Old 12-04-2017, 09:03 PM   #1
Decep
Drives: 2013 FR-S Series 10
215 on 17x8
Looking at getting RPF1s when my tires wear out (im at 24K but they have some life in them yet). I want to keep things lightweight and darty and i dont necessarily need massive grip so I dont want to go bigger on tires (225s are also a bit pricier i would expect). So basically just want better looking and lighter rims.
Obviously these will fit, but will i lose any of the fun of the stock handling by going up to 8" rims? Will stretched 215s wear much worse on 8" ?
Considering just sticking with 7" since im not planning on going bigger on tires. plus the extra protection on curb rash is nice.
I'd go with perhaps the conti extremecontact sports since they're quite a bit cheaper than michelin PSS and almost as good.
Old 12-04-2017, 09:12 PM   #2
swarb
Handling is more affected by the tire than the wheel width. If more grip is what you consider fun, then no; you won't lose any fun.
Go to tire rack and read the tire spec. It will fit 7-8inch rim. Tire wear will be the same.
PSS are over priced and over rated.
You will be happy with the conti's.
Old 12-04-2017, 09:37 PM   #3
jamal
jamal's Avatar
Drives: Legacy GT
With high performance summer tires, which tend to run a little wide, 215 on an 8" rim isn't even a stretch. The measured tread width of a 215/45-17 hankook rs3 or -4 for example is 7.7 inches. Ideally you have the rim slight wider than the tire as it reduces lateral movement of the casing.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
Teseo (12-04-2017)
Old 12-04-2017, 11:26 PM   #4
Decep
Good feedback, thanks bros.
Should i just go to the dealer to have the rims mounted, since they have to program the TPMS anyway? Or can other tire shops do this?
Old 12-04-2017, 11:54 PM   #5
swarb
If you are swapping the tpms you do not need to reprogram. If you buy new tpms, some tire shops can reprogram them.
Old 12-05-2017, 12:37 PM   #6
Racecomp Engineering
Enkei does have 17x7 and 17x7.5 RPF1s as well. Would be a better fit with the 215s.
- Andrew
xxr 527 17x8.25 jsbrz Wheels and Tires 9 03-09-2016 02:05 PM
17x8 all around or staggered 17x8 & 17x9 cawith Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-12-2015 12:27 PM
245-40-17 on 17x8 +35??? Fast_Freddy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-27-2013 02:49 AM
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop AGM6789 AUSTRALIA 17 11-10-2012 05:10 AM
17x8 +35, will it rub? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-31-2012 03:26 AM
