| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#3571 | |
Country Boy 4 Life
Tires are made different and will fit different. the specs below I grabbed from tirerack.com 245/40/17 tire comparison S.Drive tread width = 8.8" BFG Sport Comp2 tread width 9.7" Just something to think about if you are worried about clearance.
I LIKE TIRES! |
#3572 | |
Country Boy 4 Life
Compared to your 8" +40 wheel, His 9" wheel with a 5mm spacer wheel will be 7.7mm closer to the strut. And the outer rim edge will poke out 17.7mm more then yours.
I LIKE TIRES! |
#3573 |
Just the tip
Drives: 2017 DGM BRZ
Curious if this would fit on a 2017 brz:
17x9 + 38 Gramlight 57cr 245/40/17 MPSS Eibach pro kit (~1" drop) |
#3574 | |
Country Boy 4 Life
Yes, they will bolt on and should not rub, but... You will poke a little. There will be very little clearance between the rim/tire and spring/strut. Adding camber bolts will decrease this clearance more. If these things don't bother you, then yes they will fit.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | wolffbite (11-15-2017) |
#3575 | |
Just the tip
Close to flush is my goal. So to reduce the poke I would need more negative camber (camber bolts) to suck the wheel towards the fender, but that would make the clearance issue worse? Should I be very concerned about minimal clearance? Maybe I should be looking at a narrower wheel/tire combo... Greatly appreciate the help... there is a boatload of information to digest on this topic and I want to make an informed decision. |
#3576 | |
Country Boy 4 Life
No problem. Camber bolts "lean" the top of the wheel inward towards the strut. After some research; this setup will work just fine. Read through this short thread. http://www.ft86club.com/forums/showt...t=28437&page=9 ![]()
I LIKE TIRES! |
#3577 | |
Drives: 2017 Toyota 86
Will these wheels fit with no rubbing or clearance issues? If yes, how much poke will there be? Thanks |
#3578 | |
Country Boy 4 Life
On stock suspension you will have appox. this much poke... Read post #102 http://www.ft86club.com/forums/showt...t=28437&page=8
I LIKE TIRES! |
#3579 |
Drives: 2013 Scion Frs Whiteout
anyone know if a set of 18x8.5 +45 offset with a 245/35 in the front and 18x9.5 +45 offset rear with a 255 or 265/35 will have any clearance issues on bilstein b16 coils?
#3580 |
Drives: 2017 BRZ
Anyone know what spacers to run on a lowered BRZ (probably 1.5”) with the performance package wheels? Will it be the same as the normal wheels or do I need to adjust for the wider wheel and go down a size in spacers. I’m thinking 15f/20r or 15f/25r.
#3581 |
Drives: 2014 GT86
As main bits in car parts/suspensions are same, just different sized wheels, and different brakes and coilovers, why would it be different? Check in wheel directory sticky thread opening post wheel flushness chart lines that are about PP wheel sizes for flushness offsets. I'd extrapolate what flushness for 1.5" lowering might be from difference between mentioned there stock heigh vs 1" lowered values.
| The Following User Says Thank You to churchx For This Useful Post: | Barefootdan (11-22-2017) |
#3582 |
Drives: Not a BRZ
Need some feedback on my new setup:
18x9.5 +38 offset - 255/35-18 Bridgestone S04 Pole Position - Fortune Auto 500 coilovers Potential issues? |
#3583 | |
Country Boy 4 Life
![]() http://www.ft86club.com/forums/showthread.php?t=41083 It will fit fine...
I LIKE TIRES! |
#3584 | |
Drives: Not a BRZ
They are on now - uploading some pics. |
| The Following User Says Thank You to GalloVecchio For This Useful Post: | Leonardo (12-04-2017) |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
