Old 01-05-2018, 01:28 PM   #15
SAY WHAT ....!!
Heroin is never the answer.
humfrz (01-05-2018)
Old 01-05-2018, 01:30 PM   #16
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Monofilament fishing line would be my recommendation for clearing the nozzle.
Used to use mono for cleaning carburetor jets and passages.
The nozzle itself is usually a small captive bead with a hole through the middle you can move to aim it appropriately.
It can get turned too far and act like a ball valve in a water line.
The Following 2 Users Say Thank You to bcj For This Useful Post:
humfrz (01-05-2018), Ultramaroon (01-21-2018)
Old 01-05-2018, 01:32 PM   #17
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
If I had a weak squirter I'd consider main lining.
Old 01-05-2018, 01:44 PM   #18
Maybe it was an insulin shot ??.......
Old 01-05-2018, 01:47 PM   #19
Give it time ...... give it time ...... you're still at relatively low mileage .....
Old 01-08-2018, 07:03 PM   #20
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
Can anyone recommend good windscreen washer mix?
Or something to add to water that would stop gunk build up.
Cheers
FRS2017 is offline   Reply With Quote
Old 01-08-2018, 11:24 PM   #21
Cheers
How about a mixture of 50% vodka and 50% distilled water.....
Run a third line into the cabin .....
Seriously, I would suggest you suck the gunkie fluid out of your washer bottle, flush the lines and fill it up with whatever windshield washer fluid is sold locally .....
Old 01-08-2018, 11:59 PM   #22
FirstWinter
Drives: Car
Cheers
I get windshield washer from the local auto parts store. Costs less than a $1 for a gallon. Nothing special and I've been using it for a bunch of cars for years. Have you figured out what was causing the blockage? Could it be dried buildup from the liquid you're using now?
FirstWinter is offline   Reply With Quote
Old 01-14-2018, 11:49 PM   #23
FRS2017
Enthusiast 86
FRS2017's Avatar
Took my car to the dealer with a bit of haggling and they said they would fix it under the warranty. They ordered a new washer nozzle, haven't got the call yet to bring my car in so they prob trying to import the part from china lol
I used to use a bit of white vinegar with water, but if your not careful and you don't use the washer for a while the vinegar builds up into gunk. I think I start buying washer fluid from the store now as my warranty is ending this year and don't want to start having problems with the washer system. It doesn't look that hard to take all the clips off and get at the nozzle, but still a hassle I want to avoid.
humfrz - vodka.....lol, sure if I want my car to be a new fire red color or the next paul walker on TV
Old 01-15-2018, 01:44 AM   #24
First off, there FRS2017 ....... vinegar and water .....?? Did you grandmother recommend that solution .. ??
Yep, good plan on using store bought windshield washer solution....
As far as using vodka and water ...... you're not supposed to smoke while running your windshield washers.......
Do you know what we used back-in-the-day ..??
That's a trick question, ........ because we didn't have windshield washers on your average car back in the day .......
Old 01-15-2018, 09:19 PM   #25
ls1ac
ls1ac's Avatar
Just an FYI, in Florida the washer fluid sold at most locations is 32+ and has no alcohol in it. If you leave it sitting it will start to grow black stuff in it. You may have to ask for winter washer fluid at the parts store.
I had to use a compressor to back flush the system on one of my cars. Rainx makes a fluid with silicone and alcohol in it that also seems to fight growing things.
The Following User Says Thank You to ls1ac For This Useful Post:
Old 01-16-2018, 10:21 PM   #26
FRS2017
Enthusiast 86
FRS2017's Avatar
bought some tablets off ebay as they cheap and I can mix them in water to make 4L with each tablet.
I use white vinegar all around the house and use to clean my Toyota 86 Windows, does a great job and only $2 for 2L of it.
Old 01-17-2018, 12:26 AM   #27
............humfrz
Well, I reckon those tablets would work OK ...... if the temperature never dropped below freezing.......
Do you know what those tablets are made of ...... ?? .......
Yep, vinegar can be a very useful household product.
Back in my grandfathers day, the adult per capita use of vinegar in the US was about 50 gallons per year.
Old 01-21-2018, 08:54 PM   #28
EzyBreezy
EzyBreezy's Avatar
Drives: 2016 Subaru BRZ (ZC6)
I had a car with similar problem. At the bottom of your winshield washer fluid bottle there should be a small pump with an electrical connection. That piece could be faulty. I would suggest replacing it. Instead of blowing through the lines just replace them tho i doubt thats your problem.
You can go dealer specific part or local parts store should also stock the item.
EzyBreezy is offline   Reply With Quote
Total windshield washer amt? SteveGrillo BRZ First-Gen (2012+) — General Topics 21 03-04-2022 10:21 AM
DIY: Smaller Windshield Washer Reservoir zeal86 DIY (Do-It-Yourself) Guides 15 06-05-2021 01:25 AM
Where can I get the Smaller Windshield Washer Tank? Cross Forced Induction 37 01-19-2017 04:23 PM
where to buy a windshield washer tank shif7i7down Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-23-2015 08:09 AM
Windshield Washer Motor and Pump Assembly Fainten BRZ First-Gen (2012+) — General Topics 0 09-06-2014 07:14 PM
