Old 12-13-2017, 09:17 PM   #29
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
Another Hard Start
Update:
Tonight I went to start my car, and unlike last time, this time it didn't start at all. On the first crank I held it for about 5 seconds and it sounded like it was about to pick up but nothing. Second crank, no start either. Waited 15 seconds, cranked it a third time and had to hold it for about 6 seconds until it started.
I drove earlier today and didn't have this problem, even though the weather this morning was colder than what it is right now tonight.
Hope this doesn't become an issue...
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 12-13-2017, 11:28 PM   #30
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by itsAlex View Post
Update:
If it's cranking, you are missing one or more of the following, spark, fuel, air. Air is not likely to be the culprit.
Either bring it to a mechanic/dealership to resolve or do the following.
Step 1: when you turn the key to on (not ignition) do you hear the pump in the back priming? Should sound like a buzz for a second or 2. If so, proceed.
Step 2, does everything you expect come on when the key is in the on position?
Step 3, take your battery to an auto parts store and have them test it. If it's good, it should come back fully charged. Doesn't usually cost anything.
Step 4: if battery is good and charged and car still doesn't start, check all cables and ground straps for damage or looseness. If car starts, but after a while you have this issue again, get the alternator tested. Also usually doesn't cost anything.
Step 5. Do you always fill up at the same place? Might be consistently bad gas with water seeping into the tank at the station.
After that, things get more difficult.
Old 12-14-2017, 02:36 AM   #31
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
1) E85 without a proper tune
2) battery suck
3) Bad Alternator
Get a free check at pep boy, oreiley first, if battery and alternator are ok, go to a dealer.
FR-Sky is offline   Reply With Quote
Old 12-22-2017, 08:23 PM   #32
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by PetrolioBenzina View Post
Trouble starting in cold temps running E85 is normal, which is what I think you are saying.
You went too far back in the thread!
Guess so.
Regardless of how far back in the thread he went, I have had E85 for some time in sub freezing temps and with a few tuning adjustments it starts up fine.
Old 12-22-2017, 08:44 PM   #33
Itsalex is not running E85 so all of the answers to his questions saying that E85 is the issue are meaningless in his context.
Old 12-22-2017, 10:04 PM   #34
That's wonderful news. I'm thrilled for you.
Old 12-23-2017, 11:57 AM   #35
navanodd
Drives: 2013 BRZ Sport-tech WRB
Is this your daily? How long since you last filled up with gas?
If it's been a while, could be the low RVP of summer blend gas causing it to be difficult to ignite when cold.
navanodd is offline   Reply With Quote
Old 02-01-2018, 12:42 PM   #36
itsAlex
itsAlex's Avatar
Update:
It's been more than a month since I've experienced this issue again so I don't think my vehicle is at fault. Since the last time it's happened, the temperatures have only been colder and it starts just fine.
I think it's safe to assume that I probably had a bad batch of gas or something. Will update if it happens again.
The Following 2 Users Say Thank You to itsAlex For This Useful Post:
DandoX (02-01-2018), Tcoat (02-01-2018)
Old 02-01-2018, 01:34 PM   #37
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Update:
Thanks for the update hopefully it was some bad gas and the issue doesn't return.
DandoX is offline   Reply With Quote
Old 02-04-2018, 01:00 PM   #38
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
My steering wheel has been extremely squeaky this year... I've been meaning to look into the issue but haven't had a chance... From what I've seen on here others have run into this issue when it's cold out as well...
Sometimes cold weather does weird things...
02.ACCORD.DUDE is offline   Reply With Quote
The Following User Says Thank You to 02.ACCORD.DUDE For This Useful Post:
Tcoat (02-04-2018)
Old 02-10-2018, 02:35 AM   #39
sniffpetrol
sniffpetrol's Avatar
Drives: 2013 Scion FRS
Something a bit funny happens when I've just started my car. I pull away, and as I accelerate the car feels to lack power, not that I'm flooring it or anything. Just the first time I accelerate, then after that it's fine.
Barely Qualified Car Guys Facebook Youtube
sniffpetrol is offline   Reply With Quote
Old 02-10-2018, 02:45 AM   #40
Do you jump out of bed and do a sprint? The car just needs to wake up.
Stop sniffing petrol!
HKz (02-10-2018), humfrz (02-10-2018)
Old 02-10-2018, 03:02 AM   #41
The ECU is just protecting the engine until it warms up a bit ...... not to worry.
Just stop doing this .......
Weird hot start issue mike the snake Software Tuning 21 01-18-2021 08:03 PM
Car won't start! Making weird sounds. B_Rad Issues | Warranty | Recalls / TSB 35 01-25-2017 06:33 PM
Cold Start Help Kayysonie Software Tuning 39 04-01-2016 12:35 AM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 03:55 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
