Old 11-13-2017, 04:39 PM   #1
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
Here we go again! BRZ vs FR-S Crickets!
Ok. I have a 2015 BRZ that has always had crickets. I can usually get rid of them by switching to Chevron gas (must be their detergent package). Anyhow I'm showing the FR-S TSB with 4 revisions of the fuel pump while Subaru is showing my 2015 as having the latest pump model. My question is to the other 2015+ BRZ owners, how did you get Subaru to fix your crickets? I'd like to get this replaced before the car goes out of warranty.
PNW-BRZ is offline   Reply With Quote
Old 11-13-2017, 04:48 PM   #2
Somerandom18
Drives: 2017 manual BRZ
If it's a TSB warranty is irrelevant. I had crickets but headers fixed it so Subaru got off easy.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 11-13-2017, 06:04 PM   #3
chamourian
chamourian's Avatar
Drives: White Aozora BRZ
I also have a 2015, and my local Subaru dealership replaced my fuel pump last week because of the crickets. I only got mine done because a friend had his replaced by a particularly overachieving tech. I had tried in the past and they had just turned me away
chamourian is offline   Reply With Quote
Old 11-13-2017, 06:32 PM   #4
new2subaru
Weight Weenie
Drives: 15 FR-S
I got rid of mine by using Shell 91
Old 11-13-2017, 07:57 PM   #5
Why is warranty irrelevant? A TSB is just a technical document that tells the techs how to repair a known problem. It is not a recall or even a notice to customers that there is any issue. A dealer can turn you away for a TSB item if they don't feel your car has that issue. Any repairs done under a TSB are indeed warranty work.
humfrz (11-13-2017), stevesnj (11-14-2017)
Old 11-13-2017, 08:46 PM   #6
Teseo
Drives: frs
I get crickets when use 93 oct with 10% ethanol
Old 11-13-2017, 08:57 PM   #7
Yep, this concept seems to cause ongoing confusion. Maybe Wiki can help ....
https://en.wikipedia.org/wiki/Techni...rvice_Bulletin
Old 11-13-2017, 08:59 PM   #8
Welp, now THAT would be my plan .....
Old 11-13-2017, 09:04 PM   #9
MrDinkleman
Drives: 2016 Oceanic, "base" model
Chevron gas eliminated the crickets for me as well. But Mobil gas seems to idle the smoothest but with crickets. So, I have been meaning to try Mobil and adding Techron to see if I get the best of both worlds but I keep forgetting to bring the bottle of Techron with me when I fill up.
MrDinkleman is offline   Reply With Quote
Old 11-13-2017, 09:23 PM   #10
new2subaru
Weight Weenie
Drives: 15 FR-S
ethanol
I get crickets when I use 94 octane with 10% ethanol
Old 11-13-2017, 10:40 PM   #11
Vital
Drives: 2015 BRZ
I have a 2015 BRZ and I got the new fuel pump in July. I just showed them the TSB or you can tell them to look up the updated TSB and they should install the new fuel pump. After I got the new fuel pump I have no crickets.
Old 11-14-2017, 09:44 AM   #12
stevesnj
stevesnj's Avatar
Been a 11 months and no crickets, if it bothers you take it back until there are none. They could possibly been installing the wrong pump from the wrong TSB.
My 2016 Build thread
Old 11-14-2017, 09:55 AM   #13
Tokay444
How many did it take?
Old 11-14-2017, 05:10 PM   #14
PNW-BRZ
PNW-BRZ's Avatar
. What TSB did you show? All the ones i could find and Subaru found shows that my 2015 is outside the VIN #'s of the TSB and that they don't show a later part # (unlike Scion).
FRS / BRZ Crickets Fix Urmyson Engine, Exhaust, Transmission 11 07-12-2016 05:08 PM
Crickets Wilfred86 Southern California 4 06-16-2016 03:05 PM
The crickets... RojerLockless Issues | Warranty | Recalls / TSB 67 02-10-2014 02:20 AM
Crickets? Jertronic Scion FR-S / Toyota 86 GT86 General Forum 15 05-24-2013 08:38 PM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-05-2013 11:29 PM
