#15 | |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Did you swap the sensors before ordering a new one? It's an easy way to tell if the sensor itself is borked, or if it's something deeper. If you switch the affected sensor with one of the other ones, theoretically the code should change to reflect the new position of the bad sensor, assuming the sensor is bad. If the sensor is fine, the code will stay the same, which would mean you are looking at a deeper problem. That is exactly what happened to me. I would have said to do this before you ordered a new valve, but meh. At least it's not a super expensive part. Good luck!
@bpennerz
#16 |
The manual will answer this:
https://demos.starbase7.net/t3Portal..._rm_index.html P0018 = 2A If you are in front of the car looking into the engine bay from the front of the car, Bank 2 will be on your right side. "A" would be the intake side which is the top of the engine. So the top right sensor is the one for P0018. Last edited by ermax; 12-13-2017 at 03:57 PM. |
#17 |
Drives: None
Thank you both!!!
#18 | |
A = Intake (top side) B = Exhaust (bottom side) Bank 1 is the left side or passenger side on the LHD models. Bank 2 is on the right side.
| The Following User Says Thank You to ermax For This Useful Post: | RL_BRZ (05-12-2019) |
#19 | |
Drives: None
#20 |
Isn’t P0018 the VVT sensor? Wouldn’t you swap the VVT sensor to troubleshoot that rather than the OCV?
#21 |
Drives: None
It's a host of potential issues, I'm just hoping it's not the cam sprockets. I'll look into swapping the VVT sensor as well (mostly read about swapping OCV). Thanks!
#22 |
Drives: FT86
not 100% either sorry maybe swap both
#23 |
Drives: None
So I just swapped the position sensors and drove around and shut off the engine 5 times. So far the CEL has not shown up. Vs earlier today I swapped the OCVs and the error light came back after one restart. We’ll see what happens tomorrow but fingers crossed...
#24 | |
Strange that it didn’t come back. Maybe it was just contamination on the sensor that cleared up when you moved them around. I will cross my fingers for you too. I bet a new sprocket would be pricy and labor wouldn’t be fun either. |
#25 | |
Drives: None
Thanks again for the help, guys! |
| The Following User Says Thank You to Jamestl For This Useful Post: | Ultramaroon (12-14-2017) |
#26 |
Drives: Track preped NA FRS
Hope it is the sensor, it was in my case, a very easy and painless fix. *fingers crossed for you*
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Ultramaroon (12-14-2017) |
#27 | |
@bpennerz
#28 | |
I was only 10k (km) out of my warranty when it happened, so I e-mailed Subaru Canada to see if they would help. They ended up investigating, and less than 2 weeks later, offered to cover the cost of all parts involved in the repair, and I only had to pay labour, which meant I ended up only $650 out of pocket instead of $2500+ out of pocket. If you are still within your warranty, there's a good chance it will be 100% covered. If you are outside of your warranty, it may be worth at least contacting the manufacturer to see if they will help. I would have ended up $2500+ out of pocket if I hadn't e-mailed them to see if they'd help. Hopefully your issue is gone for good, but if not, definitely consider it.
@bpennerz
| The Following User Says Thank You to SLVRSRFR For This Useful Post: | Ultramaroon (12-15-2017) |
| P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 05:15 AM |
| P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
| P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
| p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 03:49 PM |
| OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 09:24 AM |
