Old 07-22-2017, 02:35 PM   #1
user4815
Drives: 2013 Scion FRS Series 10 Manual
Spark Plugs at 65K
This is what my Plugs looked like at 65k. I'm no expert but I wouldn't recommend running them until 100k like most Subaru engines specify.
user4815 is offline   Reply With Quote
Old 07-22-2017, 02:45 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Can't tell much from that angle.
Cole (09-09-2017), Somerandom18 (07-22-2017)
Old 07-22-2017, 03:06 PM   #3
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Doesn't the manual call for replacement at 50k?
The Following User Says Thank You to Summerwolf For This Useful Post:
chaoskaze (12-25-2017)
Old 07-22-2017, 03:17 PM   #4
humfrz
The manual for my 2013 FR-S calls for spark plugs replacement at 60,000 miles.
humfrz
funwheeldrive (09-06-2017)
Old 07-22-2017, 03:19 PM   #5
humfrz
I think they look pretty darn good for 65,000 mile plugs .....
humfrz
Old 07-22-2017, 03:22 PM   #6
humfrz
Here ya go .......old man ........
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Cole (09-09-2017), Strife26 (01-06-2018), Ultramaroon (07-22-2017)
Old 07-22-2017, 03:24 PM   #7
Ultramaroon
not playing cards
got jokes
Cole (09-09-2017), humfrz (07-22-2017), Strife26 (01-06-2018)
Old 07-22-2017, 03:26 PM   #8
MurderousPandas
MurderousPandas's Avatar
Damn. Are you burning oil at all or using anything but 93? I'm at 91k, been using E85 for a while, not sure if it helps keep them clean or the extra fuel needed makes em dirty.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 07-22-2017, 03:26 PM   #9
humfrz
got jokes
Isn't it past your nap time ......?????
humfrz
Old 07-22-2017, 03:29 PM   #10
Summerwolf
Panda Trueno
Summerwolf's Avatar
humfrz
I remember a whole bunch of people saying it was suggested during their 50k service.
I didn't actually want to look it up in my manual.
humfrz (07-22-2017)
Old 07-22-2017, 04:05 PM   #11
user4815
It might burn 1/2 a quart every 5k. I use ethanol free gas to keep the crickets at bay... The highest octane I can find in my area is 92. Bought mine used with 59k, I have no idea what previous owner did.
Old 07-22-2017, 04:53 PM   #12
MurderousPandas
Bleh. I plan to change mine at 100k anyway unless something comes up. Mine has been through 93 for half its life, corn for the other half. This is something i've always wondered about, so close to seeing the condition of the plugs. Was your changed at a dealership or at home? I want to do it at home, but as far as i know, nothing has made it an easier than lifting the engine.
Old 07-22-2017, 05:06 PM   #13
Ultramaroon
not playing cards
Unless your electrodes and/or insulator are seriously burned away, or the plug is fouled with goop, I woudn't sweat anything. Honestly, in my 40 years of reading and changing plugs in all manner of engine, including aircraft, it seems like most people tend to make too much out of it. Just a middle-aged fart's HO.
On the flip side, you already took the time to remove them, fuck it. Plugs are cheap.
...except aircraft. Whole different ballgame. Those see a sandblaster as needed.
Cycletech (09-13-2017)
Old 09-03-2017, 11:19 PM   #14
BuffDriver
Drives: 2016 Subaru BRZ
ah yes, The SANDBLASTER! Soooo many reconditioned plugs!
changed out SOOOO many of these when working as an A&P in the 80's n 90's
{I hate O200s!}
Champion REM37BY
and then I started working on THESE! ! ! GE LM6000 Aeroderivative
https://www.geaviation.com/marine/en.../lm6000-engine
If I could only get one to shoehorn into my BRZ! I just know I could make it work somehow.
Note the 6000 stands for +-60,000 HP
Wonder what WHP I would get...
Maybe if like a famous song I carried out a part a day in my lunchbox?
I NEED A BIGGER LUNCHBOX! WITH WHEELS ON IT!
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
BuffDriver is offline   Reply With Quote
The Following User Says Thank You to BuffDriver For This Useful Post:
Ultramaroon (09-04-2017)
NGK OEM Equivalent Spark Plugs? wparsons Engine, Exhaust, Transmission 10 05-12-2016 01:09 PM
Which model spark plugs for the FRS/BRZ? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-05-2016 05:18 PM
boosted spark plugs? 350matt Forced Induction 9 08-09-2014 03:54 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
