to start tracking and before it was a DD that never revved past 3.5k rpm, it's survived this long, no reason for it to not keep on trucking for tens of thousands more miles
ineedyourdiddly
Old 01-11-2018, 04:05 PM   #5
Don't panic! The number of them with issues is actually very very low. You just hear about them. As said if still going odds are you will be fine. Even the 13s that have a much higher stated failure rate probably represent something under 2% of all the cars. Taking the engine apart to inspect it could cause issues of it's own so best to leave it alone. If it does happen it will be sudden and a gauge isn't going to help.
Just keep in mind that these horror stories are a tiny minority.
Old 01-11-2018, 10:19 PM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If your worried about it sell it.
Buy a civic.
Problem solved.
Old 01-11-2018, 10:38 PM   #7
It sucks. I think about it all the time but short of preemptively tearing down the engine to inspect and clean, there's not a damn thing we can do.
I just passed through 40K with my 13.
Old 01-11-2018, 10:47 PM   #8
gravitylover
93k and haven't experienced that problem yet. Don't worry about it, just drive it.
Old 01-12-2018, 12:25 AM   #9
Buy a civic.
Problem solved.
So, Mr .ac ...... how are your civic sales going ...... ??
Old 01-12-2018, 01:30 AM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Not that good. Maybe I should rethink my lame car puns. I'm thinking about earl '90's 240's. Most of those are douche bags fan boys. Or Prius & Volt cars. Not sure which one insults more.
Old 01-12-2018, 01:35 AM   #11
Mustang?
Old 01-12-2018, 01:46 AM   #12
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Mustang?
Ah. Yes. Another good one.
Old 01-12-2018, 02:09 AM   #13
Am I going to have to go change all the tags?
buy a civic, problem solved
Excessive manufacturing JZ mounts PolishFrs13 Engine, Exhaust, Bolt-Ons 1 05-08-2017 05:33 PM
Excessive oil in PCV side air/oil separator Jbelmonte Engine, Exhaust, Transmission 0 02-26-2017 07:45 PM
excessive shaking while wheelspinning andrew5826 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-01-2015 09:00 AM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
Excessive wheel weights? muffinman Other Vehicles & General Automotive Discussions 6 05-25-2012 09:59 AM
