Old 11-08-2017, 02:01 PM   #1
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
SARD ITB (4 Throttle) News!
Just saw this posted by SARD on FB:
http://www.sard.co.jp/pdf/1710_4Throttle.pdf
https://www.facebook.com/SARD.Customize/
Seems to be an updated, final production version that is actually available. Anyone want to translate the Japanese for us?
Williampreza is offline   Reply With Quote
The Following 3 Users Say Thank You to Williampreza For This Useful Post:
-Willis-86touge (11-08-2017), cyde01 (11-15-2017), gtengr (11-08-2017)
Old 11-08-2017, 02:12 PM   #2
Icecreamtruk
Drives: Track preped NA FRS
So they are putting it out at about the same time as the Greedy version. Two ITB kits at the same time, I wonder if we are about to see some interesting changes in NA tuning for our cars.
Old 11-08-2017, 02:21 PM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'm hoping to see some of the top-tier companies jump on these and see what sort of extra jam and response we get!
I'm imagining an E85 full bolt on ACE powered car would be preeeetty righteous.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 11-08-2017, 02:22 PM   #4
Tokay444
Inb4 no gains.
The Following User Says Thank You to Tokay444 For This Useful Post:
R2RO (11-18-2017)
Old 11-08-2017, 02:27 PM   #5
JazzleSAURUS
Originally Posted by Tokay444 View Post
Inb4 no gains.
Most likely minimal, if any gains seen on a dyno sheet, with substantial gains felt from the drivers seat, and small gains seen in lap times.
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
Cole (11-08-2017)
Old 11-08-2017, 03:21 PM   #6
Tokay444
Good ol' placebo effect never disappoints.
Tcoat (11-09-2017)
Old 11-08-2017, 06:13 PM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
4x the potential problems. I don't understand the benefits. The MAF is in the stock position even.
Old 11-08-2017, 08:55 PM   #8
armstrom
Drives: none
ITB's don't improve throttle response by reducing the distance between your air metering device and the throttle body, the idea is to reduce the distance between the throttle body and the combustion chamber. In the strictest sense MAF placement doesn't really impact throttle response as much as you might think. To increase throttle response you want to reduce the delay between opening the throttle and an increase in charge air pressure. Now, of course you need to add more fuel to match the added air and if you relied only on the signal from your MAF then the fuel would lag behind the increased air pressure. However, pretty much all modern engine management systems provide numerous adjustments to handle tip-in enrichment. This is specifically due to the delay between the increased fuel demand and the MAF signal. This delay is present on pretty much ALL MAF systems, even our stock system. ITBs cause other difficulties in tuning but handling lag in MAF signal is not a big deal.
Heck... full-out race systems will often use Alpha-N tuning which bases fuel purely on TPS and RPM. Horrible for a street setup but it is a very simple system for cars that operate at high load most of the time and don't have to worry about stop and go traffic or other moderate load scenarios that trip up Alpha-N.
armstrom is offline   Reply With Quote
The Following 5 Users Say Thank You to armstrom For This Useful Post:
Cole (11-09-2017), CSG Mike (11-11-2017), GoJoshGo (04-04-2018), JazzleSAURUS (11-09-2017), wparsons (11-15-2017)
Old 11-08-2017, 08:58 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Yes, we heard you the first time you posted in this thread.
The Following 6 Users Say Thank You to mav1178 For This Useful Post:
chaoskaze (11-11-2017), JazzleSAURUS (11-09-2017), Lorico (11-09-2017), Teseo (11-08-2017), weederr33 (11-08-2017), wparsons (11-15-2017)
Old 11-08-2017, 10:33 PM   #10
Grady
Grady's Avatar
The more you spend the more you have to justify to yourself of what a good deal it was.
The Following User Says Thank You to Grady For This Useful Post:
Tokay444 (11-09-2017)
Old 11-08-2017, 10:45 PM   #11
Turdinator
Señor Member
Turdinator's Avatar
Looking at the photos, I suspect both brands use the same throttles and manifolds to the heads but with their own runners and plenum.
Both brands have a fairly abrupt angle of runner just about the throttles.
1974 TA22 Celica
2013 86 GT
The Following 2 Users Say Thank You to Turdinator For This Useful Post:
nikitopo (11-09-2017), Williampreza (11-08-2017)
Old 11-09-2017, 09:00 AM   #12
Tokay444
Sorry, who are you?
Old 11-09-2017, 10:58 AM   #13
ajh88
Drives: 2013 Firestorm FR-S
Curious what this or the Greddy achieves. If slight gains, then maybe some great sounds?
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 11-09-2017, 11:27 AM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It says ...
· Each cylinder intake is longer and the throttle area is enlarged. There is an improvement in responsiveness and intermediate power
· Φ 45 Throttle × 4 / Surge tank / piping etc. required for installation
· Genuine injector can be installed
An ECU setting is needed.
The Following 3 Users Say Thank You to nikitopo For This Useful Post:
chaoskaze (11-11-2017), Turdinator (11-09-2017), Williampreza (11-09-2017)
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 01:20 PM
SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp Trojan_SC Engine, Exhaust, Bolt-Ons 19 03-28-2018 08:52 PM
Bad news good news ls1ac BRZ First-Gen (2012+) — General Topics 2 10-01-2016 10:11 PM
SARD 86 GT1 Body Kit + SARD LSR Wing nigel-jdmparts Cosmetic Modification (Interior/Exterior/Lighting) 1 04-27-2015 01:41 PM
