Old 01-08-2018, 08:49 PM   #15
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by texastwurkt3am View Post
Well then I guess this begs the question, where in the hell did they get these dyno figures? All just an elaborate ruse?
"Our catted UEL header is a simple bolt on install that gains 18ft lb. of torque and 12HP in the infamous "dip". Peak power is up 14HP and 5ft lbs of torque with no ECU tuning. Unlock even more with a tune. No CEL, as well, for those who wish to not stare at a light on the dash. No CEL is on a stock car with no other mods. If you have other parts you still need a tune."
Looks like it's running lean there with the header and no tune. That's not good for actual use, but sometimes shows a good dyno run.
The Following User Says Thank You to Spuds For This Useful Post:
texastwurkt3am (01-09-2018)
Old 01-09-2018, 10:17 AM   #16
texastwurkt3am
texastwurkt3am's Avatar
Drives: '17 PP BRZ
What does yours run generally? I kept Torque up the whole trip home from work last night and it steadily hovered around 14-15
texastwurkt3am is offline   Reply With Quote
Old 01-09-2018, 10:21 AM   #17
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Stoich AFR is 14.7, you generally want it around there while idling and cruising. At WOT you’ll usually see around 11-12.5.
mjanmohammad is offline   Reply With Quote
The Following 2 Users Say Thank You to mjanmohammad For This Useful Post:
Spuds (01-09-2018), texastwurkt3am (01-09-2018)
Old 01-09-2018, 10:30 AM   #18
Spuds
The Dictater
Spuds's Avatar
Step on the gas for a few seconds to get the car into open loop mode (make sure it's warmed up first). The afr should come down to 12ish while you are on it.
In closed loop, all cars run at 14.7 as that's the stoichiometric point where all the fuel is burnt using all the air. However you make the most power at lower afrs due to a number of factors.
Also, running richer (lower afrs) reduces knock. Knock is bad, so when it happens, the engine reduces timing, which reduces power. So if you run lean (higher afr) you risk damaging the engine AND will have less power.
Edit:. See bold. Was originally "open" which was incorrect.
texastwurkt3am (01-09-2018), TorontoNat (01-09-2018)
Old 01-09-2018, 03:33 PM   #19
Jordanwolf
Rice King
Jordanwolf's Avatar
Warranties cannot be voided.
http://www.ft86club.com/forums/showthread.php?t=42595
Nobody can guarantee that the dealership in question won't pull a fast one (requiring you to go to court to get a repair covered) aside from a written contract from said dealership service department, which they could still double back on and make you suffer.
I wonder if this is valid for Canadians as well
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 01-09-2018, 03:50 PM   #20
Cole
Not a troll
Cole's Avatar
Service department at the dealership I bought the car from basically told me to go fuck myself (obviously more politely) when I was having a transmission issue.
They asked me to return the car to 100% stock form (I had full exhaust, coilovers, wheels, drop in filter, etc). And yes, that included stock wheels with OEM tires when I asked them to clarify that. So, I mean, my warranty isn't void, they just made it clear that they had zero interest in performing the warranty work.
Which of course, turned out to be 20 minutes of work via a TCU reflash. Eventually they did the work when I went to the Scion side of things, and asked to take one of their bone stock cars out for a test drive, and replicated the issue in less than 5 minutes, and proved to the service manager that it had absolutely nothing to do with my mods.
Cole is offline   Reply With Quote
Old 01-09-2018, 03:59 PM   #21
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Don't believe the catted header marketing hype.
Catted header + no tune = waste of money.
I speak from personal experience. I had a JDL catted header with no tune, OFT stage 1, and EcuTek tune.
TofuJoe is offline   Reply With Quote
The Following User Says Thank You to TofuJoe For This Useful Post:
texastwurkt3am (01-10-2018)
Old 01-09-2018, 04:13 PM   #22
Jordanwolf
Rice King
Jordanwolf's Avatar
Pretty silly. I can only hope my current issue doesn't become something silly like that because I installed steelies lol
Glorious Honda.
Old 01-09-2018, 05:18 PM   #23
Spuds
The Dictater
Spuds's Avatar
Any comparison between oft and ecutek tunes with the header?
Old 01-09-2018, 05:52 PM   #24
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Brand name vs generic drugs IMO.
Both are tools that do the same thing.
Same exact tune on each system will net same gains.
The more expensive one has some extra bells and whistles.
The Following User Says Thank You to x808drifter For This Useful Post:
Spuds (01-09-2018)
Old 01-09-2018, 06:38 PM   #25
mjanmohammad
ECUtek tunes are more dependent on the tuner too, a dyno tune from one tuner will be different from another tuner.
The Following User Says Thank You to mjanmohammad For This Useful Post:
strat61caster (01-10-2018)
Old 01-09-2018, 06:41 PM   #26
Spuds
The Dictater
Spuds's Avatar
Yes, both are ways to flash the ECU. Usually someone goes from the ots oft files to ecutek so they can get a more specific ots tune, or get a custom tune. As I understand it, most custom files are locked, where the oft doesn't support it. Was just curious as to whether there was a noticable difference between the oft stage1 and whatever TofuJoe went to.
Unless you were saying just that and I misinterpreted, in which case .
Old 01-09-2018, 06:47 PM   #27
mjanmohammad
I was running an OFT tune for 5 months and switched to ECUtek in November. After the process was done, I don't know why I messed around with OFT at all. The car ran smoother on the ECUtek, the torque dip was nonexistent (where it still slightly existed on the OFT Stg 2), and I ended up getting BETTER gas milage without changing my driving habits at all.
Spuds (01-09-2018), texastwurkt3am (01-10-2018)
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions Corradooo Engine, Exhaust, Transmission 2 11-25-2017 07:16 PM
MY17 Exhaust questions Elliotw Engine, Exhaust, Transmission 1 09-28-2017 03:50 AM
SIMPLE! Beginner Build Questions NicoFRS Engine, Exhaust, Transmission 28 09-22-2017 05:33 PM
Build Your Own BRZ Accessories (MY17) FlipperBizkut BRZ First-Gen (2012+) — General Topics 15 10-12-2016 05:48 PM
soundman's audio build and questions soundman98 Electronics | Audio | NAV | Infotainment 0 01-20-2014 08:59 PM
