Old 11-10-2017, 09:56 PM   #15
Originally Posted by Icecreamtruk View Post
Edit: dammit,
Icecreamtruk (11-12-2017)
Old 11-12-2017, 08:28 PM   #16
Icecreamtruk
Drives: Track preped NA FRS
Originally Posted by Twitchy313 View Post
@Icecreamtruk Makes perfect sense, thank you for that! So you think that the loud rattle (leak noise) is caused by the no shield and gasses mix? What are the chances that i wrap them and that sound goes away?
Wrapping them made the sound go away for the most part for me. It should at the very least reduce it considerably, its a case by case depending on the header itself.
Icecreamtruk is offline   Reply With Quote
Old 11-14-2017, 11:52 PM   #17
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
So I got them looked at, and it turns out there is a hole in the collector. Called the company and they're going to replace them, I just knew there was something wrong.
Twitchy313 is offline   Reply With Quote
Catted vs resonated front pipe noise reduction difference raven1231 Engine, Exhaust, Transmission 11 03-30-2017 11:20 AM
Mounting aftermarket header. Do i have to wrap/ ceramic coat for heat protection? giorgi0424 Engine, Exhaust, Transmission 9 03-03-2017 09:58 PM
Catless header noise reduction SlydwinderFT86 Engine, Exhaust, Transmission 11 08-24-2016 02:37 PM
Request: Oil Pan heat wrap? 1Cor10:23 DIY (Do-It-Yourself) Guides 14 11-26-2014 05:01 PM
DIY Gold Foil heat wrap intake box autoCAR DIY (Do-It-Yourself) Guides 35 02-20-2014 03:22 PM
