Drives: 2013 Subaru BRZ
Catch can fittings
Hey this is my first post, I got my BRZ a few months ago and have been working on it day and night. It had a turbo from the previous owner but I am re-doing everything. I am having a larger baffled catch can welded up and am switching the barbs on the block to AN fittings. However I cant seem to lock down what thread size the crank case vent and pcv valve are. I have searched far and wide and they seem to be 3/8 npt but I want to be sure before I order all the wrong fittings. Thanks!!!
#2 |
Anyone? I spoke to someone who said the pcv is 3/8 bspt confusing me even more. Pleeeeease help.
#3 |
anyone?
#4 |
Drives: 2014 BRZ
3/8 NPT threads into the block if you are deleting the PCV, I am absolutely 110% positive.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
#5 |
We are talking the crank case vent ( below the left side of the intake manifold if looking from the front of the car) and the pcv (under the ac compressor) correct? From my understanding I can vent both to atmo with a baffled catch can. Radium makes an AN adapter for the pcv which they claim to be bspt not npt.
#6 |
If you want to check, go to Home Depot get a brass fitting. Try it out, heck you can even return it.
| Zeitronix fittings? | Tal | DIY (Do-It-Yourself) Guides | 2 | 07-17-2019 08:51 PM |
| Do Blowoff valves all have the same fittings? | apelpapa | Forced Induction | 1 | 06-18-2016 03:00 PM |
| Replacing oil cooler line fittings? | 1Cor10:23 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 09-17-2015 01:43 AM |
| Aeroquip socketless AN fittings / hose question | brillo | Engine, Exhaust, Transmission | 1 | 07-14-2013 07:31 AM |
| Dual Catch Can, hoses and fittings | Sportsguy83 | Engine, Exhaust, Transmission | 9 | 02-21-2013 01:13 AM |
