Old 12-18-2017, 11:57 PM   #1
ILLSMOQ
Drives: 2017 WR BLUE BRZ
How rigid is this chassis?
Got to thinking about that tonight. I’ve been drilling holes and moving metal to fit all this power and hardware into this car. I’m noticing that everything bends, drills, stretches and tears pretty easily...started wondering at what point do you need to add a cage to strengthen the chassis?
ILLSMOQ is offline   Reply With Quote
Old 12-19-2017, 02:17 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
When you are required by a race track.
Or when you have 5 point harness and need a roll bar as per scca rules. Or at least that was the new rule with having 5 point harness.
Old 12-19-2017, 07:16 AM   #3
ILLSMOQ
Thanks but I’m not talking about race track rules...I’m talking about stresses on the unibody and chassis flex. The seems on this car are spot welded and glued together, they come apart pretty easily. It was designed for 200hp right? Doing an engine swap, we are throwing double or triple or more hp at it. Even the subframes are not super beefy...the sheet metal in between the subframes is pretty weak.
Some others that have done swaps may be able to answer, how well does the car seem to handle the extra power and torque?
Old 12-19-2017, 08:21 AM   #4
Tokay444
Anti stance.
Tokay444's Avatar
Not very. It twists like a wet noodle.
Old 12-19-2017, 08:30 AM   #5
The car is designed to crumple on impact and absorb the forces instead of the driver. If you "beef" it up too much you negate all of that engineering and risk being pulped in a crash.
Conversely if you start drilling holes, tearing and stretching things then it may crumple more than it should and crush you.
When you swap engines you pretty much change the whole engineered safety aspects of the car and there is not much you can do about it. It is the compromise and risk that you have to accept.
Old 12-19-2017, 09:57 AM   #6
ILLSMOQ
Starting to think a cage of some sort is probably a good idea.
Old 12-19-2017, 10:02 AM   #7
gtpvette
Drives: 2015 FRS - FFR GTM
With the HP you're going to install,,, it certainly couldn't hurt. What do you think one would run,,,, $3k or so??
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 12-19-2017, 10:32 AM   #8
Is this going to be a street car? Cages are designed to be used with a helmet and can be very hazardous when used on the street without one.
Old 12-19-2017, 10:34 AM   #9
e1_griego
e1_griego's Avatar
Drives: Many
ITT: a bunch of people who haven't played with actually floppy chassis from early 90s japanese cars.
e1_griego is offline   Reply With Quote
Old 12-19-2017, 11:12 AM   #10
ILLSMOQ
Definitely a smart thing to think about...and I hadn’t thought about that. It’s a street/track toy.
I really don’t want a cage in it but I think this thing is going to need some rigidity added to it.
I’m thinking something along the lines of this...
Are there any sort of sub frame connectors available for these cars?
Old 12-19-2017, 11:15 AM   #11
ILLSMOQ
They are all over the place...few hundred to a few thousand.
Old 12-19-2017, 11:22 AM   #12
cjd
cjd's Avatar
Drives: 2017 BRZ
For safety, you typically need a fixed back seat and helmet once you get a roll bar in. And a helmet on the street is usually not legal.
The chassis is reasonably stiff for what it is, but that's because of how it's engineered. It doesn't have to be thick materials or insanely strong glues, etc; it's all in using the materials so they're strong in the direction they will be stressed.
Old 12-19-2017, 11:37 AM   #13
ILLSMOQ
Hmm, it did feel pretty tight the few times I drove it before I started the swap.
Maybe it is strong enough when stressed as intended...but yeah it definitely seems pretty flimsy when I’m banging on it with a hammer lol
Old 12-19-2017, 12:16 PM   #14
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I think having a sheet of aluminum bead rolled for strength behind the rear seat isn't a bad idea, or a copy of Spencer Fabrication brace
DustinS is offline   Reply With Quote
HELP: Spoon Front Subframe Rigid Collar Install nichiolas DIY (Do-It-Yourself) Guides 1 12-25-2016 07:44 AM
SPOON rigid collars install mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 11-16-2015 03:24 PM
Rigid Collars? Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 11-04-2015 01:38 AM
New Rigid Industries Capture LED Light w/ Built in GoPro could be sweet for the track 86_Insider Cosmetic Modification (Interior/Exterior/Lighting) 0 07-02-2015 07:53 PM
