Old 02-11-2014, 09:03 AM   #15
frslee
Just drive it
Drives: 13' FR-S
This is my first manual car, but I think I'll be able to make 120k miles.
frslee is offline   Reply With Quote
Old 02-11-2014, 10:20 AM   #16
wparsons
wparsons's Avatar
Originally Posted by Superhatch View Post
I'm at 54,xxx miles right now and I think that my stock clutch might be on it's way out. Getting in to first from neutral is starting to get tougher than it's been before. At 55K I'm due for another trans/diff fluid change, but it feels like more than older fluids are causing this tough engagement.
This seems to be about the right time, but just wondering what other people thought.
If you're having a hard time getting into gear that could be the clutch not disengaging properly, which would be either low fluid, bad clutch master, bad clutch slave or air in the clutch line.
If the clutch is worn out you'll have it slip under acceleration. If it's not slipping, you're 100% fine on the clutch end.
flickr
Old 02-11-2014, 10:27 AM   #17
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by Basket Case View Post
I would expect 50-60k with hard driving.
My WRX's clutch was beginning to wear around 53k miles, but the throw out bearing disintegrated first.
^GT5 Replay Photo Mode^
Old 02-11-2014, 11:55 AM   #18
arghx7
Drives: car
Originally Posted by 6-Shift View Post
Honestly if you're worried about it, get a stage one clutch. It's not an extremely expensive replacement and it's still close to stock but will have a little more grab than stock. Might as well lol.
If he wants to replace the clutch, and wants more clamping force (with all that entails), then yes he should get a clutch rated for more. Keep in mind though that there's really no guarantee that any aftermarket clutch is going to last as long as a stock one if the driving style and type of use is similar.
Old 12-13-2017, 11:20 AM   #19
rbuecker
Drives: 2015 BRZ
im at 109,000mi so far so good (from 12/13/2017)
edit: lost a rod in the motor 9 days later
still stock clutch and brakes 117,000 mi (4/20/2018)
for reference picked up the car august 2014
rbuecker is offline   Reply With Quote
The Following User Says Thank You to rbuecker For This Useful Post:
TorontoNat (01-26-2018)
Old 12-13-2017, 05:27 PM   #20
toyubie
Drives: none
Keep in mind you should be looking into an aftermarket clutch fork if you upgrade to a heavier clutch than stock.
toyubie is offline   Reply With Quote
Old 12-13-2017, 06:44 PM   #21
Teseo
Drives: frs
TOB will go first, when you replace it make sense to swap clutch while you are at it
The Following 2 Users Say Thank You to Teseo For This Useful Post:
Adam_L (01-25-2018), Ultramaroon (12-15-2017)
Old 12-13-2017, 08:14 PM   #22
For a non tracked vehicle ....... how about every other TOB replacement .......??
Old 12-14-2017, 12:06 PM   #23
RallySTI
Drives: 2013 Subaru BRZ
How long do you expect brake pads to last ?
This is a rhetorical question. Clutch is a wear item just as brakes. Life is dictated by usage, driving style and the actuation system controlling it.
RallySTI is offline   Reply With Quote
Old 12-15-2017, 09:13 AM   #24
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
everyone should upgrade the clutch fork, throwout bearing, and some of the other transmission stuff no matter what clutch they choose to use. But there are tons of stock clutches out there since so many upgrade those too.
My stock clutch will last forever since it is sitting in a box in my bedroom.
why? is offline   Reply With Quote
Old 12-15-2017, 09:23 AM   #25
ermax
ermax's Avatar
84k on my original clutch. Not the original TOB though.
Old 12-15-2017, 10:01 AM   #26
bababooey
Drives: BRZ SWP Limited -6MT
Id imagine the disc material would outlast the TOB, except if standing burnouts and the like were regularly preformed.
bababooey is offline   Reply With Quote
Old 01-25-2018, 06:22 PM   #27
G_Rossney
Drives: 2013 BRZ, Limited, 6spd MT, GBS
Send a message via AIM to G_Rossney Send a message via MSN to G_Rossney Send a message via Yahoo to G_Rossney
My clutch went at 68,270 miles. The car has been tracked a few time. I heel/toe daily. I thought it might last longer, but I do drive a little hard on the daily.
G_Rossney is offline   Reply With Quote
Old 01-26-2018, 02:13 PM   #28
wu_dot_com
Drives: accord
My clutch went at about 70K.
TOB went out due to cracks, clutch not releasing when press. Upon disassembly, the undamage portion of the clutch friction surface still have plenty of life left.
wu_dot_com is offline   Reply With Quote
Stock clutch $50 obo PineappleFriedRice Transmission and Driveline 2 11-25-2013 01:21 PM
WANTED! Stock Clutch! JD86 Australia Classifieds 1 07-02-2013 10:21 PM
GI: Stock FLywheel and clutch jwjknorr Transmission and Driveline 2 04-15-2013 07:38 AM
How long would you expect coilovers to last? Blue86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-30-2013 04:44 PM
