Old 12-04-2017, 06:07 PM   #505
alchemy
Drives: 86 GTS 2015
Has anyone tried this and gotten it to work on a completely stock exhaust system? :O
alchemy is offline   Reply With Quote
Old 12-04-2017, 07:10 PM   #506
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The OEM muffler will completely kill any sound you get. I did it with the OEM system and a Berk muffler delete with the cats gutted and it worked great. I don't know how much sound you'll get with the cats intact- you'd damage the cats eventually anyway.
guybo is offline   Reply With Quote
Old 12-05-2017, 08:57 PM   #507
Totalrecall
Drives: frs
Yes i tried it on a stock header, catback n1.... It works somewhat, Not anywhere near enough to keep tune and burn stock header though lol. Getting catless will for sure be fun though
Totalrecall is offline   Reply With Quote
Old 12-07-2017, 02:22 PM   #508
liu875684119
Drives: FRS-Released Series 1.0
Originally Posted by cwvisual View Post
Had this same issue. I tried to edit the xml and got the second row added but it did not run properly.
Just edit that row and ignore the other (since you don’t have it). I played it safe and began retarding at higher rpms since we don’t have a second row for startup temperature. Just don’t let it rev that high while your engines warming up.
Hi, I am currently in OFT stage 1 with the backfire tune, and I am trying to implement the off-throttle thing. Mine is a D00D 6AT version. However, when I open the bin file in Romraider, I cannot locate the Fueling--Overrun folder. And the table for Base time idle(In-gear) is really strange.
https://imgur.com/1sfuqLd
Is this file broken something? I did flash it in my car before and it was fine.
Thank you!
liu875684119 is offline   Reply With Quote
Old 12-07-2017, 03:25 PM   #509
elBarto
elBarto's Avatar
Drives: Toyota GT86
Thank you!
Update your definitions, use Wayno's or Kodename47 defs. The OFT's are outdated. Unless you really know what you are doing do not edit your definition, there is a chance that you brick your ECU.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 12-08-2017, 03:11 AM   #510
liu875684119
Thanks for the information! Do you know where to find those definitions?
Old 12-08-2017, 04:13 AM   #511
steve99
Drives: FT86
If your using OFT its not going to be that easy as the defs those guys did are for B01D not D00D.
If you had tactrix/ecuflash you could just use B01D rom and def.
Otherwise your doing to need a hacked rom and def to fool oft
defs are here but they are incorrect calid for you
http://www.ft86club.com/forums/showp...&postcount=411
Old 12-13-2017, 11:22 PM   #512
steve99
Drives: FT86
Originally Posted by Evangelion View Post
So I've tried everything regarding the Base Timing B map, and my car still does not produce any popping. My car is a 2017 86 if it matters.
My setup is N1, Tomei UEL, and a Invidia catless nonres FP.
Can't figure this out.. anyone mind chiming in?
Should pop fine doing just base B are you putting in negative numbers ??
you will need to feather throttle on overrun for more pops
Old 12-14-2017, 01:09 AM   #513
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Nice username.
Originally Posted by humfrz
I'm old and lazy
Old 12-14-2017, 09:51 AM   #514
bababooey
Drives: BRZ SWP Limited -6MT
@guybo - u still running this feature? did messing with the values ever change anything?
ive got -6 plugged in down the line in first column. while i usually get a nice pop (not shotgun bang) between upshifts, the popcorn off throttle is growing old, especially in first in parking lots. stock FP, aftermarket all components.
anyone know of a way to retain the upshift pop without going catless FP?
bababooey is offline   Reply With Quote
Old 12-14-2017, 04:12 PM   #515
guybo
Huge E85 fan!
guybo's Avatar
I kept dialing back the timing (retarding it less) until I got the sound to where I wanted it. I think I actually got into positive territory before it was unobnoxious enough to run. I wanted burbles, not pops or shots.
Right now I'm on the pretty much stock Stage 2, but I still keep the other tune in my back pocket, I may go back
Old 12-21-2017, 03:05 AM   #516
wasabiseaweed
Drives: 2017 BRZ Performance Package
So right now I have -15 in the .15 column and I get some pretty solid burbles, though I want gunshot style pops. Should I go down to -5? For some reason the louder pops are completely unpredictable...
I have a Borla UEL, invidia resonated catless front pipe, and an n1, though my pops aren’t as ridiculous as I want them ��.
wasabiseaweed is offline   Reply With Quote
Old 12-21-2017, 09:49 AM   #517
bababooey
ive got -6 and similar results to yours on decel. no shotgun blasts, but a nice pop on most upshifts. im willing to give up the burbles for a single pop.
Old 12-22-2017, 05:44 AM   #518
guybo
Huge E85 fan!
guybo's Avatar
Are you guys catless? Because even at -5 I got gunshots sometimes. Hell at -9.96 I got AK47 gunfire!
I went back and re-did my tune (changed FFS and LC too) and I changed the B table some and I'm popping again. not a lot of burbling though (my new Works axleback really changes the sound from when I had a Berk dual exit). It sounds good now.
Between 2800-4000 RPM I advanced the timing because in that range it gets obnoxious
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
