go_a_way1
Old 12-28-2017, 12:46 AM   #3599
swarb
Originally Posted by DarkSideFRS View Post
i am lowered on TRD springs with -1.7F and -1.3R camber... would i rub on 17x9 +38 rims on 245/40/17?
No rub. You good. Nice setup.
The Following User Says Thank You to swarb For This Useful Post:
Teseo (12-31-2017)
Old 12-29-2017, 01:47 PM   #3600
DarkSideFRS
Drives: 2013 pearl white FR-S
thanks for the input. I was also looking at some posts and ppl are also saying that 17x9 will rub due to excessive camber. Are you speaking from personal experience?
DarkSideFRS is offline   Reply With Quote
Old 12-29-2017, 11:23 PM   #3601
jz86
Drives: Toyota 86
Have searched rocket bunny in this thread and didn't see my specific question so here goes. Looking at RB v2 with Tein Super Racing at 1.4" drop. What's the absolute max contact patch I can get in the rear? Would like to run 305s or even 315s on 18" wheels if possible.
Bonus question, can I fit 255s or wider up front? What about with these? https://www.maperformance.com/produc...SABEgIokvD_BwE
jz86 is offline   Reply With Quote
Old 12-30-2017, 12:09 AM   #3602
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This guys build is epic, and one of the only with super massive wide tires. Read the whole thread. See the huge amount of work that's been done. He's listed all the parts needed. Hope you have a big pile cash.
http://www.ft86club.com/forums/showthread.php?t=74391
Also, at least read the first page of this thread too. I've read the whole thing. Great info!
http://www.ft86club.com/forums/showthread.php?t=41083
GOOD LUCK.
I LIKE TIRES!
Old 12-30-2017, 12:27 AM   #3603
swarb
17x9 +35 RPF1's with 245/40 with camber bolts fit with no problem.
It really depends on a number of factors.
1. Tire, a wide 200tw tire runs wide when compared to a street tire.
2. Every car slightly different.
3. Inside lip/barrel is shaped different for every wheel.
If you are worried, you can buy a pair of 3mm spacers for the front to make them fit like a +35 and go from there. The rears will clear easily. While the fronts will be very tight... we are talking 5mm or less here... not exactly a lot space to work with.
Leonardo (12-30-2017)
Old 12-30-2017, 04:48 AM   #3604
jz86
Drives: Toyota 86
GOOD LUCK.
Thanks for the nice reply. This car is going to hopefully get a 600+ hp 2j swap, but going to build "from the outside in" to get things ready for the power. Once things get going I'll start a thread
The Following User Says Thank You to jz86 For This Useful Post:
Leonardo (12-31-2017)
Old 12-30-2017, 12:27 PM   #3605
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thanks. But from my experience the fact that you are saying "Hopefully".... bro you may as well say never. None of this talk impresses anyone here. Guys doing swaps have lots of money (or lots of debt).
Like yoda says "Do or Do not, there is NO try"
Just have fun with the car, post pics of mods you have made, you can fit 275 front 285 rear on a stock body, a 2jz swap is 20 grand minimum.
GOOD LUCK, welcome to the Forum, and
I LIKE TIRES!
Old 12-30-2017, 08:52 PM   #3606
jz86
Drives: Toyota 86
Thanks, I think that’s generally good advice! I wasn’t trying to impress with my 2J comment, just explain why I want that much rubber. My “hopefully” refers to my short attention span when it comes to projects as much as anything but you’re right that it’s not cheap either. I think even 20k is quite low for a reliable result. Still, there are a lot slower and less fun cars out there in that price range!
Yeah, might not do it. But then again I might. If life’s about the journey, a project car is way more appealing than rolling up to the dealership and driving off with something.
Old 12-31-2017, 01:30 AM   #3607
funwheeldrive
I'm looking at a set of wheels right now that are 16x7.5'' with an offset of +48.
Would this fit ok? Usually I see 16'' wheels with a lot lower of an offset.
Old 12-31-2017, 01:55 AM   #3608
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Those will fit, no problems. You could use a 225/50, if you wanted a little more tire.
I LIKE TIRES!
funwheeldrive (12-31-2017)
Old 12-31-2017, 02:28 AM   #3609
funwheeldrive
Thanks. The ad says that the central hub diameter is 61mm, that should be fine right?
I'll probably end up using either a 205 or 215 tire.
The Following User Says Thank You to funwheeldrive For This Useful Post:
Old 12-31-2017, 11:29 AM   #3610
churchx
churchx's Avatar
Drives: 2014 GT86
If it's for winter tires, then they are better to run narrower, eg. 205. Lugnuts/wheels on ours are lugcentric. It's not must have to have hub bore exactly same. As in same hub bore will ease mounting/centering, but should be safe enough to drive even with wheel bore bigger then stock axle diameter (56.1mm). For ease of mind you can buy spacer rings.
Check though, what nut seat wheels in add have. If they are of most common for aftermarket wheels 60degree conical seat (coincidentally same as stock) you should be ok. If it's flat seat like eg. VW's wheels, you may need to get other lugnuts or adapters.
funwheeldrive (12-31-2017), Leonardo (12-31-2017)
Old 01-02-2018, 04:24 AM   #3611
Mehrshad
GT86PersianClub
Mehrshad's Avatar
Drives: 2014 Crystal Black Silica GT86
Hey guys
I found a Rays te37 with good price,
But the size is 18x9,5 +12 and 18x10,5 +15
You think its gonna fit stock 86?i really love te37’s
Mehrshad is offline   Reply With Quote
Old 01-02-2018, 01:45 PM   #3612
swarb
Originally Posted by Mehrshad View Post
Hey guys
It would not fit without major modification to have 5++ camber and super stretched tires like 215's up front and 225's in the rear.
Leonardo (01-02-2018)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
