Old 07-03-2012, 12:42 PM   #85
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Originally Posted by DarrenDriven View Post
It is a plastic panel in the rear, not metal.
Cheers Darren, should have thought about that. Dont take ownership until september but should have looked at the pics more closely before commenting.... Makes things more complicated.. I dont know if u could just plastic weld it without warp.... With metal i could have done myself and controlled temps but plastic welding means someone else doing it and possibly making a mess.....
Looks like ill be leaving the toyota badges on and just deleting the GTS....
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
Old 07-03-2012, 01:19 PM   #86
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Someone already brought up welding about a third of the way down the 2nd page of this topic, haha.
I would think that a little bit of epoxy dripped into each hole could then be sanded down and the small panel could be repainted easily enough. Someone is gonna need to do another DIY.
Old 07-05-2012, 12:09 PM   #87
KlafKoon
Drives: 2013 H8R FRS, 03 Miata (Sold)
Could http://www.toyotapartszone.com/oem/t...003-03126.html be for the opposite/fender possibly resulting in the pins being in the opposite orientation so that you don't have to remove the pins on the back of the emblem?
KlafKoon is offline   Reply With Quote
Old 07-05-2012, 01:58 PM   #88
Roadstercycle
FRS Rear Mount Turbo
Roadstercycle's Avatar
Drives: 2013 FR-S Raven, Rear Turbo
Originally Posted by avusblue View Post
Well, I finally got the side "Boxer 86" emblem installed on the back, and I think it looks great.
Ordered the emblem from the parts counter at my Toyota dealer: $41.01. Part number SU003-03125:
Here's the "before":
Got out my fine-point panel removal tool, a soft, lint-free wipe, and some goo-gone:
Using the correct tool for the job is very important for any job. In this case it made emblem removal a piece of cake. The old emblem came off in a jiffy and did not mar the surface whatsoever. Super easy. Took 10 seconds. I think it was helped by the 100-degree heat we had today. Used my fingers to roll up the small amount of "goo" left behind. Barely needed the goo-gone:
Note the two peg-holes and the small dimple in the trunk lid molding. This dimple makes it very easy to align and center the replacement emblem. Also note, the alignment pegs on the new emblem are the opposite layout as the original emblem:
Easily remedied with a needle nose pliers -- I just broke off the pegs from the new emblem:
Carefully aligned the new emblem, peel, and stick. I did use a pencil to very lightly mark where to line it up, just as a precaution. Voila!:
Here's another view:
Last step -- remove the FR-S emblem to complete the clean-up of the rear view. It came off just as easily as the other one:
So, I'm very happy with the effect. To me it nicely simplifies, and visually cleans up, the rear perspective of the car.
Cheers,
Dave
Looks great, I ordered a couple red 86 side badges to accent my red lined wheels and I will use one of the old side badges for the back. Wanted to do this since I picked up the car Memorial day..
Roadstercycle is offline   Reply With Quote
Old 07-07-2012, 02:55 PM   #89
DetroitJake
DetroitJake's Avatar
Drives: '13 FR-S 6MT / '14 Prius-C
Originally Posted by NeedsmoreCowbell View Post
has anyone messed with the front decal? any holes there?
yes. there are holes in the front. I also wrote up about this. See "Badge Removal" in the cosmetic section of the forum.
DetroitJake is offline   Reply With Quote
Old 07-07-2012, 03:23 PM   #90
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Meanwhile, at the Toyota dealer I spent a little time in the parking lot measuring emblems of the various Toyota models. Hoping to find a US "Toyota T" emblem that matches for the front end of the FR-S.
The "Scion" oval on the front of the FR-S measures 11.0cm across by 7.5cm tall. Lo and behold, the "T" oval on the trunk lid of the 2012 Corolla (i.e. post mid-cycle facelift) seems to measure exactly the same.
It is this version of the Corolla (note the chrome bar across the back end and the updated taillights. It can be either an "LE" or an "S" model, they both use the same oval "T" emblem):
Not this Corolla (pre-2012 facelift), because it has a larger "T" emblem:
So, I ordered that Corolla emblem from the parts counter, and it should come in by the end of the week. I will let everyone know how it goes.
Cheers,
Dave
How much were the emblems?
Is the rear scion emblem the same size as the front emblem?
quik1987 is offline   Reply With Quote
Old 07-07-2012, 03:28 PM   #91
quik1987
quik1987's Avatar
LOL
The Following 2 Users Say Thank You to quik1987 For This Useful Post:
Fish (07-07-2012), JDMSushi (07-10-2012)
Old 07-07-2012, 03:46 PM   #92
Fish
Fish's Avatar
Drives: 2015 Yuzu RS1.0 Scion FR-S #893
Originally Posted by quik1987 View Post
LOL
lol! Yeeees!!
Fish is offline   Reply With Quote
Old 07-07-2012, 11:17 PM   #93
DarrenDriven
NW Region Moderator
I was just saying that I should put Lexus emblems on it today... and you beat me to it.
Old 07-07-2012, 11:20 PM   #94
Kundiethala
Drives: Scion FRS 6M Whitout
LOL
Looks clean!!
Kundiethala is offline   Reply With Quote
Old 07-09-2012, 10:27 PM   #95
KlafKoon
Cheers,
Dave
Any update on whether the corolla badge fits correctly? Are the front and rear emblems of the frs the same size? And would the same corolla emblem work for the rear of the car?
Old 07-09-2012, 10:54 PM   #96
Jayde
Jayde's Avatar
Jayde is offline   Reply With Quote
Old 07-09-2012, 11:40 PM   #97
DarrenDriven
NW Region Moderator
I was at the dealer today and they wanted $32 for the rear Corolla emblem... that is $2 more than actually ordering the JDM one through Carson Toyota!
Old 07-11-2012, 10:42 PM   #98
NeenaChrry
NeenaChrry's Avatar
Drives: 2013 FR-S Firestorm Automatic
Boxer 86 Emblem on Front?
Cheers,
Dave
Looks Great! Nice Job!
Has anyone put the Boxer 86 emblem on the front?
NeenaChrry is offline   Reply With Quote
teq emblem
Debadging - How difficult will it be? Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 86 06-24-2014 10:49 PM
