Old 11-11-2017, 02:26 AM   #85
Zer0
Drives: 2015 frs
Looking clean.
Zer0 is offline   Reply With Quote
Old 11-11-2017, 06:54 PM   #86
kurty85
Drives: 2014 FRS LS Swap
Adjusted the clutch and took out the helper spring. Clutch is now similar to my vette with release at the top 1/3 of the pedal. Car doesnt feel very fast though. Doesnt wake up until 4-5k. Maybe the cam being a zr1 cam is the result. Any ideas besides running rich?
kurty85 is offline   Reply With Quote
Old 11-12-2017, 01:58 AM   #87
BRX
BRX's Avatar
Drives: Toyota GT86
I didn't read the whole thread just the few last posts but did you tune it? I doubt a ZR1 cam would work on a 4.8L properly without a tune. Sports cars generally focus on top end HP rather than low end torque unlike trucks. The stock 4.8 cam you had was probably better down low not to mention it was tuned for it.
Sent from my Pixel XL using Tapatalk
BRX is offline   Reply With Quote
Old 11-12-2017, 02:11 AM   #88
kurty85
I have not tuned it yet. I put the came in more for price ($99) but will eventually have boost. I didn't think it would be this bad. Specs are 211/230 and .558/.552 lift with 1.7 rockers and a 122.5 lsa. Gonna start looking at an NA cam from LJMS or LG. I have a G6X3 cam in my C5 ZO6 and it is beastly. Makes 507/491 on 93. The 4.8 cam was worn out and you could see rub marks all over it. There was bearing material in the cam faces. I put new bearings and a new camshaft in.
Old 11-12-2017, 02:16 AM   #89
BRX
BRX's Avatar
Drives: Toyota GT86
I totally forgot that the ZR1 came with a blower. Yeah, that cam is probably too big of a jump for a relatively small 4.8 with stock heads and no boost. I would keep it if you're gonna run a supercharger but with a turbo it might just cause more lag depending on the turbo specs.
Old 11-14-2017, 05:24 PM   #90
kurty85
HP Tuners is coming right now so I will be able to verify everything is running right with sensors and do some street tuning. Also installing my wideband from when I was turbo.
Old 11-14-2017, 09:07 PM   #91
ILLSMOQ
Drives: 2017 WR BLUE BRZ
What’s the word?
ILLSMOQ is offline   Reply With Quote
Old 11-22-2017, 03:39 AM   #92
kurty85
Originally Posted by ILLSMOQ View Post
What’s the word?
Got HP tuners working today after work. Changed the cylinder volume for a 4.8L. Adjusted the PE tables to command an AFR of 12.25 above 1200 rpm with a 2s minimum delay into open loop. Seemed to make a big difference in how it rev's up. 1 code popped up though. P0357 #7 cylinder misfire. Going to fix that tomorrow. Checked oil pressure and getting 47 psi at idle and in the 60's+ when revved up. So now I know I didn't make any major mistakes when I built the engine. Going to play with some more tables including injector timing to try and get rid of some gas smell and unburnt fuel. Need to make time for the dyno here to see what it is putting down.
The Following 2 Users Say Thank You to kurty85 For This Useful Post:
ILLSMOQ (11-22-2017), Sportsguy83 (11-22-2017)
Old 11-24-2017, 07:32 AM   #93
kurty85
Misfire on cylinder 7 looks worse than i thought. Swapped plugs, wires, coil harness,coil. No change. All the parts i moved to cylinder 1 work fine. Did a resistance and capacitance check from pin 53 of c2 on the ecm to the coil plug and it passed both. ECM has a driver issue on cylinder 7. Going to get psi to replace the ecm under warranty. Only other thing i could do is check the hertz coming from pin 53 to the coil plug connector c. Cant finish tuning until i get this fixed. When driving, i can feel a roughness right by my right foot from the engine from cylinder 7 attempting to fire. Yesterday it fired as i was driving and spun tires when unexpected then stopped firing again.
Old 11-24-2017, 01:21 PM   #94
ILLSMOQ
That’s a bummer
Old 11-27-2017, 10:30 AM   #95
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Wish I had that kind of oil pressure haha. Hopefully the ECM change fixes the issue. Good luck
Old 01-04-2018, 10:01 PM   #96
Totalrecall
Drives: frs
did it explode?
Totalrecall is offline   Reply With Quote
Old 01-05-2018, 05:54 AM   #97
kurty85
Originally Posted by Totalrecall View Post
did it explode?
Excuse me? No I am waiting for the replacement ECM to be shipped to me. Don't make smart ass comments if you don't know what your talking about.
Old 01-15-2018, 06:35 AM   #98
kurty85
Got the replacement ECM installed and no misfire codes. Loaded my tune with HP Tuners. Working on SD tuning right now, then some MAF tuning later. Seems to be running much better. Tires broke loose at 6k rpm today. That was a bit frightening on a very bad road. Thing gets no traction now! Need to do some tire/aero/suspension work to get it settled down. First autocross is the 21st. Hopefully I can make it by then.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Not just another ls swap killin'_for_a_livin' Member's Car Journals 7 08-28-2016 05:58 PM
WRX SWAP!!! PowderfaceTr. BRZ Photos, Videos, Wallpapers, Gallery Forum 1 02-24-2015 07:29 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 08:59 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
