Old 12-21-2017, 10:31 AM   #57
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by Tokay444 View Post
My guess is neither of you have ever measured torsional rigidity before and after a proper cage install, and are talking out of your asses.
To quote you, "show your math". The internet is devoid of any info regarding even just OEM FT86 chassis rigidity numbers, let alone with a cage, so please fill us all in. And please do so in industry standard Nm/deg format. Unless YOU'RE the one talking out your ass.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 12-21-2017, 10:37 AM   #58
Tokay444
You have?
A proper cage install in a well engineered, dedicated racecar is a rare thing. We are talking about slapping something into a modified street car. The effect is not going to be the same. To say that "A cage will most DEFINITELY increase rigidity, and likely by a fair margin" is not a catch all nor accurate statement by any means.
A proper cage*
Old 12-21-2017, 10:39 AM   #59
Tokay444
Yet there are copious amounts for other chassis.
Are you saying that the same type of engineering used to design a proper roll cage for another platform, would not translate to this one?
Old 12-21-2017, 10:45 AM   #60
venturaII
venturaII's Avatar
I'm not debating crash safety. I'm saying adding a cage to our cars does not necessarily equate to a change that has a positive effect on performance, and until you can provide numbers not only quantifying the changes made, but also showing a clear improvement in performance as related to those changes alone, your claim is baseless. Or is it really just because racecar?
Old 12-21-2017, 11:03 AM   #61
A proper cage*
Install*
Old 12-21-2017, 11:05 AM   #62
Tokay444
I never said it added performance. I argued it added rigidity.
Old 12-21-2017, 11:42 AM   #63
venturaII
venturaII's Avatar
And your argument was ice sliding off your roof. Not quite the level of research needed to support such a claim.
Old 12-21-2017, 11:43 AM   #64
Tokay444
That's just a real world daily driving situation in which I notice it. It wasn't an argument. It was an observation. Not seeing where you're going with this.
Old 12-21-2017, 01:01 PM   #65
ILLSMOQ
Drives: 2017 WR BLUE BRZ
So sifting though...unless it’s tied to many points throughout the car/cage (like Zeros example) and actually tied to the subframes, a simple 6 or 8 point cage probably isn’t going to add enough support/rigidity to be worth the trouble.
Do we all agree on that?
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Tcoat (12-21-2017)
Old 12-21-2017, 02:07 PM   #66
venturaII
venturaII's Avatar
I think a better question would be: why do you feel like rigidity needs to be added, and how can you be sure a cage is adding it in areas of any use? I understand you're making more power, etc, but the bottom line is that if the power hasn't cause the chassis to flex any more than it was before, why go to the bother?
Old 12-21-2017, 02:20 PM   #67
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Nobody gives a shit about unit choice, give it to me in stone*fathom/minute and I'll punch it into google and give you mg*in/rad AND Nm/deg in under two minutes.
Quote an SAE testing standard or gtfo.
ineedyourdiddly
Old 12-21-2017, 02:24 PM   #68
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
OK GUYS
The Following 3 Users Say Thank You to chaoskaze For This Useful Post:
nikitopo (12-27-2017), strat61caster (12-21-2017), Ultramaroon (12-21-2017)
Old 12-21-2017, 02:35 PM   #69
venturaII
venturaII's Avatar
My point was more to be sure to use a recognized measurement standard than the actual units used. "My car feels stiffer" isn't acceptable.
The Following User Says Thank You to venturaII For This Useful Post:
Tcoat (12-21-2017)
Old 12-21-2017, 03:00 PM   #70
Get a far better bang for the buck with a proper stiffening kit. With a kit your are getting stiffening where the car needs it not at some random points throughout the car.
ILLSMOQ (12-21-2017)
HELP: Spoon Front Subframe Rigid Collar Install nichiolas DIY (Do-It-Yourself) Guides 1 12-25-2016 07:44 AM
SPOON rigid collars install mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 11-16-2015 03:24 PM
Rigid Collars? Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 11-04-2015 01:38 AM
New Rigid Industries Capture LED Light w/ Built in GoPro could be sweet for the track 86_Insider Cosmetic Modification (Interior/Exterior/Lighting) 0 07-02-2015 07:53 PM
