#15 |
Just drive it
Drives: 13' FR-S
This is my first manual car, but I think I'll be able to make 120k miles.
#16 | |
If the clutch is worn out you'll have it slip under acceleration. If it's not slipping, you're 100% fine on the clutch end.
#17 |
Trust me, I'm the Doctor
My WRX's clutch was beginning to wear around 53k miles, but the throw out bearing disintegrated first.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#18 |
Drives: car
If he wants to replace the clutch, and wants more clamping force (with all that entails), then yes he should get a clutch rated for more. Keep in mind though that there's really no guarantee that any aftermarket clutch is going to last as long as a stock one if the driving style and type of use is similar.
#19 |
Drives: 2015 BRZ
im at 109,000mi so far so good (from 12/13/2017)
edit: lost a rod in the motor 9 days later still stock clutch and brakes 117,000 mi (4/20/2018) for reference picked up the car august 2014 Last edited by rbuecker; 04-20-2018 at 09:44 PM. |
#20 |
Drives: none
Keep in mind you should be looking into an aftermarket clutch fork if you upgrade to a heavier clutch than stock.
#21 |
Drives: frs
TOB will go first, when you replace it make sense to swap clutch while you are at it
#22 |
#23 |
Drives: 2013 Subaru BRZ
How long do you expect brake pads to last ?
This is a rhetorical question. Clutch is a wear item just as brakes. Life is dictated by usage, driving style and the actuation system controlling it. |
#24 | |
Only happy when it rains.
Drives: series.blue
My stock clutch will last forever since it is sitting in a box in my bedroom. |
#25 |
84k on my original clutch. Not the original TOB though.
#26 |
Drives: BRZ SWP Limited -6MT
Id imagine the disc material would outlast the TOB, except if standing burnouts and the like were regularly preformed.
#27 |
My clutch went at 68,270 miles. The car has been tracked a few time. I heel/toe daily. I thought it might last longer, but I do drive a little hard on the daily.
#28 |
Drives: accord
My clutch went at about 70K.
TOB went out due to cracks, clutch not releasing when press. Upon disassembly, the undamage portion of the clutch friction surface still have plenty of life left. |
| Stock clutch $50 obo | PineappleFriedRice | Transmission and Driveline | 2 | 11-25-2013 01:21 PM |
| WANTED! Stock Clutch! | JD86 | Australia Classifieds | 1 | 07-02-2013 10:21 PM |
| GI: Stock FLywheel and clutch | jwjknorr | Transmission and Driveline | 2 | 04-15-2013 07:38 AM |
| How long would you expect coilovers to last? | Blue86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 03-30-2013 04:44 PM |
