#29 | |
This is a community and as such you will get both the info you want and some that you don't. Lashing out at the people with answers you don't like won't stop them and just makes you look as bad.
| The Following User Says Thank You to Tcoat For This Useful Post: | ILLSMOQ (12-19-2017) |
#30 |
Listen guys, we all appreciate the hostility, but let's get back to the subject on hand. If you're driving your car in a manner that would be deemed "dangerous" on highway roads, it's a good idea to have a cage.
Let's all just agree with me and be done with it. |
| The Following User Says Thank You to Skeneypoo For This Useful Post: | ILLSMOQ (12-19-2017) |
#31 | |
Drives: 2017 WR BLUE BRZ
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | Tcoat (12-20-2017) |
#32 |
With or without a helmet???
#33 |
Drives: 2017 BRZ
You can use dial indicators and cameras to aid in deciding on whether to reinforce the subframe-chassis hard points.
One option is to build a rear strut bar that ties into the subframe mounts. That would give you local rigidity while retaining some safety for street driving. You'd lose some of the rear crumple zone, but wouldn't have the safety risks of a full cage. |
#34 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
I mean our stock chassis has been in the 7s already
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#35 |
Drives: 2017 BRZ
7's with no cage?
#36 | |
A cage is intended for a dedicated race car and is to be used in conjunction with other safety devices.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#37 | |
Drives: 2013 Scion FR-S Asphalt [Gray]
I was actually hoping you'd respond with.. "Putting a Porsche flat 6 in there so jokes on you!" But I guess not. Just because you don't like the information doesn't make it false but don't mind me, I am just one ricer in a slow and uncomfortable car among thousands passing through here.
#38 | |
Drives: 2013 Ultramarine FR-S
He is simply asking if the chassis could handle the power/torque increase without causing any negative effects. I don't blame him for asking. Coming in and responding to a thread in which you have no direct experience and spreading speculations without even know what is going on doesn't help.
#39 | |
, You were so focused on center of gravity and body roll, I completely missed where you actually addressed any part of my comments.Also, I wouldn’t call your information “information”...it’s more of an opinion and you know what those are like. Everyone’s got one. You can flush what comes out of yours next time thanks
#40 |
Read through the swap thread and it doesn't look like you have compromised the integrity of the chassis to any great degree. Looks like it was pretty well thought out.
I would skip the idea of a cage for adding strength though. Any increase in rigidity it may give is poorly located and of little value anyway. A long piece of pipe with several bends in it and a very small contact footprint with the car is not going to gain you much. If I was in your position I would go with one of the available brace kits. You may have to do some minor surgery to get some to work with your engine though. https://www.frsmod.com/products/fr-s...it-for-frs-brz
#41 | |
Wish I would have seen that kit before ordering the Cusco strut tower brace. Any idea if it’s aluminum or steel? Looks pretty good. Those items will help for sure since the subframes are not very robust. I had to bend the rear subframe to open it up a bit to be able to slip the 8.8 diff into place...it bent pretty easily with a pry bar. Last edited by ILLSMOQ; 12-20-2017 at 03:03 PM. |
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | venturaII (12-20-2017) |
#42 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | ILLSMOQ (12-20-2017), strat61caster (12-20-2017) |
| HELP: Spoon Front Subframe Rigid Collar Install | nichiolas | DIY (Do-It-Yourself) Guides | 1 | 12-25-2016 07:44 AM |
| SPOON rigid collars install | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 137 | 11-16-2015 03:24 PM |
| Rigid Collars? | Calum | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 11-04-2015 01:38 AM |
| New Rigid Industries Capture LED Light w/ Built in GoPro could be sweet for the track | 86_Insider | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-02-2015 07:53 PM |
