Old 01-06-2018, 06:42 AM   #1
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
How to gap spark plugs
I purchased hks spark plugs for the brz as my turbo requires a replacement if over 15k.
I was told I should gap to .022.
On the spark plug box it says:
Do not adjust spark plug gap due to extremely fine center electrode.
How would I get the bad boys to .022?
Sent from my SM-G950U using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 01-06-2018, 02:16 PM   #2
Plug gaps don't have to be perfect. The iridium-tipped center electrode greatly reduces the voltage required to trigger an arc. It's also delicate.
Install them straight from the box.
humfrz (01-06-2018), Spuds (01-06-2018), Teseo (01-06-2018)
Old 01-06-2018, 03:11 PM   #3
Who told you that ....??
What is the gap out of the box..??
Yep, I agree with @Ultramaroon ...... just don't mess with them.
Old 01-06-2018, 03:48 PM   #4
Strife26
Strife26's Avatar
The ultimate racing techs who designed their turbo kit says it is a must that they be gapped to .22.
It's gapped at around .32
Old 01-06-2018, 03:53 PM   #5
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
Just gap them, if you break the electrode you screwed up, try again. You probably wont though. Just make sure you aren't using a coin style gap tool, since they'll most likely break the tip.
I doubt you wanna go through the trouble of pulling the plugs on this motor if it starts blowing out spark.
murdoc is offline   Reply With Quote
The Following User Says Thank You to murdoc For This Useful Post:
Strife26 (01-06-2018)
Old 01-06-2018, 04:04 PM   #6
Strife26
Strife26's Avatar
Lol damn. That's the kind I had. I'll go grab a better tool then.
Thanks!
Old 01-06-2018, 04:22 PM   #7
Teseo
Drives: frs
But why you need change them after 15k miles?
Old 01-06-2018, 04:31 PM   #8
Strife26
Strife26's Avatar
Gotta ask them. They need to be gapped at 22 if they are over 15k they require replacing according to them. It's a "must." I trust that they know what they are talking about and I confirmed with them that yes, they want them to be changed is one 15k. Sensitive turbo perhaps, /shrug.
Old 01-06-2018, 04:36 PM   #9
OMG - smash them down ...... QUICK ......
Old 01-06-2018, 04:51 PM   #10
Please help this old man out here ........
If the cylinder is charged and the valves are closed and the piston is at/near the top of its compression stroke and the spark plug fires ....... what's to "blow out the spark" ........
Which brings to mind a back-on-the-farm story.
It was a cold, sunny day in late August, when we were picking corn. We had just pulled the loaded wagon up to the elevator to upload the corn into the corn crib.
My father was trying to start the Wisconsin engine on the elevator, but it wouldn't start. So, he laid the plugged in spark plug on top of the cylinder head and pulled the rope to see if he could see a spark. Like I said, it was a bright sunny day.
Anybody see where this is going ......??
My father told me to hold the spark plug in my bare hand, while he pulled the starting rope, so I did ....... since I jumped and let out a yelp ....... he figured the plug was firing.
Now, that diagnostic strategy just works once per kid ......
THE END
Old 01-06-2018, 05:04 PM   #11
Strife26
Strife26's Avatar
Helpful. The exact kind of help I was looking for... Smh. Are there better forums? I thought these were better.
Old 01-06-2018, 05:10 PM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
It is true. Too much push it down, not enough, bend it up. Use guage. Pretty simple.
Old 01-06-2018, 05:11 PM   #13
Hey, Skippy, are those plugs REALLY set at .32" (that's almost a third of an inch).
I was jest ah funnen with your math (and/or ability to read measurements).
Sorry to have bothered you. I already chimed in with a helpful comment up above.
I reckon ol humfrz needs a nap ...... ZZZZZZZZZZZZ
Old 01-06-2018, 05:29 PM   #14
Strife26
Strife26's Avatar
I guess leave them alone is helpful but not what I was looking for.
Don't use a coin type tool was helpful.
Thanks for what you offered but I'm not looking to leave em alone. I need em to be .22.
And yes I used the gap tool to read how the were gapped. Could I be wrong sure, does that require ridicule? I guess since it's the internet. Anyways, I don't want to argue, but if you have helpful info I appreciate it otherwise I can do without.
Spark Plugs at 65K user4815 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-25-2017 04:19 PM
Spark Plugs for turbo e85 Hags86 Forced Induction 6 09-17-2017 07:01 PM
Which model spark plugs for the FRS/BRZ? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-05-2016 05:18 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
