Old 08-27-2016, 05:17 PM   #1
killin'_for_a_livin'
Drives: 13 scion fr-s, 88 dodge daytona
Not just another ls swap
So everybody can get mad at me for swaping this car ...i seriously don't give a s***. I put a LT1 into my car today. And here are the pictures to prove it. 6.2 liters of shut the f*** up.
Sent from my SM-N920P using Tapatalk
killin'_for_a_livin' is offline   Reply With Quote
The Following User Says Thank You to killin'_for_a_livin' For This Useful Post:
brz fred (08-28-2016)
Old 08-27-2016, 07:54 PM   #2
surfwaxsmitty
Drives: '14 BRZ 6MT
"put" an LT1 in your car! cant deny it, you sure did!
you planning to install?
do your thing man!
surfwaxsmitty is offline   Reply With Quote
The Following User Says Thank You to surfwaxsmitty For This Useful Post:
killin'_for_a_livin' (08-28-2016)
Old 08-28-2016, 08:51 AM   #3
Yea i am i got to save up some cause this engine didnt have a wiring harness and ill have to get a driveshaft as well other than that it will be mostly fab parts. I was going to make this my ongoing build thread. I plan on taking lots of pictures as i get farther down the line but for now this is what i have
Tr6060 with mcleod dual mass flywheel twin disc clutch and throw out bearin and bellhousing-$2100
LT1 without harness-$3300
Old 08-28-2016, 09:29 AM   #4
And this is when the trans got a ride along
Old 08-28-2016, 09:45 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
Does it count as double clutching if you have two trans in your car?
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 08-28-2016, 10:21 AM   #6
Triple clutching if you double clutch and shift the one in the passenger seat
Old 08-28-2016, 10:40 AM   #7
Atropine
Drives: 2021 Toyota Supra 2020 4Runner
Pretty sweet, mounting the LT1 towards the middle of the car will make it more balanced.
Atropine is offline   Reply With Quote
Old 08-28-2016, 04:58 PM   #8
Yea man you know its like perfect 50/50 balanced just like a hoverboat
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
3GR-FSE Swap cf6mech Engine Swaps 0 10-24-2015 01:32 AM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
WRX SWAP!!! PowderfaceTr. BRZ Photos, Videos, Wallpapers, Gallery Forum 1 02-24-2015 06:29 PM
