Old 12-19-2017, 09:44 PM   #29
Originally Posted by ILLSMOQ View Post
Not at all, I posed my question about the rigidity of the chassis and its ability to handle the extra power. There were a few relevant responses , including some of yours which are appreciated.
...Also had some irrelevant responses, that have nothing to do with the question and one response in particular that had more of a condescending, "keep the 86 as it was designed, you've ruined it" tone to it, hence my response.
By your reaction to my response I wonder are you including yourself in the "Genius" group I mentioned and taking offence or actually just curious as to the nature of my response?
Just curious more than anything but your cryptic statement will have more than one person with a sincere response wondering if you included them.
This is a community and as such you will get both the info you want and some that you don't. Lashing out at the people with answers you don't like won't stop them and just makes you look as bad.
ILLSMOQ (12-19-2017)
Old 12-19-2017, 09:57 PM   #30
Skeneypoo
Skeneypoo's Avatar
Listen guys, we all appreciate the hostility, but let's get back to the subject on hand. If you're driving your car in a manner that would be deemed "dangerous" on highway roads, it's a good idea to have a cage.
Let's all just agree with me and be done with it.
Skeneypoo is offline   Reply With Quote
The Following User Says Thank You to Skeneypoo For This Useful Post:
Old 12-19-2017, 10:01 PM   #31
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Thanks and you’re right.
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Tcoat (12-20-2017)
Old 12-19-2017, 10:02 PM   #32
ILLSMOQ
With or without a helmet???
Old 12-19-2017, 11:01 PM   #33
gtengr
Drives: 2017 BRZ
You can use dial indicators and cameras to aid in deciding on whether to reinforce the subframe-chassis hard points.
One option is to build a rear strut bar that ties into the subframe mounts. That would give you local rigidity while retaining some safety for street driving. You'd lose some of the rear crumple zone, but wouldn't have the safety risks of a full cage.
gtengr is offline   Reply With Quote
Old 12-19-2017, 11:14 PM   #34
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I mean our stock chassis has been in the 7s already ��
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 12-19-2017, 11:31 PM   #35
gtengr
Drives: 2017 BRZ
7's with no cage?
Old 12-20-2017, 06:15 AM   #36
No it is not.
A cage is intended for a dedicated race car and is to be used in conjunction with other safety devices.
Cole (12-20-2017), DustinS (12-20-2017), JoeeStacks (12-21-2017), Skeneypoo (12-21-2017)
Old 12-20-2017, 11:15 AM   #37
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
Not irrelevant...It was clearly said that the chassis felt tight when you drove it stock implying that it will retain this same "tightness" afterwards. I was merely explaining why that is not correct.
I was actually hoping you'd respond with.. "Putting a Porsche flat 6 in there so jokes on you!" But I guess not.
Just because you don't like the information doesn't make it false but don't mind me, I am just one ricer in a slow and uncomfortable car among thousands passing through here.
TorontoNat is offline   Reply With Quote
Old 12-20-2017, 11:46 AM   #38
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
He isn't just slapping some engine in there. He is using well thought out mounts which put the engine as low and far back as possible while still retaining enough clearance for everything to work as intended. The engine/transmission combo he is using is somewhere around 60-80lbs more than the factory engine/trans combo, and most of the weight is gained in the transmission, which is low and center. Factory Weight Bias is retained, while more than tripling the factory power output (without use of a turbo).
He is simply asking if the chassis could handle the power/torque increase without causing any negative effects. I don't blame him for asking.
Coming in and responding to a thread in which you have no direct experience and spreading speculations without even know what is going on doesn't help.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
ILLSMOQ (12-20-2017), Jaden (12-24-2017)
Old 12-20-2017, 11:55 AM   #39
ILLSMOQ
Welcome back Mat, You were so focused on center of gravity and body roll, I completely missed where you actually addressed any part of my comments.
Also, I wouldn’t call your information “information”...it’s more of an opinion and you know what those are like. Everyone’s got one. You can flush what comes out of yours next time thanks
Old 12-20-2017, 02:23 PM   #40
Read through the swap thread and it doesn't look like you have compromised the integrity of the chassis to any great degree. Looks like it was pretty well thought out.
I would skip the idea of a cage for adding strength though. Any increase in rigidity it may give is poorly located and of little value anyway. A long piece of pipe with several bends in it and a very small contact footprint with the car is not going to gain you much.
If I was in your position I would go with one of the available brace kits. You may have to do some minor surgery to get some to work with your engine though.
https://www.frsmod.com/products/fr-s...it-for-frs-brz
DustinS (12-20-2017), ILLSMOQ (12-20-2017)
Old 12-20-2017, 02:50 PM   #41
ILLSMOQ
Wish I would have seen that kit before ordering the Cusco strut tower brace. Any idea if it’s aluminum or steel? Looks pretty good. Those items will help for sure since the subframes are not very robust. I had to bend the rear subframe to open it up a bit to be able to slip the 8.8 diff into place...it bent pretty easily with a pry bar.
venturaII (12-20-2017)
Old 12-20-2017, 03:00 PM   #42
Wish I would have seen that kit before ordering the Cusco strut tower brace. Looks pretty good. Those items will help for sure since the subframes are not very robust. I had to bend the rear subframe to open it up a bit to be able to slip the 8.8 diff into place...it bent pretty easily with a pry bar.
They are more robust than they seem. They are engineered to take stress in a certain direction. Come at it from another direction or apply force outside of the design criteria and they will bend easily but try to force it to move from the proper angles and it will be strong as hell. The thing is that the design is meant to operate as a whole so even though individual pieces may seem weak when you put it all together it is very strong. If every piece was strong individually the car would be about twice it's weight.
ILLSMOQ (12-20-2017), strat61caster (12-20-2017)
HELP: Spoon Front Subframe Rigid Collar Install nichiolas DIY (Do-It-Yourself) Guides 1 12-25-2016 07:44 AM
SPOON rigid collars install mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 11-16-2015 03:24 PM
Rigid Collars? Calum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 11-04-2015 01:38 AM
New Rigid Industries Capture LED Light w/ Built in GoPro could be sweet for the track 86_Insider Cosmetic Modification (Interior/Exterior/Lighting) 0 07-02-2015 07:53 PM
