Old 11-01-2017, 07:31 PM   #1
mr.brz1234
Drives: sport-tech
Rubberized Rust Proofing Vs Oil Based
just want to know which would be better as my brz is a daily driver and winter is fast approaching pros/ cons for each would be nice or the best overall
thanks!
mr.brz1234 is offline   Reply With Quote
Old 11-06-2017, 04:59 PM   #2
Localghost
Drives: 2014 WRB BRZ
A rubberized coating should be permanent while an oil-based coating will wear off the more you drive/wash. Rubberized coatings can chip off, so they can need to be touched up.
I just opted to use Fluid Film on all the bolts, suspension, and driveline components on my BRZ in order to save a few bucks over a professional undercoating. It cures as a wax-like substance that will prevent water from coming in contact with the parts it covers. From the reviews I was reading, it sounds like it needs to be applied yearly as it will wear off. Be careful not to get any spray on your brake rotors if you go this route. Any film that gets on the exhaust will burn off the first time you run the car, but you should try to avoid it anyways.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Localghost is offline   Reply With Quote
Old 11-06-2017, 09:55 PM   #3
ls1ac
ls1ac's Avatar
We use Fluid Film on equipment that we leave out side for long periods of time. It is lanolin based and is sort of self healing. It can be cleaned of when needed.
It is available in one gallon cans that that can be sprayed as an undercoat.
Old 11-07-2017, 12:31 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
The undercoating from the factory on the unibody is pretty tough stuff. You could also look into underpanels for the areas they cover.
As mentioned above, drive components, suspension, and the rear subframe in particular are really the only parts you need to worry about. I had a rear subframe rust out on an otherwise good Subaru.
I had some sort of oil based undercoating on a previous car. It gets really nasty and grimey over time. Not pleasant to try to do any work on anything coated with it, which was pretty much everything...
The Following User Says Thank You to Spuds For This Useful Post:
Tcoat (11-07-2017)
Old 11-07-2017, 04:41 PM   #5
mr.brz1234
Drives: sport-tech
cool thanks i guess i will just put the car up on the hoist and spray down the main parts as mentioned above
Thanks!!
Old 11-07-2017, 05:37 PM   #6
Ernest72
let it rust and just drive the car. by the time its really rusted, you will be done with the car or it will be the perfect time to upgrade that part.
The Following 3 Users Say Thank You to Ernest72 For This Useful Post:
humfrz (11-10-2017), JD001 (11-10-2017), Tcoat (11-07-2017)
Old 11-07-2017, 06:22 PM   #7
gutbuster
Drives: 13 FR-S
I been using Fluid Film NAS for years on all my cars driven in winter.
Ziebart and coatings like that are crap.
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
gutbuster is offline   Reply With Quote
Old 11-09-2017, 01:27 PM   #8
jordan7831
Drives: 2016 Halo FRS
Hi everyone, noobish question, but did all model years of the FRS come with factory undercoating?
jordan7831 is offline   Reply With Quote
Old 11-10-2017, 02:00 AM   #9
shadow_772
Drives: 2014 BRZ Limited
Another vote for fluid film. When I lived up north (MA), we would coat our vehicles yearly before winter and there wasn't a spot of rust on them. It's an achievement if you know how much salt is on the roads up there.
shadow_772 is offline   Reply With Quote
Old 11-10-2017, 02:53 AM   #10
@Tcoat , what is your take on the necessity of undercoating a FR-S/BRZ that is driven in Canada ... ??
No, this is not a trick question ......
MrFisty (11-13-2017)
Old 11-10-2017, 02:55 AM   #11
I understanding they are rust protected ..... but, I don't know if it is considered "undercoating".
Old 11-10-2017, 11:23 AM   #12
If we were talking about a 1964 Mustang or a 1980 Chevette I would say it is mandatory.
We are not talking about cars from the rust bucket eras though.
Over the last 15 years or so the manufacturers have gone to great lengths to produce cars that are far more rust resistant than the older ones. The need for rust protection on body panels went away a while ago even if the dealers would still like to sell it to you.
Are there parts that will still rust? Most certainly. Bolts, nuts, fittings, engine components and any other untreated steel or iron part will indeed rust. It may make a fastener slightly more difficult to remove or an engine component look bad but unless you are planning on keeping the car for 40 years none of this rust will actually damage anything.
We are 5 years into the car's life and there has not been a single report of any serious body rust issues. What we have seen is some slight bubbling around the window on some early 13s and a light tin strip (not a part of the body) holding a gasket in the front of the hood that got pretty bad. In comparison my mother had a 64 1/2 Mustang in 69 that was missing the whole rear floor and the wheel well archs were rotted about a good 3"s. In 1991 I had to scrap my beater 1984 Citation because the back door rusted out and flew off on the highway it had zero floor left in the hatch anyway.
My car is pretty much a worst case scenario as far as exposure goes. Not only do we salt the roads we use beat juice to make the salt stick. What makes it stick to the road also makes it stick to your car. I have a bad stone ship that actually cut the steel of my fender that happened two weeks after I got the car in 2014. In the name of science I have left it exposed through 3 winters and many, many, MANY slat accumulations. It has just recently started to develop surface rust and is probably many years away from rust through. The rest of the car (with the exception of the untreated parts mentioned above) is pristine. I would not even remotely consider undercoating on these cars. If somebody is truly concerned about the untreated parts there are several solutions as already discussed.
Spot (the picture makes it look worse than it really is)
Brink (01-07-2018), humfrz (11-10-2017), JD001 (11-10-2017), Lynxis (11-13-2017), MrFisty (11-13-2017)
Old 11-10-2017, 11:55 AM   #13
jordan7831
tcoat thank you kindly for your insights to the factory rust resistance. It's greatly appreciated having feedback from a fellow Canadian!
The Following 2 Users Say Thank You to jordan7831 For This Useful Post:
humfrz (11-10-2017), Tcoat (11-10-2017)
Old 11-10-2017, 12:50 PM   #14
I do need to add a disclaimer to my pervious post!
Ignore everything I said if you own. or are considering buying a Mazda.
They alone do not seem to have figured out how to prevent rust and the car will all but disappear in under 10 years.
Rust proofing by Toyota dealership... NitroXIII Issues | Warranty | Recalls / TSB 16 11-16-2015 01:09 PM
Rust proofing? rip curl CANADA 17 06-20-2014 01:40 AM
Rust-Proofing Gunk Taro CANADA 4 10-10-2013 07:57 PM
Subaru dealership rust proofing tinma Issues | Warranty | Recalls / TSB 49 09-20-2013 02:26 AM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
