#57 | |
Drives: 2017 BRZ
![]() Here’s a graph of a gruppe-s uel header run 12 and Tomei is run 11 if I recall correctly. These were 92 oct. Last edited by Barefootdan; 01-04-2018 at 09:37 AM. |
#58 |
#59 | |
Included with your tune, will be revisions (you'll be given instructions and asked to send in logs via e-mail) to individualize the tune to your specific engine, as every engine has minor variation. |
#60 |
Drives: Toyota 86 GTS
Oh awesome! Thanks man. That's pretty much exactly what I was looking for. The Gruppe-S is the equivalent to the PSR here in Australia. Seems it makes a little more top end power than the ACE at the expense of torque at the low-mid range
#61 |
Drives: 2014 GT86
ImportPer4mance: you really are going to compare gains from different dynos charts and base purchase choice on that? :/
At very least try finding charts with stock-unmodified-with-stock-ecu-tune baseline to compare relatively to. |
| The Following User Says Thank You to churchx For This Useful Post: | cjd (01-04-2018) |
#62 |
That's exactly what I'm going to do. Relying on different dyno charts without a baseline stock car is useless haha, I just wanted to see something for the 400. Only issue is that dyno's from members (especially those from Australia) who have the CS400 are pretty scarce, there really aren't many to be found around.
#63 |
Drives: 2014 GT86
Try searching threads here related to headers you are interested in. Try finding dyno charts with them, of course preferably ones with also stock baseline on. "stock car on this dyno usually is ###hp max" is a bit vague and tells just very small bit of story. Also don't mistake "completely stock" baselines, with "stock, but ecu (or just parts of mods)" baselines. Remember also, that to make look variations better, some charts display data with cut lower part and also may have less "smoothing"/"averaging". And don't look just for max numbers. One rarely is at very redline for long periods of time, usually it's just seconds before gear switch. Something like "large area under curve" (btw well attributable to ace's headers) often says much better on overall performance then just slightly higher max numbers, as that "area" means more performance gains across much wider rpm range, especially very important low-mid rpm range, which is mostly used when daily driving, which is what dual-use cars see 99% of mileage. Also pay attention in what gear dyno run is done. I'd look at: 1) gains over stock in "%" at eg. 3-4-5-6-7K rpm, 2) look at shape of curve (eg. if getting rid of torque dip matters to me, or if i care more about low-mid rpm gains over just short performance spike at very top).
Every dyno reads different. It reads different even in different ambient temperatures/air pressure/height above sea level. And different countries may have different quality fuel. And there are variations between even completely stock cars. Try eliminating as much variables as possible, if you want to at least roughly compare different dyno charts. Having stock baseline that you somewhat can expect to be similar is about only thing that at least remotely/roughly/aproximately lets do that. Check relative % gains over it, never absolute numbers. Or you'll just be searching not for part performing best, but rather for dyno that is calibrated to read highest, as you did with that linked chart. Completely wrong to choose by that. Last edited by churchx; 01-04-2018 at 11:48 PM. |
#64 | |
Yeah the fuel quality is a reason I wanted to see Australian dyno's specifically, as our 98 is not as good as USA 92/93, hence I don't expect the gains on a 98 tune to be as big. I managed to find one dyno from an aussie (usng a BRZEdit tune), hopefully some other aussies can post up some stuff if they have any! It's a really expensive product so I want to make sure I make the right decision haha, I only wanna buy headers once. |
#65 |
Drives: UK GT86
Forgot to add it's a Cobra HFC and the manifold, rest of the system is stock AFAIK.
.: Stealth 86 :.
#66 |
Drives: 2013 BRZ (DGM)
I'm looking pretty closely at the CS400 since I think it would be more suited to my driving (mostly DD, some AX) than the A350 but the lack of solid dyno comparisons between the two has me a little cautious. Has anyone got or seen any more charts than what are in this thread? I've heard pretty much nothing but positive anecdotes, but I'm a numbers guy, especially when it comes to dropping ~$1500 on a chunk of hardware.
I guess also on the same thread - exhaust note. I really like what I've heard of the A350 with the rest of the system stock, but outside of a few rough youtubes I haven't heard much out of the CS400. Can anyone who has heard both comment on if they're similar or substantially different? Thanks! |
#67 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Bumping for my dyno I did this morning
CS400, HKS R-Spec high flow cat frontpipe, oem midpipe, TRD muffler; HKS intake duct and drop in filter. I was a little disappointed in the output, but still, good to know what it's putting down!
#68 |
Drives: Crapcan
Don't be. Dyno's read so different, for all you know your car was only putting down 150whp on that dyno stock. Without a baseline and being able to look at the difference between the two all you are really looking at is the curve. I'd kill for a torque curve that looks like that. Mine has the grand canyon in it untill 4k.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | CSG Mike (06-26-2020), new2subaru (06-26-2020) |
#69 | |
| The Following 3 Users Say Thank You to weederr33 For This Useful Post: |
#70 |
Isn't the CS 400 discontinued in favour of 350 for RHD?
| Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results | JDM-dono | Engine, Exhaust, Transmission | 24 | 05-05-2016 04:54 PM |
| Shiv dyno day 2 in lewisville, OFT users custom dyno tunes | malubawla | Southwest | 14 | 11-21-2015 01:53 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
