Old 11-10-2017, 08:22 PM   #57
Tokay444
Originally Posted by Kicknwing View Post
i mean they have only been used in cars both street and track for years. So i see no reason why they wont work on here. also don't see why greddy and sard would invest thousands on r&d for something that wont work. they would never see there return
Sure, but this is one the best, most even flowing factory manifolds I’ve ever flow benched.
Old 11-10-2017, 10:33 PM   #58
Kicknwing
Drives: 2014 frs
but that doesn't mean it cant still be improved upon. its still not out to the general public. i do know that greddy has been testing there's on ken gushi's street car.
Kicknwing is offline   Reply With Quote
Old 11-11-2017, 06:11 AM   #59
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
What kind Apples to oranges are you talking about to ruin a thread?
Why is ITB on NA cars a strange things? tell that to BMWs?
IT's just good for some ppl's build, FI or not.
Not everything is about right or wrong, this is not stupid politics, just drop it.
The Following User Says Thank You to chaoskaze For This Useful Post:
venturaII (11-11-2017)
Old 11-11-2017, 06:46 AM   #60
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Is it weird i keep coming back to this thread just to see how much this argument has progressed?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following 5 Users Say Thank You to Spawn_Of_Creation For This Useful Post:
CSG Mike (11-11-2017), JazzleSAURUS (11-13-2017), meWant (11-12-2017), Williampreza (11-11-2017), wparsons (11-15-2017)
Old 11-11-2017, 02:00 PM   #61
Tokay444
No one said it was wrong.
Comparing two completely different engines, one with boost and one NA, as some type of justification is stupid.
Old 11-11-2017, 04:03 PM   #62
gtengr
Drives: 2017 BRZ
Why all the focus on ITB's when a plenum is being added? That and the new runners will have a bigger effect on power.
gtengr is offline   Reply With Quote
Old 11-11-2017, 04:34 PM   #63
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
BMW obviously doesn't know what they're doing by putting ITBs on hugely successful STREET motors like the S14, M88/S38, S50, S54, S62, S85, etc. Or Ford with any of their Cosworth offerings. Or is the argument now simply going to be that a forced induction motor was referenced earlier? I seriously doubt the RB26 was referenced as a comparable motor to the FA20; only that ITBs were quite successfully used on it as a road-going motor. If that's the case, then there's really no point comparing ANY motor with another unless they are 100% identical, which is really pretty pointless.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 11-11-2017, 04:45 PM   #64
Tokay444
Originally Posted by venturaII View Post
BMW obviously doesn't know what they're doing by putting ITBs on hugely successful STREET motors like the S14, M88/S38, S50, S54, S62, S85, etc. Or is the argument now simply going to be that a forced induction motor was referenced earlier? I seriously doubt the RB26 was referenced as a comparable motor to the FA20; only that ITBs were quite successfully used on it as a road-going motor. If that's the case, then there's really no point comparing ANY motor with another unless they are 100% identical, which is really pretty pointless.
Do you have data on ANY of the mentioned motors, WITHOUT ITBs?
Make an apples to apples comparison or don’t bother.
Post some gains made on an NA Honda from going ITB. That could actually be useful info.
Old 11-11-2017, 04:47 PM   #65
venturaII
venturaII's Avatar
I bet BMW and Ford have plenty. Are you suggesting that removing the ITBs and going with a single TB would have no effect on power output or delivery? Or even more absurd, would IMPROVE either?
I'm sure that data is readily available (in fact, you can't Google 'Honda' and 'ITB' and not find tons of info), but then we'd be comparing apples to oranges, according to you...
The Following User Says Thank You to venturaII For This Useful Post:
Old 11-11-2017, 04:49 PM   #66
Tokay444
Edited.
Old 11-11-2017, 07:00 PM   #67
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
That is EXACTLY what started the argument.
Originally Posted by mav1178 View Post
Originally Posted by Spawn_Of_Creation View Post
If there are gains to be had, it would be in the 8500+ rev range where the stock plenum has restrictions.
Tell that to Nissan, who put this type of system on the R32-34 Skyline GT-R as a factory design with a rev limit of 7500, same as our engines.
The Following User Says Thank You to x808drifter For This Useful Post:
Tokay444 (11-11-2017)
Old 11-11-2017, 07:20 PM   #68
venturaII
venturaII's Avatar
Only in that the RB26 operates in the same rpm range as ours, meaning ITBs are not some sort of component reserved for super high rpm motors. Likewise, the M88/S38 motors only make peak power in the mid 6000rpm range, but still use ITBs.
Old 11-11-2017, 08:00 PM   #69
CSG Mike
CSG Mike's Avatar
Typical ITB results on a NA S2000.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Gadzooks (01-24-2018), JazzleSAURUS (11-13-2017), Teseo (11-11-2017), Tokay444 (11-11-2017)
Old 11-11-2017, 08:44 PM   #70
Tokay444
Can we see the rest of the build? I have a had time swallowing a 45hp gain on an already strung out S2000.
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp Trojan_SC Engine, Exhaust, Bolt-Ons 19 03-28-2018 07:52 PM
Bad news good news ls1ac BRZ First-Gen (2012+) — General Topics 2 10-01-2016 09:11 PM
SARD 86 GT1 Body Kit + SARD LSR Wing nigel-jdmparts Cosmetic Modification (Interior/Exterior/Lighting) 1 04-27-2015 12:41 PM
